Flapper discs.
Flapper discs.
Postby squatch » Mon Jul 27, 2015 9:30 pm
One of my favorite tools. I have a couple of 4 1/2" angle grinders. They get a workout. a few years ago I discovered these flapper discs. The abrasive is bonded to steel leaves that lay like fish scales. They clean like crazy without over heating the metal like a grind stone wheel does. They also last a long time. This week I've been cleaning leaf springs with mine.
My builds are dead without the pics photobucket was holding hostage. The pics have been deleted and so have the links from my sig.
squatch
Has thanked: 71 times
Have thanks: 361 times
Re: Flapper discs.
Postby JLEMOND » Mon Jul 27, 2015 11:00 pm
I WILL PICK UP ONE OF THOSE AND CHECK IT OUT , LOOKS GOOD . THANKS MARK
JLEMOND
Have thanks: 351 times
Re: Flapper discs.
Postby paulevans76 » Tue Jul 28, 2015 11:50 am
Love me some flapper discs.
MUA5 w/ 3.07's & fixed yoke
Warn XD9000 w/ synthetic rope, rear swing out tire carrier
1.5" body lift and fuel tank lift
1994 Samurai - 1.3 FI - topless mini wheeler in the works
Has thanked: 219 times
Have thanks: 180 times
Re: Flapper discs.
Postby PPCLI-JIM » Tue May 31, 2016 10:03 am
been using for years , what a great piece of kit :D
Its a small amount of fuel , but it's a whole lot of walking..Note from my Dad
97 Rodeo 3.2 AKA THE PAVEMENT PRINCESS pretty much stock DEAD PARTS DONOR
88 TROOPER II 2.6 Auto Weber 32/36 Carb 9k Winch
95 Rodeo 3.2 Manual AKA Frankenstien this will be off roadered
91 Rodeo 3.1 Auto The GREY GHOST new highway runner
9 ft 1963 Harbercraft
12 ft fiberglass boat
14ft 1962 Powercat 14T boat
Fishing Rods lots of those !
PPCLI-JIM
Trail Scout
Has thanked: 50 times
Have thanks: 18 times
Re: Flapper discs.
Postby imamonstertruck » Tue May 31, 2016 11:30 am
Use them all the time, especially in the shop when i clean up bourbon barrel rings
Great idea on the springs Mark. They look great
Cheers
-Ian :blackeye:
-91 Trooper, 3.4 V6, 5speed, 4.77 gears, 3:1 Revo T-Case Gears, HD tie rods, 3" body lift, 2" suspension lift, 1.5" diff drop, 33x10.5x15 BFG A/T,
Round Eye Swap (JDM marker lamps).
1989 Trooper RS https://forum.planetisuzoo.com/viewtopic.php?f=15&t=81642&p=722882#p722882
Previous Troopers and Build Thread->https://forum.planetisuzoo.com/viewtopic.php?f=15&t=63260
1988 ISUZU TROOPER WORKSHOP MANUAL
"There are only two days in the year that nothing can be done. One is called yesterday and the other is called tomorrow, so today is the right day to love, believe, do and mostly live."~ Dalai Lama
“Unless someone like you cares a whole awful lot, nothing is going to get better. It's not.”Dr.Suess
Aaronmcvay84 wrote:I think with isuzus there is a more mature crowd that realizes the value of their hard work. They keep things.
imamonstertruck
Has thanked: 55 times
Have thanks: 175 times
Re: Flapper discs.
Postby geoffinbc » Wed Jul 06, 2016 3:01 am
They are descent. In a production environment they are only good for finishing. If you have serious rust and scale removal jobs and a sand blaster is not available then use Walter Mill Scale Flex Cut Discs. They work much faster and don't clog up.
The idea behind a flap disc is they remove material like 36 grit but leave a finish like an 80 or 120 grit.
Have thanks: 352 times
Re: Flapper discs.
Postby wesharris » Wed Jul 20, 2016 9:52 pm
I love flap discs ...I like them cause you can nearly Polish with them ...but also clean up nasty metal for welding
1990 trooper 2.6 msd6al ignition system msd turned "out to junk" blaster ll coil accel wires iridium NGK plugs 5 speed new head brake rotors and brakes 16" wheels new tires. new axles new clutch,flywheel,clutch master and slave cylinder all new ball joints 95 trooper front seats and turbo coming soon
viewtopic.php?f=15&t=65233
wesharris
Has thanked: 78 times
Have thanks: 28 times
Return to Tool & Shop
