Well, this is Ruby's old stomping ground, so, I felt that I should place the first post on PlanetIsuzu. Of course. Asking price of $5720. (what a bargain!!!)
Trooper is located in Portland, Oregon. And, is capably driven throughout the US if you want to fly in and drive her away.
I'm selling my '91 Isuzu Trooper. Discover below what she's all about. Each item with the link "see notes and images" gives you more information about specific areas of the truck. Click on those links to reveal more.
(If you want to see this advert in HTML, there are more links and images there, click here: '91 Isuzu Trooper - Coil Sprung SAS - For Sale)
Here are some details on the vehicle and build:
- Engine, Transmission and Transfer Case
- GM v6 2.8L, with electronic fuel injection
this is a common GM engine and replacement parts are very economical
- 5 speed manual transmission
- Mileage 167,650, runs very strong with no engine oil leaks
- Custom heavy duty extended lines for auxillary oil cooler ($120)
- Tera Low 3.07 low range gear ($300)
- MSD 6AL Ignition Control ($240)
- MSD Blaster GM Coil & Tach Adapter ($70)
- Accel 8.8mm spark plug wires
- Transmission and transfer case vents end in engine bay for improved protection from water crossings
- Body & Interior
- 3" body lift ($170) including raising and armoring gas tank
- Custom heavy duty rocksliders welded to frame members
- Custom ¼" wall heavy duty bumper with two recovery points and winch mounting plate
- Dual fire extinguishers install ($60)
- Headliner is clean and in very good condition (1 small tear)
- Tinted windows (greatly reduce solar heat gain and damage)
- Rear has custom carpet fitted (padded and very clean)
- Rear has platform to mount 5' Hi-lift, and body has mount point for Hi-lift base
- Wheels & Tires
- Series 97, 15x8 steel wheels ($300)
includes wheel lock nuts and full-size spare
- Interco - TrXus MT Radial, 35"x12.50R15LT ($1,600)
4 tires 95% tread, and new spare tire with 100% tread, no tread/lug damage
- Centramatic wheel balancers ($200)[/i]
NO balancing weights needed, longer tire life, permanent solution to balancing
- Front Axle
- Solid axle swap (SAS) from stock independent front suspension (IFS)
- Jeep Wagoneer Dana 44 front axle ($150)
- Yukon Dana 44 5.38 gears ($250)
low miles on gears
- OX Locker, shifter & cable ($1000)
- Axle knuckles rotated for proper caster and pinion orientation
- Warn Premium manual hubs ($120)
- Custom flange for transfer case output ($90)
- Custom CV front driveshaft ($180)
- Procomp lift coil springs ($130)
- Currie ACOS spring adjusters with custom aluminum extensions ($220)
- TnT Customs Front axle truss with coil perches ($180)
- TnT Customs HD lower coil mount with shock stud ($130)
- TnT Customs long control arms ($550)
- Stainless steel brake lines ($45)
- Front disk brakes
- Rear Axle
- Isuzu Rodeo Dana 44 rear axle ($150)
low miles on gears
- Detroit Locker Dana 44 ($580)
- One-piece custom CV drive shaft ($220)
- TnT Customs U-bolt Eliminator ($150)
- Bluetorch Fabworks ¼" differential cover with truss extension ($80)
- Custom ¼" steel truss with traction bar links and differential skidplate
- Rear disk brakes
- Extras
- Tank skid plate armored with 11 gauge plate steel
- Enlarged power steering cooler installed
- 5 gallon air tank for on-board air ($80)
air line plumbing to vehicle rear with quick connects
- Thule Spare Me bike rack ($150)
custom bracket extension for mounting on 35" tires
- Sony stereo (with removeable faceplate) with 10 disc changer
- Speaker for CB radio
- New front windshield ($120)
- New exhaust and muffler with custom pipe placement ($150)
- Hi-Lift off-road jack base ($40)
- Pro Comp recovery tree strap
- 3, ¾" D-ring shackles ($30)
- Solid rear recovery point
- Notes
- Engine
At the time that this Trooper was made, GM owned 49% of Isuzu. Thus this hybrid was created. This is good, because the GM motor that is in this Trooper is reliable andparts are readily available and inexpensive. This engine runs strong and has virtually no fluid leaks. I recently moved from Colorado to Oregon, with the entire Trooper loaded to the gills with my stuff. The 900 mile drive was no problem and the engine felt stronger throughout the drive. Even fully loaded, lifted, and running 35"s, I probably averaged around 18mpg. And, of course this Trooper is perfect for the GM 3.4 swap. That was on my To-Do list also. This Trooper with a 3.4 would be one super trail rig. Lastly, the Trooper has passed the latest Oregon DEQ Vehicle Emissions Test.
- Steering/Handling
See any steering dampners on the linkage? No way! Steering dampeners are bandages on underlying steering design problems. From the very first drive after the SAS this Trooper has tracked straight and true. Never any death wobble. In fact if you feel the steering drift a little to the right, or to the left, it's probably a result of the crowned road surface. If the road is pan flat, the Trooper will go true straight with no hands on the steering wheel. I also believe that the Centramatic dynamic wheel balancers contribute to the smoothness of handling at highway speeds.
- Coil Sprung SAS Build
Many of the SAS build items I priced above. But, of course that is just a fraction of the cost that was expended to achieve this quality build. First, all the raw steel cost quite a lot. Also, none of those prices include fabrication and/or installation fees. Have you recently priced gear installations? Have you priced a full axle swap lately?! I spent hundreds of hours designing and fabbing my coil sprung SAS build. It was never easy, but I am proud of what I accomplished. I think that you would also be proud to place your unique signature with your choices that would refine this great Trooper.
- Engine
Certainly, if you have any questions feel free to message me. I will try and get to you as quickly as possible.
