Aisin A340H in 2001 Trooper with TOD
Postby vovkus » Thu Oct 15, 2009 12:08 am
I read all posts about Teds swap. But he have older Trooper. Anybody know, is A340H fit in TOD Trooper?
I'm ok with crossmember mods and other mechanical mods.
Questions:
1. Is it possible to utilize 4L30E bellhousing with A340H? Or tranny from 4WD Axiom will fit to the 6VE1 engine?
2. Is Trooper ECU with TOD will control A340H? (I understand, I have to do some connectors work)
3. Anybody done swap like this?
Thank you.
2001 Trooper LS with AISIN 30-40LE transmission and 4" lift
vovkus
Trail Scout
Has thanked: 2 times
Have thanks: 6 times
Postby sassee » Thu Oct 15, 2009 9:45 am
Those are jlemond questions! He knows the Aisin-Warner trans well as he helped me with the one in my Red 89
2000 Nissan Xterra SE, Currently my DD
94 Trooper S 3.2 w/ a 5-speed brand new off the showroom floor in 1994.
88 Trooper LS GONE
89 Trooper XS (Red) - GONE to a good home in Alabama
89 Trooper SE (Blackie) - Gone to a good home but won't be forgotten anytime soon!
98 Acura SLX. Sadly, it lost the engine and I can't justify putting any more money in it. Gone to crusher.
95 LS Trooper bought for parts. Now gone to the crusher.
98 Trooper, 3.5 SOLD!
89 Trooper "Blue" 2.6 w/ "Jerry Cam", 5-speed, LSD Rear, Lock Rite in front, Manual Aisins, Big brake upgrade, Rock Sliders, 15" Snowflakes with 32" MT's.
sassee
Has thanked: 4 times
Have thanks: 135 times
Postby bigpoppax2 » Thu Oct 15, 2009 12:56 pm
I'd say it will bolt up, but that would be the end of the fun.
I don't think you will be able to control the Aisin with the stock ECU.
Joe
Good judgment comes from experience, and a lot of that comes from bad judgment.
bigpoppax2
Forum Admin
Have thanks: 16 times
Re: Aisin A340H in 2001 Trooper with TOD
Postby JLEMOND » Thu Oct 15, 2009 10:19 pm
vovkus wrote:I read all posts about Teds swap. But he have older Trooper. Anybody know, is A340H fit in TOD Trooper?
Questions:
NO ON THE BELL HOUSING , COMPLETELY DIFF DESIGN, YES THE A340 FROM THE 2004 RODEO OR AXIOM WILL FIT YOUR ENG AND BOLT RIGHT UP, BUT YOU WILL HAVE TO DO YOUR OWN WIRING AND CONTROL, THE ECU OR PCM FORM THE TROOPER WILL NOT WORK CORRECTLY, , THE EASY OPART IS THE ECU IS A STAND ALONE UNIT NOT BUILT INTO THE MAIN PCM.
JLEMOND
Have thanks: 354 times
Postby vovkus » Fri Oct 16, 2009 2:33 am
thanks for reply.
Another question:
What is better to do:
1. 4L30E with custom torgue converter
or install A340H+transfer case from AXIOM?
vovkus
Trail Scout
Postby autoxgalant72 » Fri Oct 16, 2009 2:36 am
Would it even be that hard if one was to do a 4.3L to just go with the 4L60/ 60-E transmission and a transfer case out of a blazer/s10. I think it would be easier to get driveshafts to work with the GM yokes on the T-case then it would be to adapt a 4L30E to a motor its not designed for.
autoxgalant72
Postby vovkus » Thu Oct 22, 2009 7:18 pm
The project is started!
I ordered Axiom transmission.
Will keep post progress.
vovkus
Trail Scout
Postby GenXr » Fri Oct 23, 2009 2:36 pm
If this could be kitted, that would be an awesome swap.
zippo wrote:My Last post was a Joke i swear...
GenXr
Postby vovkus » Fri Oct 23, 2009 4:32 pm
need Axiom electric schematics. Possible, I will build custom transmission/transfercase controller, which will comunicate with Troopers ECU.
vovkus
Trail Scout
Postby suv_drift » Thu Oct 29, 2009 12:49 pm
Just one quick questions, does it needs the transfer case? (bolts to driveshaft directly) I want to make something custom as well, not rebuilding a 4L30-E for 10k miles......
'02 Isuzu Trooper 3.5L
Custom 2" drop on front, 2.5" on rear / Spectre cold air intake / HID conversion (yellow) fog lights. 9007 6000k HID headlights / Orange corners and fog lights
No longer with me, but remembered in the heart......
'11 Kia Soul. red'ish 2.0 auto / 6k HID's headlight and fogs/ blackout tails / Euro burner Grill / 18" wheels
Toaster Ride
suv_drift
Trail Rider
Postby vovkus » Fri Oct 30, 2009 7:06 pm
I got transmission with TOD transfercase from 2004 Axiom.
It will be delivered at Tuesday. Will post some pics then.
Mechanically looks like almost direct swap. Will be some tricks with electric/electronics. I hate to pay 1.5K for universal TCU. It is nice to have that unit, probably will save a lot of time, but I just can not afford it.
On that point I do not know yet, what to do with TCU.
Posible solution:
adopt TCU from Jeep or Toyota
to built a custom TCU.
vovkus
Trail Scout
Postby [email protected] » Sun Nov 01, 2009 10:03 pm
I thought you were selling your trooper?
99 Passport, BFG A/T, 5" Taller via OME 919's and coil spacers, Audio system, 4x Hella
[email protected]
Postby vovkus » Mon Nov 02, 2009 3:21 pm
I did try to sell. But
1. I do not want to sell it to random repson.
2. Nothing on the market right now is better then my Trooper.
So, I decided to continue improovement and will use it for purpose.
vovkus
Trail Scout
Postby vovkus » Wed Nov 04, 2009 12:40 pm
I got documentation for 2004Axiom.
The good news:
1. TOD control unit is same as Trooper TOD control unit.
I have two options here. Use my old transfer case with all wiring, or switch to unit from Axiom. In this case I have to add some control circuits, like 4WD electrical switch e.t.c Not a big problem.
2. 2004 Axiom used separated Transmission Control Unit, not like ECU in the Trooper. TCU communicate to the ECU via CAN bus.
On that point I do not know yet how to merge Trooper ECU with Axiom TCU.
Will do more research.
vovkus
Trail Scout
Postby vovkus » Wed Nov 04, 2009 7:43 pm
Received shipment today from qualityautoparts.com
Instead of 2004 Axiom they sent 2004 Rodeo unit (no TOD).
On that point, I do not know which one is better. I think, my transfer case will fit to this transmission.
Transmission itself looks .... salty. But all sensors and cables are not damaged mechanically.
vovkus
Trail Scout
Postby vovkus » Thu Nov 05, 2009 1:42 am
Still need manual for AISIN 30-40LS transmission. It is different from A340H!
Based on electrical diagrams and descriptions 30-40LS has a pressure control solenoid for smooth shifting with PWM control (same as 4L30E),
same two solenoids for shifting gears. And TCC solenoid. Looks like PWM controlled also. The set of sensors are the same.
I think it will be possible to run 30-40LS with Trooper ECU.
It will be great to be able re-program Trooper ECU for control 30-40LS directly.
vovkus
Trail Scout
Postby vovkus » Wed Dec 30, 2009 9:37 pm
Finally got some time to continue this project. Now old 4L30E is removed.
The transfer case is unbolted from transmission. Good news the length of 30-40LS is the same as 4L30e. I think, will be no problem with cross-member installation.
Some bad news. When I try to unbolt gears switch arm from switch shaft on the new transmission, I broke threaded end of the shaft. Is it possible to replace shaft without disassembling whole unit? Will deal with this after NY.
Still think how to connect new transmission to the Trooper ECU. It is possible, to fabricate bracket for old transmission position switch, but for me way easy to built relays module for emulate old switch and utilize 30-40LS switch.
Or will use more expensive solution:
http://www.powertraincontrolsolutions.com/transcontrol.php
Will continue posting.
vovkus
Trail Scout
Postby vovkus » Fri Jan 22, 2010 12:53 pm
Latest update.
AW30-40LS checked, re-sealed. New filter is installed. Ready for installation.
I got PCM-2000 transmission control unit. There are a lot of wires need to be routed. Looks like I will spend more time for electrical work, then for mechanical.
I ordered original dipstick for Axiom 2004 from isuzuparts.com
Will put transmission on over coming weekend.
vovkus
Trail Scout
Postby vovkus » Mon Jan 25, 2010 12:45 am
AW30-40LS is installed.
Mechanically it was almost no problems to put it in.
One simple problem with ugly solution. It was impossible to connect transfer case when sensor in the stock position. I use "bracket" to fix sensor in position.
Now I have ATF dipstick:
Electrical parts almost ready. Need few more hours for complete setup.
vovkus
Trail Scout
WOW!
Postby nickya » Tue Jan 26, 2010 1:02 pm
WOW! great work vovkus! :shock:
i have an 2001 SWB Trooper with 6VE1 and 4L30E and i will definitely consider this swap when my 4L30E will die on me.
i hear from other trooper owners about their 4L30E dying on them and they keep spending big bucks for rebuilds.. i believe that you have found the solution for a fundamental problem. :salute:
nickya
Postby Trooopah » Thu Jan 28, 2010 10:40 am
Watching this thread with anticipation. Great work vovkus!!
1999 Luxury Edition Trooper - Red Mica
BFG AT KO's 265/75/16, OME Shocks/929 Springs, WARN Premium Hubs
Trooopah
Postby vovkus » Thu Jan 28, 2010 1:49 pm
Most work in this project related to wiring.
Will try to start new transmission tonight.
vovkus
Trail Scout
Postby timrkopi » Fri Jan 29, 2010 10:38 pm
what is the difference between the 340L and the 30-40 transmission?
2002 Rodeo Sport, 3.2 V6, 4WD, Auto, Hard Top, OME 912, Rancho RS99000 9 position shocks, 2" lift, heated leather, 265/70 Geolanders. EBC Green Stuff w/ slotted rotors. 6.5" Infinity Kappa in front/ 6.5" Polk dbx in back.
50 Series Deltaflow (too loud)
timrkopi
Postby vovkus » Sat Jan 30, 2010 2:10 am
AW30-40LS has anti-slip system.And used special high grade materials.
Disadvantage - complicated control system: two speed sensors, two temp sensors.
Some info here:http://www.aisin-aw.co.jp/en/02products/02at/02fr/index.html
vovkus
Trail Scout
Postby vovkus » Sat Feb 06, 2010 11:54 pm
All electrical work is done!
Today I completed shift links, flushed ATF cooler. Only two parts need to be installed: left site exhaust and first crossmember.
I was not able to adjust shifter to the proper position. Now correct gear indication only on the instruments cluster, but not on the shifter.
This is 4L30E "emulator"
Load resistors instead of 4L30E solenoids
4L30E switch:
I use clutch cylinder hole for route wires trough firewall:
Transmission controller under the dashboard:
Shift link:
vovkus
Trail Scout
Users browsing this forum: 93trooperpooper and 20 guests
