Aaronmcvay84 wrote:I think with isuzus there is a more mature crowd that realizes the value of their hard work. They keep things.
Engines:
2.3/2.6
GM 2.8
GM 3.1
SOHC 3.2
DOHC 3.2
DOHC 3.5
swapped GM 3.4
swapped GM 3800 and/or 4.3
Diesels?
Transmissions:
MAU-5
4L30E
AR-5
BW T5
Axles:
8 bolt front
10-bolt front and rear
12-bolt (all 3 generations covered here)
D44 (both 97 and down and 98+ covered here)
Bodies:
1st Gen Trooper
2nd Gen Trooper
3rd Gen Trooper?
1st Gen Rodeo
2nd Gen Rodeo
1st Gen Amigo
2nd Gen Amigo
Pup
Vehicross
Axiom
Any foreign models?
What about a "MOD" section in each specific category allowing room for such content?
Tad wrote: Personally I think the 1st and 2nd gen rodeos are different
lorenzo816 wrote:
I still think we could have the sohc and dohc break down.
The intakes are different, the cams are well.. self explanatory, the timing is way different.
What were you thinking Tad on early vs. late? OBD1 vs OBD2?
You might could lump the dohc with the 3.5 and create one section for that.
thoughts?
JoeIsuzu wrote:There's so much bleed-over between bodies, generations, etc. that it's going to be difficult to push these topics into any kind of meaningful hierarchy.
Jack
-88- wrote:........Aside from all the cross over between models, & even generations.....Another thing we have to remember Isuzu is done in the U.S. & we're nearing a point even as used vehicles they're becoming irrelevant. New ground breaking info isn't coming everyday or once a week....it's once a month if we're lucky. Most posts are the same 10 topics repeated over & over.....To fill these new sections lots of thread sorting & moval will have to be done. An easier task if we're a little more broad in our "breakdown". I'm all for 'some' more organization.....Some; being the key word as we should stay mindful of where we've been, & where we're going. The boom is over leaving info chaoticly everywhere yes, but we're a niche & dwindling segment......or in other words I guess? Too little, too late? To go totally apey with splitting it down.
-88- wrote:.,..
Users browsing this forum: No registered users and 0 guests
