PlanetIsuzoo.com (Isuzu SUV Club)
Welcome to the Planetisuzoo Forums!
It is currently Tue Oct 20, 2020 1:49 pm
Post new topic Reply to topic  [ 4 posts ]
Author Message
 Post subject: maf sensor
PostPosted: Sat Oct 17, 2020 8:49 pm
Offline
I looked through the forums and didn't see much on maf sensors. I have been trying to figure out what is wrong with truck since I was able to get back to it after surgery and it doesn't make sense. Replaced fuel pump again (Edelbock external), installed new relay, circuit breaker and reset the ecu. Starts and idles without the maf sensor plugged in but as soon as I plug the maf sensor in it dies. Also while it's idling I push on the throttle just a little bit and it kills it. What am I missing here? 95 pickup 2.3l
_________________
Thumper
 Profile
 Post subject: Re: maf sensor
PostPosted: Sun Oct 18, 2020 1:11 pm
Offline
The MAF is the Mass Air Flow sensor
The MAP is the Manifold Absolute Pressure sensor
I am looking a 95 2.3L engine schematic and I see the MAP sensor connection to the ECM but there is no MAF sensor. Does your engine have both a MAP and MAF sensor?
_________________
 Profile
PostPosted: Sun Oct 18, 2020 3:29 pm
Offline
I know on my 95 pickup it has both a MAP and a MAF sensor. And I have the opposite behavior for what its worth, if I unplug the MAF it will hesitate and die.
_________________
1995 Isuzu Pickup 4WD
2016 Fiesta ST
2017 Jeep Renegade
 Profile
PostPosted: Mon Oct 19, 2020 4:30 am
Offline
So I just figured out that the schematic I am looking at is for a 2.3L carburetor engine and the 95 2WD pickup with 2.3L was upgraded to a fuel injected engine.
At startup, the MAP measures the barometric pressure so the initial air/fuel ratio is calculated correctly for the elevation of the truck. The MAF is measuring the airflow into the engine so the ECM can adjust the fuel injector duration to produce the correct air/fuel ratio.
There is very little air flow into the engine at idle so the engine will start with the MAF disconnected, but as soon as the throttle is opened there is too much air for the amount of fuel being delivered so the engine stalls.
_________________
 Profile
Display posts from previous:  Sort by
Users browsing this forum: Eabyrd1977, namealreadyinuse and 12 guests
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
Powered by phpBB® Forum Software © phpBB Group
VigLink badge
