Hi there. I replaced both the driver and passenger side CV's last week (geez were those brackets a pain on the driver's side) and it appears there is a fairly significant gear oil leak that has developed. Oddly enough, it's complete dry along both the differential bracket, and on the CV (replaced the axel seal as well). The leak appears to be near the vaccum lines that run on the inside of the framerail on the driver's side. My main question is, is there any line up higher than the differential that has gear fluid? I'm a bit worried I may have damaged a line during the CV removal. Any help would be appreciated, as my efforts to clean and inspect have been fruitless so far.
