WTB Folding trail jackstands
Postby Nelsoncycles » Wed Mar 22, 2017 2:18 pm
http://www.jkowners.com/forum/jk-genera ... stand.html
I would be really interested in something like the Slee prototype Has anyone bought anything similar to this product? What do normal people do when they have to do more than pull a tire? Is there a better option than cutting a section of log?
Nelson
Nelsoncycles
Re: WTB Folding trail jackstands
Postby Von » Mon Mar 27, 2017 10:58 am
I have no idea what normal people do.
Interesting thread though... those JK owners can get kinda pissy.
Pretty cool stands though, wonder why they haven't pursued that. That's the only jack stand design I've seen that I'd trust on soft ground though. Or carry around some lumber to put under a regular jack stand.
2015 BMW 328i (The Mighty Wife's ride)
2009 Dodge Ram 1500 quad cab (my fat car with a yuge trunk)
1965 Ford Fairlane 500 Sports Coupe 289 & 4 speed (SOLD)
1968 Kaiser M715, Ford 390, T18, Dodge divorced NP205, stock Dana 60 and 70 axles, lockers front and rear.
Von
Has thanked: 48 times
Have thanks: 43 times
Postby N law » Thu Mar 30, 2017 3:56 pm
Seems like if you need jack stands on the trail, you're in deep doo doo. I've seen everything from using nearby rocks or logs for cribbing under the frame. Most of the time though, unless you're changing a tire, an off-road rig will have clearance to climb under and fix a rear end or driveshaft issue. If you do have to pull the wheel to do brake or CV work, stick the tire between the frame and the ground. Keep your arms and legs out of the way while you work and just be careful.
If you really wanted to haul something around, get or build something like a dirt bike stand or the pedestal that elephants put their feet on at the circus as a stationary jack stand. But I would make sure it was wide and stable and only use it on flat, solid ground.
99 VX
96 Rodeo Build thread
1975 FJ40
1990 Jeep Cherokee
69 Beetle
84 Westfalia
70 VW bus turned camper
07 Frontier V6 6 speed
1999 4Runner Limited
2018 4Runner Limited- wife's
2004 Genuine Stella Scooter
2018 GMC Sierra
For this post the author N law was thanked by:
Nelsoncycles
N law
Has thanked: 17 times
Have thanks: 82 times
Postby BigSwede » Thu Mar 30, 2017 4:24 pm
Spare tire under the frame.
Formerly the owner of a 95 Trooper LS - 4" lift, 35" tires, 5.38 gears, ARB lockers
BigSwede
Have thanks: 262 times
