Manual Locking Hubs - - What Brand?
Postby bamakojon » Wed May 05, 2021 11:18 am
So I am going to be replacing my CVs on my '98 Trooper and I'm thinking about treating myself to some manual hubs while I've got everything apart.
So my question is what brand should I go with? I know Aisin is OE and amazing quality, but they're expensive. I've heard good things about Superwinch, and I like the quarter-turn engagement feature and the price. At about the same price point are the Rugged Ridge ones. I like that they look more like the Aisins, but I haven't heard much about them before. Any advice would be great! Thanks!
"Stupid it isn't if work it does." - Yoda
bamakojon
Re: Manual Locking Hubs - - What Brand?
Postby Jake.Werecat » Wed May 05, 2021 1:25 pm
I would go for Aisin, undoubtedly. They are very durable,very seldom make any issues and almost do not wear throughout the years. I have them on both my rigs, Isuzu and Toyota. Try some local Pick&Pull or hunt a good deal on e-bay. They sometimes come pretty cheap second hand.
I heard good things about Superwinch, though they are very rare in Europe, so I have never used them.
As for Rugged Ridge, this brand is called AVM in Europe. They are quite OK, but I personally dislike the design, especially those big silver cups, fastened with those tiny torx/hex screws.
I have heard about a few ones broken by friends of mine, but not too many and not too often.
Isuzu Trooper 3.1D 1997
Toyota 4-Runner 3.0V6 1991
Jake.Werecat
Postby bamakojon » Wed May 05, 2021 2:36 pm
Jake.Werecat wrote:As for Rugged Ridge, this brand is called AVM in Europe. They are quite OK, but I personally dislike the design, especially those big silver cups, fastened with those tiny torx/hex screws.
I was confused at first when you said you don't like the design of the rugged ridge ones, so I Googled it and I absolutely agree, they don't look very nice! The ones I'm looking at are for sale on independent4x and they're reproductions of the Aisin ones made by rugged ridge. Here's a link to them! I really like how these ones look! I might go with them since they're less than half the price of the Aisins and let y'all know.
https://www.independent4x.com/NEW-Isuzu ... p_453.html
bamakojon
Postby Enemigo » Thu May 06, 2021 12:28 am
I bought the Superwinch brand, asks while they haven't failed me or left me stranded or anything, I hate them. The T-20 screws that hold the dial plate on are terrible. I'll post more later, when I'm not in my driveway spending an hour each side trying to get the damn things off to replace with the Aisins I found at the junk yard a few weeks ago.
Have thanks: 30 times
Postby Jake.Werecat » Thu May 06, 2021 7:23 am
@Enemigo: Same with standard AVM vel Rugged Ridge. Those tiny screws are aweful!
@bamakojon: Okk! I see what you mean. I did not know that there are copies of Aisins made by RR. Interesting.
Jake.Werecat
Postby Enemigo » Thu May 06, 2021 5:04 pm
Got my Superwinches off!
Pros to Aisin:
-They stick out less
-The hardware appears more durable, although I did over torque one of the 10mm bolts and broke it last night. I was tired and decided to fix it later. That was probably a mistake since I used orange Loctite on it.
Pros to SuperWinch:
-They are more skinny than the Aisin hubs which allows the use of certain wheels.
Cons to SuperWinch:
-The T-15 star head screws are a pain. They will strip out T-15 bits every time. i found that a T-20 fits if I tap them in with a hammer. Then nothing strips. Maybe I just got the size wrong and all my problems have been caused by myself. Entirely possible.
-The aluminum finish rapidly fades and looks terrible.
SuperWinch installed with 1.5" spacers and Axiom wheels.
Aisin installed with 1.5" spacers and Axiom Wheels.
Postby bamakojon » Thu May 06, 2021 9:34 pm
Thanks for the write up! The Aisins do look nicer for sure. And that's good to know about the T15 screws. Did you have to remove the screws often, and why?
bamakojon
Postby Enemigo » Fri May 07, 2021 1:02 am
The Allen bolts would be loose, and I'd have to remove to tighten them. Definitely recommend loctite. I didn't have to pull them often, usually for maintenance, but every time it was a huge hassle.
Postby 93trooperpooper » Fri May 07, 2021 8:10 am
i have ebay aisin knock-off hubs on my trooper. i recommend longer bolts, and a touch of loc-tite on the threads of those bolts, that holds the cap to the body. and use an inch-pound tq wrench, or your hands if your great at guessing the proper tightness...the threads are soft material in the body, and the provided bolts dont go in far enough....
put almost 100,xxx km on them, only had 1 issue with the pass side not wanting to lock / unlock properly....the spring and clip inside became dislodged, jamming it up. a quick removal, clean , repair and lube , and its working good again...
will drive these until they quit and move onto something else.
parts from JERRY LEMOND.
93trooperpooper
Have thanks: 27 times
Postby Enemigo » Fri May 07, 2021 11:35 am
I've found this video to be excellent concerning the Aisin hubs. It exactly explains the issue that 93trooperpooper ran into where the hub binds up as well.
https://www.youtube.com/watch?v=W78RkF1 ... heeliePete
Postby Jake.Werecat » Fri May 07, 2021 5:05 pm
I just rebuilt mine a few months ago, some rust removal here and there, ultrasonic clean, new gaskets, new x-rings, lubrication. Now they engage and disengage perfectly!
A few pics:
I often use thred-locker here and there, but as for the Aisin hubs I've never done it, I just torque to bolts with proper ft·lb, and they never came loose or strip the threads.
Jake.Werecat
Postby Enemigo » Fri May 07, 2021 5:20 pm
Lorenzo sent me a link to a guy with a rebuild kit and it came with the star gasket AND new spring and detent ball. Unfortunately the gasket for the hub to wheel was the wrong size, so I just used grey RTV.
Postby Jake.Werecat » Fri May 07, 2021 5:59 pm
Those aisin body to wheel hub gaskets seemed absolutely impossible to find, so I draw my own in AutoCAD and had them plotter-cut for me. These are the dimension if ya interested:
I can also provide *.dwg/*.dxf file.
Jake.Werecat
Postby Enemigo » Fri May 07, 2021 6:48 pm
Oh thanks. This thread is in the way to being a sticky.
Postby bamakojon » Sat May 08, 2021 12:38 am
I found an older thread (2013) that seems to answer the question of whether or not the Rugged Ridge made Aisin reproduction hubs are worth it, and the answer seems to be "No." you can view that thread here: https://www.planetisuzoo.com/viewtopic.php?f=22&t=72647
I guess I'll search around for some used Aisins.
Does anyone have experience with the Warn hubs? They're even more expensive than new Aisins, and I have a hard time believing they're any better.
bamakojon
Postby Enemigo » Sat May 08, 2021 1:58 am
Lorenzo has the Ruged Ridge I think. Full disclosure, I don't go to the junk yard that often, but it probably took me five years to find a pair in the yard.
Postby bamakojon » Sat May 08, 2021 7:09 pm
Enemigo wrote:Full disclosure, I don't go to the junk yard that often, but it probably took me five years to find a pair in the yard.
Yeesh, that's a long time. I don't go very often either, and the junkyards around me don't usually have a ton of isuzu vehicles... I might just have to break down and buy a set new. Is there anywhere in particular that anyone knows of that has the best deals on new Aisin hubs?
bamakojon
Postby bamakojon » Thu May 13, 2021 3:06 pm
Okay, I have another related question if anyone would be so kind (and knowledgeable) as to answer. What is the actual part number for the Aisin hubs for Troopers? In doing research on this, they all seem to have a part code like AISIN FHT-019, or something similar. Indy4x has the ones for Troopers, but doesn't seem to list that part code. Amazon has them for cheaper than Indy4x, but all listed by that code. Any help would be great! Thanks!
bamakojon
Postby Enemigo » Thu May 13, 2021 3:20 pm
I don't have the code available, but anything that fits Isuzu will work. Every truck shares the same front end. In addition, if you stumble across a used pair, the internals are the same across all platforms, so buying a rebuild kit should be easy.
Postby Tentin » Thu May 13, 2021 5:53 pm
In the name of science I bought ebay knockoff Aisins for $60 shipped for the pair. Basically bought them as a parts package to fix up my real Aisins, and have a fully functional backup to potentially install on the Amigo.
All and all I would probably run them but replace the bolts with actual grade 8.
1995 Isuzu Pickup 4WD aka Suzie Q. 3" lift, 32" A/T's
1998 Isuzu Amigo 4WD aka Smeagol The Amigo. 2" Lift, 31" A/T's
Tentin
Have thanks: 25 times
Postby Jake.Werecat » Sat May 15, 2021 5:08 pm
I have some (rather bad) experience with fake Aisins, or Aisin copies made by YAC or other Chinese never-heard-of brands. A friend of mine bough a pair of those, tempted by nice paint and very decent price.
This is how it ended:
Quality is definitely below acceptable level.
Jake.Werecat
Users browsing this forum: No registered users and 14 guests
