Tantz wrote:Thanks @ED
Question: if it is only the timing cover gasket that's ultimately being replaced, does $425 seem right? Is getting to the gasket to replace it time consuming, say 1.5 hours each way, in to it, then to put it back together?
I'm trying to assess how he's quoting $425 for gasket replacement only.
Granted, that will also include/involve oil change, gallon of coolant, water pump gasket, new seals...
Thanks! TANTZ
Doesn't seem outrageously high. Shop labor up here in the PNW is running $90-$120/hr or more. That's why so many of us work on our own rigs. Understand that not everyone has the tools or skills to do so. In that case you've got to find a good reputable shop that knows what they're doing.
I'm sure it'd take me a good weekend to do that job, but I'm not as fast as I used to be! And most mechanics should have plenty of experience working on older pushrod GM engines. He'll have to unto the serpentine belt, pull the fan and fan shroud, drain the antifreeze, disconnect radiator hoses and heater hoses, pull the radiator, remove the water pump, pull the harmonic balancer (takes a special tool for that), remove all the timing cover bolts, then pull the timing cover. Clean the timing cover, scrape old gasket material off all block and cover surfaces, tap out the old crank seal in the timing cover, install a new seal.
Oh, yeah, did I forget he'll need to make sure the crankshaft is at Top Dead Center with #1 cylinder on the compression stroke. So he'll have to use a remote starter switch or have an assistant bump the engine over until the crankshaft is lined-up. Or put a wrench on the crankshaft bolt. This is an important step that has to do with alignment of the new timing set.
With the timing cover removed, he'll have to undo the bolt holding the cam gear on the camshaft, and pull the cam gear and timing chain. If he's lucky the crankshaft gear might slip off, but it'll probably have a tight, press fit so he'll have to use a puller to remove the gear. The the one easy part, the 2 bolts that hold down the timing damper! With the cam and crank marks properly aligned, the timing set is installed.
Then comes the rest of the reassembly. He'll need to carefully apply Permatex Ultra-Grey RTV or equivalent on the bottom of the timing cover where it contacts the oil pan gasket. Since he's not pulling the engine or dropping the front differential, the oil pan isn't going to be completely removed. So the area in the front where the timing cover sits on the old gasket must be thoroughly degreased so the RTV sealer will stick and cure properly. Otherwise you'll get a nasty leak at the cover/pan gasket interface.
After the timing cover, the rest of it is a piece of cake, just reinstall in order of disassembly! Sounds easy, right? Well, it ain't rocket science, but it all has to go together in the correct sequence, with the correct sealers and everything adjusted when you're done.
That's a lot of wrenching involved to replace a "two-bit" gasket! Fortunately the only special tools needed are the harmonic balancer puller/installer and a set of Torx bits for the timing cover/water pump bolts. You can rent special tools, BTW, from your local Autozone. You make a full-price deposit for the special tool, and you get your $$$ refunded in full when you return the tool.
He'll also probably want to check the engine timing, since the sloppy cam chain will affect that. Or you can learn how to do that, from this forum!
I'd highly recommend learning to do at least basic maint like oil changes, spark plugs, filters, hoses, belt, etc. You'll save so many $$ if you can do it yourself, and you have all the resources here at the Planet to guide you to a successful repair. Our 30-year+ old rigs do need a bit of maint now and then! It's still better than car payments, and if you can do some things yourself, it's like you're paying yourself $100/hr to do the work.
A factory service manual is a valuable resource. Some copies are sold on the 'net. Aftermarket manuals like Chiltons are just about worthless. Sometimes the Haynes manuals have decent info in them. Someone here might have a scanned version of the factory manual. I can give you a link to the '88 manual which is for a 2.6 4-cyl, but outside the engine and emission controls, everything else is virtually the same as your V6 rig.
I also found this Factory V6 "Supplement" manual for an '89 on eBay, it ain't cheap, but between the info the in '88 online manual, and this engine supplement, you'd have all the info you'd likely ever need to do any repair on the rig. These don't come up very often, either!
https://www.ebay.com/itm/1989-Isuzu-Tro ... 4855025482Cheers........ed
