Which OBD2 code reader w/ABS??
Postby kmcmilla » Tue Oct 24, 2017 12:15 pm
Thinking it's time to get a code reader and would like to get one that will read the ABS codes as well. I don't have an android phone and prefer to just get a standalone handheld unit.
Cars in the fleet are '97 Suburban, '99 Rav4, '02 Mazda Tribute, and a couple of '01 Rodeo Sports.
There are several Innova models that say they will read the ABS codes (3020 and 3030) for under $50, anyone had success reading codes with these?
Any other readers I should be considering? I'd like to stay under $100 if possible.
Thanks!
Ken
'01 Rodeo Sport - 4x4 3.2 V6
kmcmilla
Have thanks: 6 times
Re: Which OBD2 code reader w/ABS??
Postby kmcmilla » Wed Oct 25, 2017 11:49 am
Doesn't anyone read ABS codes from their Isuzu with a handheld OBD2 scanner?
kmcmilla
Postby gwana66 » Wed Oct 25, 2017 12:01 pm
I think I've seen Buster mention the Innova 3160, but I'm not sure. Maybe a PM to him?
Even the hubs are manual now.
2002 Grille and headlight swap
gwana66
Has thanked: 14 times
Have thanks: 265 times
Postby Von » Wed Oct 25, 2017 6:57 pm
I bought an Innova 3030 several years ago when I started getting ABS warnings on my GTP. I never could get the silly thing to pick up an ABS code, even when the car's information center was telling me the ABS had an error. And it was hit or miss as to whether or not it would read various car's systems.
So even though it's in your price range.... don't get that one.
2015 BMW 328i (The Mighty Wife's ride)
2009 Dodge Ram 1500 quad cab (my fat car with a yuge trunk)
1965 Ford Fairlane 500 Sports Coupe 289 & 4 speed (SOLD)
1968 Kaiser M715, Ford 390, T18, Dodge divorced NP205, stock Dana 60 and 70 axles, lockers front and rear.
Von
Has thanked: 43 times
Have thanks: 43 times
Postby kmcmilla » Tue Nov 28, 2017 5:22 pm
Well after working with Autel customer support they finally told me that the Autel AL619 scanner I purchased will not read Isuzu ABS codes, the protocol hasn't been developed. Their website and literature says it will read both the Isuzu ABS and SRS codes. The AL619 did connect to the SRS system and seemed to talk to that module, but not the ABS. Thankfully I was able to return the scanner for a full refund.
So, back to the original question, has anyone found a handheld scanner that will read the Isuzu ABS codes?
kmcmilla
Postby totten » Fri Jan 05, 2018 10:06 pm
Don't know about a scanner that will work, can connect pin 4 and 8 on DLC, and count the flashes off the CEL for codes.
2004 rodeo 4x4,3.2,aw3040ls automatic,Stock springs with Independent4x 2"coil spacers, Zone 2" Body Lift, 285/75/16 Mastercraft Courser HXT Tires. Cobra 29LTD CB,Transmission cooler,Functional hood scoop,kyb shocks
totten
Have thanks: 107 times
Postby 93trooperpooper » Fri Jan 05, 2018 10:19 pm
after 1996 it is the law that every vehicle in north America be OBD2 compliant
BUT
some of the car makers kept the old diag connectors, but were OBD2 compliant-ish-
but you needed THEIR adaptor to read/diagnose/clear dtc problems.
I have a autel maxidas 708-reads everything under the sun- but its not cheap new, thank god I got mine for $500.
its slower than the $4000 dollar model, but than again I get paid by the hour......
will drive these until they quit and move onto something else.
parts from JERRY LEMOND.
93trooperpooper
Has thanked: 4 times
Have thanks: 14 times
Postby totten » Sat Jan 06, 2018 9:05 pm
$500 Dollars for a scanner----unreal,good to know. :twisted:
totten
Postby Dingbat » Mon Jan 08, 2018 4:53 pm
totten wrote:$500 Dollars for a scanner----unreal,good to know. :twisted:
If you think that is high you should try to price out the Tech1 / Tech2 specified in the FSM.
Wry Wench build thread
Dingbat
Has thanked: 18 times
Have thanks: 72 times
Postby rbral » Fri Jan 26, 2018 6:51 pm
I picked up one of these Tech 2. I just couldn't resist! Lol! Works great on my 2002 Troop, my 98 Blazer and my son's 97 S-10.
2002 Trooper, Dobinson bars, Moog CC812s, Superwinch Locking Hubs, TOD mod v. 2, Aux Audio In, DS Grab Handles.
98 Blazer, needs some love
rbral
Drives in Mud
Has thanked: 20 times
Return to Tool & Shop
