Manual impact driver
Postby itsmehb » Wed Sep 23, 2015 6:33 am
There's probably not many times you will need a manual impact driver, but the one time you might, it's a very handy tool to have in your tool box. Google manual impact driver and you'll see many are available. Mine is a snap on and worked great loosening the 3 screws that have to be removed to access the front wheel bearings.
1991 Pick up (long gone)
2000 Amigo, 2.2 5 speed(sold)
itsmehb
Has thanked: 142 times
Have thanks: 290 times
Re: Manual impact driver
Postby BigSwede » Wed Sep 23, 2015 10:23 am
Yeah, I bought a cheap one for that very purpose.
Formerly the owner of a 95 Trooper LS - 4" lift, 35" tires, 5.38 gears, ARB lockers
BigSwede
Has thanked: 17 times
Have thanks: 262 times
Postby IsuzuGeek » Thu Sep 24, 2015 1:15 pm
Yeah, I will watch eBay for one.
Bart
IsuzuGeek
Have thanks: 200 times
Postby gruff54 » Fri Sep 25, 2015 1:17 pm
There's been one in my toolbox since around 1970. Had to have one for the phillips head bolts on jap bikes.
Mike
'88 Trooper 2.6L 5 spd
'89 Trooper 2.6L 5 spd
gruff54
Has thanked: 43 times
Have thanks: 72 times
Postby Ed Mc. » Fri Sep 25, 2015 8:28 pm
gruff54 wrote:There's been one in my toolbox since around 1970. Had to have one for the phillips head bolts on jap bikes.
Mike
I have a K-D hand impact tool I bought about the same time, when I started working on my Honda motorcycles. Still have it and it works perfectly!
Much better built than most of 'em you find today.
Looks like the KDT1140 is an identical copy of my old one. I guess a good design doesn't doesn't necessarily go out of style!
http://www.ebay.com/itm/KD-Tools-KDT114 ... 5b16e9cfba
An indispensable tool and one that should be found in every mechanic's tool chest.
'90 3.4 Troop LS;
Yes, I am a Trooper-Holic!!!
Keep On Troopin' !
Ed Mc.
Have thanks: 336 times
Postby Von » Sun Sep 27, 2015 6:07 pm
That's another one of those tools you don't need very often but are worth their weight in gold when you do.
I've got a cheap one from harbor freight. Works great.
2015 BMW 328i (The Mighty Wife's ride)
2009 Dodge Ram 1500 quad cab (my fat car with a yuge trunk)
1965 Ford Fairlane 500 Sports Coupe 289 & 4 speed (SOLD)
1968 Kaiser M715, Ford 390, T18, Dodge divorced NP205, stock Dana 60 and 70 axles, lockers front and rear.
Von
Have thanks: 43 times
Postby red cube » Thu Oct 08, 2015 11:30 pm
They're also handy to loosen door latch and striker bolts. Pretty sure mine's a K-D. Bought it 10-15 years ago, used it about half a dozen times. You don't need one often, but when you do, you sure are glad you have one!
for Lo! I am Isuzu: consumer of fuel and harbinger of rust;
Look upon my tires, ye potholes, and despair!
red cube
Has thanked: 26 times
Have thanks: 25 times
Postby geoffinbc » Thu Oct 22, 2015 7:54 am
They are great tools. Especially since all vehicles use Philips head screws somewhere. A tip for the wheel bearings. Remove the screws with the took and replace them with a flat head socket cap screw. I have changed mine over and it makes future service much easier.
geoffinbc
Has thanked: 8 times
Have thanks: 352 times
Postby itsmehb » Fri Sep 28, 2018 4:56 am
Bump for Richey
itsmehb
Postby Richey » Fri Sep 28, 2018 4:34 pm
itsmehb wrote:Bump for Richey
Thanks man!
-1994 2.6L Amigo 4x4 Build
-1990 Spacecab 4x4 4 speed 2.2L Diesel Complete Veggie oil conversion Build
-2000 Rodeo 4x4 3.2 Build
Richey
Has thanked: 12 times
Have thanks: 16 times
Postby furiousbob » Sat Oct 06, 2018 3:32 am
This thing has saved me sooo many times. Especially for your variety pack brake jobs. Seems like every company uses phillips screws on their rotors.
1990 Isuzu Trooper 5MT
Reproduction round-eye grille w/ Hella E-Codes
Home-made front/rear bumpers w/ Smittybuilt winch + KC Daylighters
1" Body lift, 1.5" lift Indy4x shackles
Sway-a-way HD Torsion bars cranked 1.5" higher
31/10.5r15 BFG KO2s
furiousbob
Super Trooper
Has thanked: 39 times
Have thanks: 14 times
Return to Tool & Shop
