2012 A Spacecab Odyssey
Postby DSUZU » Mon Sep 03, 2012 4:38 pm
Okay, I'm finally getting around to making a build thread for my 1989 Spacecab. I have already replaced the clutch, rebuilt the front suspension, done a valve job, replaced the missing rear seats and changed the front to a bench seat. The next thing I wil do is remove the alarm system. I hate alarm systems!
Pulled it down from under the dash. As I began to undo it, it began screaming for it's life. At this point, I named it "Hal"
Has thanked: 279 times
Have thanks: 940 times
Re: 2012 A Spacecab Odyssey
Postby DSUZU » Mon Sep 03, 2012 4:53 pm
Oh yeah, pictures of the truck[/attachment]
Next action will be doing the bodywork.
Postby squatch » Mon Sep 03, 2012 5:22 pm
Nice! I've been doing in and under dash work in mine for the last week or so. Makes the Trooper seem real easy to work on!
My builds are dead without the pics photobucket was holding hostage. The pics have been deleted and so have the links from my sig.
squatch
Has thanked: 71 times
Have thanks: 361 times
Postby shaggydoink » Mon Sep 03, 2012 7:16 pm
DSUZU wrote:Pulled it down from under the dash. As I began to undo it, it began screaming for it's life. At this point, I named it "Hal"
I hope you ran it over a few times, that looks like a mean Terminator sorta critter! LOL!!
Has thanked: 807 times
Have thanks: 412 times
Postby hessmess » Mon Sep 03, 2012 8:11 pm
Glad to see another thread on the SpaceCab! I will be watching.
88 Trooper (recycled)
https://forum.planetisuzoo.com/viewtopi ... 15&t=81567
89 Pup LS Space Cab, 4X4, 2.25 cat back exhaust system, LSD, Jerry Cam, otherwise stock, painted Oct 2018.
https://forum.planetisuzoo.com/viewtopic.php?t=55081
hessmess
Have thanks: 166 times
Postby IsZeus » Wed Sep 19, 2012 6:26 am
I've been looking for a seat option for my little space cab. What did you use to fit? Did you have to make custom seat brackets?
IsZeus
Postby DSUZU » Wed Sep 19, 2012 7:52 pm
Just removed the stock bucket seats and bolted the stock pickup bench seat in. The only problem is the regular bench seat from a pickup has no cover on the back of the seat, just the springs and foam. If you could luck out and find a front bench seat from an early Rodeo, it will have back upholstry. The Rodeo bench seat has 2 extra bolts that keep it from folding, just remove them and it will fold. Sad fact is that I had an excellent Rodeo bench seat stashed up in my attic until about 2 months before I bought the Spacecab. Dennis
Postby DSUZU » Sun Oct 07, 2012 6:07 pm
I finally got a little done to the Spacer this weekend. First I swapped the larger diameter torsion bars from the V-6 Rodeo in to the Spacer. I forgot to take pictures of that. For the next part, it's gotta get a little worse before it gets better. I decided to swap out as much of the of the burgundy Rodeo interior as I could and use fabric paint / dye to do the rest. I think the charcoal gray / silver with the burgundy interior will look petty sharp. I've seen plenty of Chevy Silverados and Fords with red or burgundy interiors and I think it's different.
For anyone planning to pull the entire dash from a first gen Rodeo or pickup, there are 3 electrical plugs on the drivers kick panel behind the ECM. You will also have to unhook all 3 of the HVAC cables
I added a picture of the dashless interior after cleaning and painting the brace bar.
Postby shaggydoink » Mon Oct 08, 2012 9:52 am
Wow, very cool Dennis - can't wait to see the refurb!!
Postby DSUZU » Sat Nov 10, 2012 8:55 pm
While I haven't posted anything in a while, I have been doing a little here and there. I took the burgundy dash from the donor Rodeo, and decided to clean it up and repaint it due to a bit of fading on the top. First I used a quart of SEM interior paint (70.00). I had chosen a red color, but after spraying the dash, I decided it was too far off from the original burgundy, and I was very disappointed that it took almost the entire quart to do just the dash. I estimate it would have easily taken another gallon to do the rest of the interior in red, and I didn't want to sink that much money into it. I bought a couple of rattle cans of Duplicolor burgundy, and resprayed the dash. Bummer, this time it came out more of a pinkish magenta color. I spent the next couple of weeks trying to find Rustoleum vinyl spray in a burgundy color. I ended up ordering a can off ebay from Summit Racing. It was reasonably priced and the burgundy color perfectly matches the original Isuzu burgundy. I sprayed a section of one part, and after drying, you can't tell what was painted and what was original. I will oreder about 4 more cans to redo the dash.
In the mean time, I have been workng on dying the headliner. I used powered RIT dye, and sprayed it from my siphon spray gun. After about 3 applications from the first batch, my headliner went from dingy gray, to dingy pink. I mixed another batch and added 2 teaspoons of black dye to darken it up. Now it was a darker pink. I bought the RIT crimson dye in liquid form and mixed it with about 16 ounces of warm water to 1/2 bottle of dye. Now we're starting to look more purpleish. After a second applicaton, it finally has a good burgundy appearance. I probably won't get the dash done and back in until after Thanksgiving
Postby bradzuzu » Sat Nov 10, 2012 10:24 pm
Good job Denis , be a pain in the rumpus to get that color change.. That's a nice clean pu , I really like the lay out of my 91 amigo..
Has thanked: 220 times
Have thanks: 390 times
Postby shaggydoink » Sun Nov 11, 2012 8:54 am
Wow, I'm impressed - amazing job Dennis! I also like the popup camper in the background, another item on my wish list. :)
Postby hessmess » Sun Nov 11, 2012 11:37 am
I had a popup camper once, I nearly froze my butt off during one deer season. It was October and in the teens during the night. It snowed, I ran out of propane, the deer had left. I blamed it on the trailer! So I sold it to my kids, they used it and sold it to the other kids and they still have it in Colorado. And I have a hard sided travel trailer now. Still haven't found the big buck but can't blame the trailer!
hessmess
Postby DSUZU » Sun Nov 11, 2012 1:26 pm
And this time next week, I'll be setting up camp in that pop up. We've had that one for about 13 years now, It spent a couple of thse years in storage and had gotten wet and some wood rot. Afew years ago, I was going to sell it for salvage or fix up, and the buyer backed out at the last minute, so I got mad and basically rebuilt it myself. We've had some realy good times with it. Wife just had me looking at A-liners yesterday, but they are far from our budget, even used ones. While I'm looking forward to camping, I'm also looking forward to getting back, and getting back full steam on my pickup too. Dennis
Postby DSUZU » Sun Nov 11, 2012 5:53 pm
One more shot that shows somewhat how it will look. The dash, as seen in this shot will have to come back out to be repainted. Once I've already done it, taking it out again will not be that bg of a deal. The seat and carpet will be redone in burgundy as well. The gray insert in the drivers door panel is the original plaid insert from the Spacer door panel. Once the Rodeo door handle is removed, the pickup panel fits right in. I lean towards keeping the gray plaid trim in gray, which would include the rear seat pad. I saved the panels from the original front seats and will probably incorporate them into a reupholstry of the front bench seat when all else is done.
Postby shaggydoink » Sun Nov 11, 2012 7:13 pm
DSUZU wrote:I lean towards keeping the gray plaid trim in gray, which would include the rear seat pad.
YES! <== Jonathan's vote. :)
Postby hessmess » Sun Nov 11, 2012 7:15 pm
I gotta say that I do like the grey insert!
hessmess
Postby bradzuzu » Sun Nov 11, 2012 9:33 pm
That's looks good like that !! What's your plans for the truck when your done ??
Postby squatch » Sun Nov 11, 2012 9:41 pm
Looking good Dennis! I don't envy you on the headliner dye job!
squatch
Postby DSUZU » Mon Nov 12, 2012 7:57 am
bradzuzu wrote:That's looks good like that !! What's your plans for the truck when your done ??
Drive it, enjoy it, get back to my aviation archaeology hobby, where it wil come in handy. I might even finish the deck :D Dennis
Postby bradzuzu » Mon Nov 12, 2012 11:40 am
Ahh projects that lead to projects , that lead to other projects !! I know that feeling.. I have rc planes in my attic , haven't flown them for years..
Postby DSUZU » Mon Nov 12, 2012 2:07 pm
I used to have a REAL one in my garage at the old house. After the second child came along, and I hadn't done anything to it for a couple of years, it became time to go. Sold it and put the money towards buying a bigger house. I may get back to work on my ATV someday too.
Postby shaggydoink » Mon Nov 12, 2012 2:36 pm
DSUZU wrote:I may get back to work on my ATV someday too.
OMG, that is so cool I can hardly contain myself!!!!!!!!!!! What year is it? And where do I get one?!! LOL!!!
Postby DSUZU » Mon Nov 12, 2012 4:59 pm
It's a COOT ATV. They were made from the mid '60s to the early '80s. It's powered by a 12 HP air cooled Tecumseh lawnmower type engine. It has full time true all 4 wheel drive. It's amphibious, and there is an optional 9" propeller that drives off the rear axle gearbox (there are no differentials, just a final drive of about 14:1. The best part, it is "articulated". It pivots in the center allowing the front and rea hulls each to twist about 45 degrees off center, yes, up to about 90 degrees opposite each other. Mine has also been converted to 4 wheel steering. This was an option that was offered, and not toodifficut to make a conversion if one could scrounge up the extra steering parts. More information at Cootworld http://cootworld.freeforums.org/ Yes, these are as addictive as Isuzus. I'll have to add a thread on "other vehicles" :D Dennis
Postby bradzuzu » Mon Nov 12, 2012 6:23 pm
That is a cool little machine !! Does it have much articulation ??
Users browsing this forum: No registered users and 18 guests
