PlanetIsuzoo.com (Isuzu SUV Club)
Welcome to the Planetisuzoo Forums!
It is currently Wed Oct 21, 2020 8:31 am
Post new topic Reply to topic  [ 6 posts ]
Author Message
PostPosted: Thu Mar 12, 2015 3:31 pm
Offline
I went to look up some info from the alternator upgrade article that used to be on the main site and found myself getting redirected right into the forums. Previously www.planetisuzu.com would take you to the home page with access to the wiki and articles, as well as the forums. Is the main site gone, or just getting some work done?
_________________
-Tim
1995 Trooper SOHC 5 Spd, daily driver.
97 camshaft swap
Multec 2/Delphi 98-02 Isuzu injector swap
drilled out exhaust restrictors
285/75-16 Kenda Klever M/T on Snowflakes
95 Trooper Build Thread
1986 Trooper LWB 2 Door - Impulse 2.3L high compression motor, 31x10.5 tires
1977 and 1979 Chevy LUVs - a 2WD and a 4WD matched set, projects in the works
 Profile
PostPosted: Thu Mar 12, 2015 3:52 pm
Offline
Direct links to the articles are also broken.
For example:
https://www.planetisuzoo.com/articles.ht ... Conversion
Gets brokenly redirected to:
https://forum.planetisuzoo.comarticles.h ... Conversion
So whatever is doing the redirection is pretty broken.
Edit: Until this is resolved, you can use the Archive.org pull of the articles @ https://web.archive.org/web/20130117111 ... es-all.htm
Edit 2: wiki.planetisuzoo.com is also going through the broken redirection: https://forum.planetisuzoo.comindex.php/Rodeos
_________________
1997 UCS7VF (Rodeo / Passport / Frontera)
Wry Wench build thread
3-inch Calmini Lift Kit, Indy4x 1.5-inch Leaf Lift
 Profile
PostPosted: Thu Mar 12, 2015 9:04 pm
Offline
Site Admin
They will be back soon. We had to make a change to the server and it broke some of the old code. Thanks for noticing the redirection error though.
-Tad
_________________
[email protected]
1999 Rodeo - rebuilt DD
 Profile
PostPosted: Fri Mar 13, 2015 9:45 am
Offline
Has a Trail Truck
Tad - will we be able to post pictures on the wiki after the fix? I'm trying to update an article in the wiki and I'm getting this error when I try to upload a photo:
Could not create directory "mwstore://local-backend/local-public".
Shaggy replied and said that the permissions on the upload directory are not set correctly.
Thanks,
Tom
 Profile
PostPosted: Fri Mar 13, 2015 9:40 pm
Offline
Site Admin
That's the plan.
-Tad
_________________
[email protected]
 Profile
PostPosted: Sat Mar 19, 2016 12:14 am
Offline
Has a Trail Truck
Sorry to resurrect a year old thread, but is the plan still to have the old main site, articles and wiki back?
 Profile
Display posts from previous:  Sort by
Users browsing this forum: joens and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Jump to:
Powered by phpBB® Forum Software © phpBB Group
VigLink badge
