PM not working?
PostPosted: Mon Oct 14, 2019 8:21 am
by sanramonrover
Has anyone else noticed if the PM feature does or does not work since the big format problem? My PMs get stuck in the OUTBOX and never get sent.
You Too?
Re: PM not working?
PostPosted: Mon Oct 14, 2019 8:38 am
by kmcmilla
Yes, I have the same problem. PM sitting in the outbox and will not send.
Re: PM not working?
PostPosted: Mon Oct 14, 2019 10:24 am
by mudoilngears
sanramonrover wrote:Has anyone else noticed if the PM feature does or does not work since the big format problem? My PMs get stuck in the OUTBOX and never get sent.
You Too?
Hi Fred, something is definitely going on, I got you PM's, but apparently my response to the first one you sent, never made it. I'll respond via email.
Re: PM not working?
PostPosted: Mon Oct 14, 2019 12:23 pm
by JoeIsuzu
That's working exactly as designed. If nobody reads your PM, it stays in the Outbox.
Jack
Re: PM not working?
PostPosted: Mon Oct 14, 2019 12:24 pm
by mudoilngears
JoeIsuzu wrote:That's working exactly as designed. If nobody reads your PM, it stays in the Outbox.
Jack
Right, but I did send one that apparently didn't make it.
Re: PM not working?
PostPosted: Mon Oct 14, 2019 3:58 pm
by JoeIsuzu
Jack
There are mailbox quotas. Maybe the recipient is over quota? If so, he can't retrieve the PM, and it will stay in your outbox.
Jack
Re: PM not working?
PostPosted: Mon Oct 14, 2019 8:41 pm
by sanramonrover
My inbox is not full - has only about 6 messages in it. I suspect something else happening.
Re: PM not working?
PostPosted: Tue Oct 15, 2019 7:04 am
by JoeIsuzu
sanramonrover wrote:My inbox is not full - has only about 6 messages in it. I suspect something else happening.
Not yours. His.
But by design, it stays in your outbox until the recipient reads it. If you remove it from your outbox, the recipient will never get it.
Jack
