Trooper II front bumper build
Postby NWTroop2 » Mon Nov 11, 2019 1:14 am
Been building a bumper for the trooper this weekend. Last thing I’ve been working on is a hoop for it. Can’t decide if I like the hoop. What do you guys think?
87 Trooper II
NWTroop2
Re: Trooper II front bumper build
Postby gruff54 » Mon Nov 11, 2019 7:50 am
Can't help you with your hoop question, not a big fan of hoops. But the bumper is NICE! May have to copy it, if you don't mind. Were you planning on making drawings or plans available?
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 43 times
Have thanks: 80 times
Postby mudoilngears » Mon Nov 11, 2019 10:30 am
NWTroop2 wrote:Been building a bumper for the trooper this weekend. Last thing I’ve been working on is a hoop for it. Can’t decide if I like the hoop. What do you guys think?
Really nice job! I personally would skip the stinger, or at least use round tube, but that's just my opinion, you gotta build it the way you like it.
Build in progress...
mudoilngears
Has thanked: 17 times
Have thanks: 157 times
Postby NWTroop2 » Mon Nov 11, 2019 12:41 pm
I could see about drawing up plans. I just bought a piece of 3”x6” box tube and marked it up and started cutting, welding, and grinding. I was really happy with it until I put the hoop on it. I don’t have a pipe bender so I miter cut the square tube with a portable band saw the best I could. I’m not sure if I’d like the hoop with round tube either though. Thanks for the opinions, and the compliments! That was a ton of work. First thing I’ve ever fabbed up other than an occasional bracket! Think I’ll end up chopping the hoop off. It just has a few tack welds holding it in place now.
87 Trooper II
NWTroop2
Postby gruff54 » Mon Nov 11, 2019 1:34 pm
NWTroop2 wrote: I just bought a piece of 3”x6” box tube and marked it up and started cutting, welding, and grinding.
OK, I see know. Did you relief cut it on the backside just outboard of the frame rails and pulled the ends back a little, then tapered them up to the outside? Pretty simple, if that's how you did it. At first glance I thought you'd welded together a bunch flat plates. Again, nice!
Mike
gruff54
Postby NWTroop2 » Mon Nov 11, 2019 9:54 pm
Yeah just a bunch of relief cuts to bend it to the shape I wanted and keep the original rounded edges. I should have taken more pictures but I’m not one for stopping before/after each step. Here’s what I got for pictures of the process.
I also trimmed the front fenders a bit. They hung down below the bumper.
Sorry the pictures are out of order. Still trying to get that figured out.
87 Trooper II
NWTroop2
Postby NWTroop2 » Mon Nov 11, 2019 10:03 pm
More...
87 Trooper II
NWTroop2
Postby gruff54 » Tue Nov 12, 2019 6:59 am
I don't see a "Thanks" button any more? So, Thanks!
Mike
gruff54
Postby NWTroop2 » Fri Nov 15, 2019 1:37 am
Here’s some more pictures of the bumper build. Think I’m going to throw a harbor freight winch on it this weekend. I’ll probably finish it up with black raptor liner.
87 Trooper II
NWTroop2
Postby NWTroop2 » Sun Nov 17, 2019 3:45 am
Picked up a Badlands 9000lb winch from Harbor Freight today. I thought I was going to mount it on top of the bumper but decided it wouldn’t look so great that way. Anyways, I pulled the bumper and took some measurements and went after it again with the angle grinder and welder. Here’s what I came up with.
It was a whole bunch more work, but I think it turned out good! Still need to mount the controller on the winch and get it fitted up and fully assembled.
Instead of saying “I” , I should be saying we. Myself and a friend of mine have been dreaming this up and working our butts off on it. It has been a good time though!
87 Trooper II
NWTroop2
Postby turnerd » Tue Nov 19, 2019 3:52 pm
Do you happen to have the original bumper?
1988 Trooper II LS 2.6L automatic
turnerd
Has a Trail Truck
Postby paulevans76 » Thu Nov 21, 2019 4:09 pm
Looking great.
MUA5 w/ 3.07's & fixed yoke
Warn XD9000 w/ synthetic rope, rear swing out tire carrier
1.5" body lift and fuel tank lift
1994 Samurai - 1.3 FI - topless mini wheeler in the works
Has thanked: 219 times
Have thanks: 180 times
Postby NWTroop2 » Sat Nov 23, 2019 9:31 pm
Day of prep, primer, and paint (raptor liner).
87 Trooper II
NWTroop2
Postby NWTroop2 » Sun Nov 24, 2019 2:14 am
Front and rear bumpers all done. They turned out pretty good! Raptor Liner is good stuff, it sprayed really easily.
I’ll put up pictures of the rear bumper when I have it mounted.
87 Trooper II
NWTroop2
Postby NWTroop2 » Sun Nov 24, 2019 7:27 pm
Back bumper mounted up.
87 Trooper II
NWTroop2
Postby paulevans76 » Mon Nov 25, 2019 12:29 pm
Nice work.
Postby gruff54 » Mon Nov 25, 2019 1:35 pm
Nice! Got a side shot of the rear bumper? How did you apply the Raptor Liner?
Mike
gruff54
Postby NWTroop2 » Tue Nov 26, 2019 3:21 pm
gruff54 wrote:Nice! Got a side shot of the rear bumper? How did you apply the Raptor Liner?
Mike
I purchased a kit off of Amazon that came with a “free” gun to spray it with. It can be applied with a roller too. I think you’d get a much smoother texture with a roller but I decided to spray to cover up some imperfections. It really did a great job at that.
I don’t have a side shot of the rear bumper right now. I’m out of town for Thanksgiving. I’ll put up side shots of both bumpers. I had to move the front bumper out a bit more to make room for the winch.
It was a fun project! I will be using Raptor Liner on the whole exterior and the floor.
More to come.....
87 Trooper II
NWTroop2
Postby gruff54 » Tue Nov 26, 2019 5:18 pm
Roller texture smoother than sprayed? I'd think it would be the other way 'round. Just went back and looked at your close-up pic. I guess the material sorta dries before it hits the surface and doesn't flow? Got a link to the kit you purchased?
Mike
For this post the author gruff54 was thanked by:
kewpie79
gruff54
Postby zzzmick » Tue Nov 26, 2019 6:40 pm
Awesome job there, it looks beautiful! I wish I had a shop. I am looking for a winch bumper with the headlight guards (don't like the hoops) and can't find them for less than $1000.00
I LOVE my Troopers! The only complaint is that the ashtray is too small and when I shift into 2nd, it hits my beer.
1986 Trooper 4 door, 5 speed manual with Weber conversion. In shop SINCE 4/24/19 for rebuilt 2.6 install and paint job.
1989 Trooper 4 door, 5 speed manual. 4ZE1 with Weber 38 and round LED headlight conversion,
2" lift and pacesetter headers.
zzzmick
Postby itsmehb » Tue Nov 26, 2019 9:12 pm
Awesome job on both bumpers.
Has thanked: 144 times
Have thanks: 294 times
Postby shaggydoink » Sun Dec 01, 2019 11:17 am
You've got incredible skills, both bumpers look amazing! :thumbup:
Has thanked: 807 times
Have thanks: 411 times
Postby NWTroop2 » Tue Dec 10, 2019 12:49 pm
Thank you for the kind words! I’m in the process of prepping to paint the whole truck with Raptor Liner right now.
87 Trooper II
NWTroop2
Postby NWTroop2 » Fri May 22, 2020 12:15 am
Here it is pretty much all done!
87 Trooper II
NWTroop2
Postby shaggydoink » Sat May 23, 2020 10:35 am
While I can appreciate the larger, more prominent-style bumpers, I've always been really drawn to the more minimalist-style like this. They look absolutely incredible, I hope you're proud of your work!
Users browsing this forum: No registered users and 27 guests
