2000 trooper abs and tod code lights
Postby joe steele » Tue Mar 22, 2011 12:24 am
2000 trooper Put two new split boots on front outer joints. A messy but easy fix. Have a abs code light on and the bottom axle light is blinking with a check light . I guess the bottom axle is the rear. How do I find the code. Won't show on regular scanner, Do i NEED a TECH 2.
joe steele
Postby TKEPA251 » Tue Mar 22, 2011 1:04 pm
Try a Modis scanner. Most Transmission shops use those
Not for wealth, rank, or honor, but for personal worth, and character. Tau Kappa Epsilon est. January 10, 1899.
"Rock Robster" of The Isuzu Outlaws
'98 Rodeo; 6VD1, 4L30E, Dana 44, 1.5" wheel spacers, Load Warrior, CB, cold air intake, glass pack/turndown, and a few stickers. 178,000 miles and counting!
TKEPA251
Postby deermagnet » Tue Mar 22, 2011 9:08 pm
As you know, the ABS, TOD, and airbag codes cannot be read and erased with an OBDII scanner, so here's how you easily do it yourself without a scanner. This is for a '99 Isuzu Vehicross that I posted over at the Vehicross forum. I just checked the '00 Isuzu Trooper Shop Manual and it's exactly the same procedure.
-ABS-
-TOD-
This is a wire that you use to jump the terminals at the data port-
Here's a video I made showing the TOD check light flashing the code.
The code is 12 of course, meaning everything is normal.
5 seconds, 439 kb, wmv file-
http://www.drivehq.com/file/df.aspx/publish/mgpa/vids/tod.wmv
5 seconds, 5.9 mb, mpg file-
http://www.drivehq.com/file/df.aspx/publish/mgpa/vids/tod.mpg
-Airbag-
Mark
'99 Vehicross, 12 year original owner, 285K, 3.5L, 4L30E
deermagnet
Mi Amigo
Have thanks: 9 times
Users browsing this forum: No registered users and 22 guests
