2002 trooper won't go into gear.
Postby Bdemaree » Fri Jun 26, 2020 8:52 pm
My roommate has a 2002 trooper she says she'll sell me for super cheap if i can fix it. She said it just overheats but her mechanic said it'd be $10,000 to replace the engine. I had the thing running for an hour. After filling the coolant it wasn't overheating and the engine sounds fine. The problem i ran into was that it wouldn't go into gear to test drive it. When i try to shift nothing happens. The engine doesn't even lag like it's trying to go into gear but just slipping. It won't even shift into neutral so i can push it. Looked online but so far the only info i can find is about the rodeo. Web says it could be the shifter cable. All the parts stores say their computer says that's not a part they carry for the trooper, can't tell me if the trooper even uses a cable.
Please help, I need a vehicle and this could be the easiest option.
2002, isuzu trooper automatic transmission. Let me know whatever other specs are needed.
Bdemaree
Re: 2002 trooper won't go into gear.
Postby Buster28 » Tue Jun 30, 2020 5:26 am
The Rod #29 operates the Lever #72 that rotates the Shaft # 9 that operates Selector # 23 that operates the transmission manual valve and Parking Pawl that locks the tail shaft in Park. Note that item #9 #23 #40(A) and item #13 are inside the transmission case.
Look under the vehicle at the left side of the transmission case and determine if Lever #72 moves when the Console Shift Lever is moved from P to N.
Click on image to expand,
Have thanks: 1183 times
Postby catbrown357 » Wed Jul 01, 2020 1:39 pm
$10K to replace the engine?! That mechanic is a con artist.
2001 Isuzu Trooper LS 4X4, 3" OME lift, Skyjacker shocks, TB crank, 265/75 16 AT tires, Warn manual hubs, Heavy duty tie rods, the list goes on...
2011 Toyota 4Runner Limited 4X4, mostly stock.
2017 BMW GS Adventure, the best bike ever!
catbrown357
Trail Rider
Has thanked: 16 times
Have thanks: 20 times
Postby Enemigo » Wed Jul 01, 2020 1:55 pm
catbrown357 wrote:$10K to replace the engine?! That mechanic is a con artist.
My neighbor paid that to rebuild an engine in an Explorer. Unfortunately, there are more than a few mechanics out there like that.
Return to Drivetrain Problems
Users browsing this forum: No registered users and 31 guests
