Torin "Big Red" Farm Jack
Postby Storz » Mon Jun 17, 2013 9:29 am
Friend of mine gave me a new in box Torin Farm Jack, basically a cheaper version of a Hi-Lift. Just wondering if anyone know if the Hi-Lift accessories (mounts, base plate etc) will work with the Torin?
2000 Rodeo 3.5L MUA5
Storz
Trail Rider
Have thanks: 9 times
Re: Torin "Big Red" Farm Jack
Postby hr2burn » Tue Jul 09, 2013 9:02 pm
I think these things are like AR-15's, extremely interchangeable based on the exact same design. I thought about one of those bad boys as a jack but as far as 4x4's go, they are made more for winching, or chaining to a wheel to lift it from loose dirt etc...not really putting on a bumper to change a tire. They look tough and bad azz mounted on a rig though!
1992 Rodeo *Old man .75" Dakkar leafs *Indy HD torsion bars (CRANKED!)
3" body lift (total 6.5" lift)
*Goodyear 33x12.5's * ProComp 15x10.5 rims
Superwinch 8500lb winch *Custom winch bumper
2004 350Z Turbochaged
2009 FJ Cruiser
hr2burn
Trail Rider
Has thanked: 16 times
Have thanks: 10 times
Postby woodsman1st » Sat Aug 31, 2013 1:34 pm
I have a high lift that I want to mount on my 86 Trooper; any suggestions or pics as to the way you have mounted yours? or any suggestions as to the best way to mount one.
I saw a pic once where the Hil Lift was mounted standing straight up on the rear bumper; problem is, it was then higher than the roof, not to good in timber country or any country with lots of trees.
But Im open to suggestions.
Ken
MY BASKETCASE 1986 TROOPER
THE MOTOR APART IN A PILE BEHIND THE REAR SEAT;
PUT BACK TOGETHER AND RUNNING LIKE A CLOCK;
THANKS TO THE MEMBERS OF THIS FORUM;
JERRY, ERIC, john,TIM, DICK AND MANY OTHERS.
3 LONG YEARS BUT WE DID IT GUYS, WE DID IT!
woodsman1st
Has thanked: 335 times
Postby QuantumRift » Tue Sep 24, 2013 10:35 pm
Like the old 'bumper jacks' of yore, the higher you lift the load on this thing the MORE unstable it becomes and prone to flopping over and crushing whatever is under the vehicle. Ow!
hr2burn wrote:I think these things are like AR-15's, extremely interchangeable based on the exact same design. I thought about one of those bad boys as a jack but as far as 4x4's go, they are made more for winching, or chaining to a wheel to lift it from loose dirt etc...not really putting on a bumper to change a tire. They look tough and bad azz mounted on a rig though!
"If Opportunity knocks and he's not at home, Opportunity waits."
"Find out what it is in life that you don't do well, then don't do that thing."
1990 Isuzu LS SpaceCab 4x4 (Japanese-built, September 1989)
226,000 miles original, unrebuilt engine.
K&N Air Filter
2.6 L 4ZE1 engine, 5-spd manual
Monroe Sensa-track Load Adjusting Shocks (rear)
Monroe OE Spectrum Shocks (front)
MagnaFlow Muffler & Cat Converter
Akebono ProACT Ultra-Premium Ceramic Brake Pads (front)
Wagner Thermoquiet Ceramic Brake Pads (rear)
Owned since 15 miles. Bought new Honolulu, HI in Oct '89.
Original sticker price: $15,000.
QuantumRift
Has thanked: 27 times
Have thanks: 112 times
Postby chuffer » Wed Sep 25, 2013 1:00 am
Don't know if the accessories will fit or not. Best is to see if you can test fit them before buying.
As for where to mount the hi-lift type hack, my vote is inside the vehicle. In my build thread somewhere there is a pic. Main reason to mount inside is protection from the elements. Grit and rust in the ratchet mechanism is no bueno.
As for the danger-aspect of using a hi-lift type jack, there is an easy solution: pay attention to what you're doing. Yup, it's dangerous, but so are many other tools.
-Chris
Shiba Wichern Cellars - Pinot Noir from Oregon -
chuffer
Has thanked: 58 times
Have thanks: 137 times
Postby bodegabandit » Sat Sep 28, 2013 6:03 pm
chuffer wrote:pay attention to what you're doing. Yup, it's dangerous, but so are many other tools.
The world would be a better place if more people would live by these simple words.
Jp
1997 Trooper Auto
265/75/16 Treadwright Guard Dogs
Full OME Setup, Nitrochargers & 919's
1 in Indy4x body Lift, Aisin Manual Hubs
Build thread
1999 Trooper 3.5 Auto
Parts truck, for now...
Give me a lever and a place to stand, I'll move the world.
bodegabandit
Has thanked: 4 times
Have thanks: 5 times
Postby Wicray » Wed Nov 28, 2018 6:34 am
Sorry to raise an old topic. Maybe this information will be useful to someone in the future. :D
I want to tell about my Hi-Lift Jack HL484 48″ Black Cast and Steel Jack. This is 48” cast iron and steel jack and is made up of four different component materials. All the parts are either cast or stamped steel.
This model is quite lightweight, coming in at only 28.9lbs, it delivers a very strong punch of performance.
Rated load capacity: 4,660lbs
Load capacity max: 7,000lbs (Tested)
This model comes with an easy to winch handle, durable mechanical operation, and a shear bolt, so if you decide to lift an M113 Bradley to change a tank tread, well it won’t let you. The mechanism is easy to operate, so I don’t sweat when applying this in any situation.
And one more model it's Torin Big Red 48″ like this https://mechanicguides.com/best-farm-jacks/ which my brother bought recently. The Torin Big Red 48″ ratcheting off-road utility farm jack weighs in at only 30.1lbs and it can life 6,000lbs from 5.12” to 40”. So its an impressive piece of metal machinery.
This model conforms to ASME B30.1 standards, and it operates smoothly. It is used both vertically and horizontally and can be used for lifting, pulling, clamping, winching, and spreading.
The mechanism is really smooth, in fact, its one of the smoothest, we felt, so it competes with Hi-Lift.
It's one usefull video https://www.youtube.com/watch?v=0KbEfqJJLWQ
Wicray
Return to Tool & Shop
Users browsing this forum: No registered users and 6 guests
