FS, NE DFW: 92-95 DOHC conv parts, 92-02 various Troop parts
680 views 1 reply 2 participants last post by  reran
#1 ·
Recently sold my 1997 Trooper so it's time to let go of my parts stockpile as well as the parts I had gathered for conversion to DOHC.
I've tried to price the parts below Rock Auto, eBay, and the common retail places but am happy to discount if you buy a bunch at once (even moreso for the DOHC parts).
Am happy to answer any questions and take specific close-up pictures. Here are pictures I already have:
https://drive.google.com/drive/folders/ ... sp=sharing
Each part listed is new unless otherwise noted.
Some of these parts are compatible with all 1992-2002 Troopers, some only with 1992-1997, some only 1992-1995, and some are shared with Rodeos from this era. I've noted applicability for a few of them but it's your responsibility to confirm fitment for your application.
You must be local to DFW, sorry no shipping.
[][]1992-1995 SOHC-TO-DOHC CONVERSION PARTS[][]
Pair of remanufactured 1992-1995 DOHC cylinder heads (from Clearwater Cylinder heads as recommended by Isuzu guru Jerry Lemond; I've kept them boxed up in my house since I bought them) -- $450 for each, keep in mind you wouldn't need to source a pair of cores
1992-1995 DOHC exhaust manifold pair (purchased used from Jerry; includes...
a pair of new gaskets for where each collector bolts to its down-pipe
a pair of gaskets for where each manifold bolts to its cyl head
heat shield for each manifold)
-- $120 for pair
1992-1995 DOHC timing belt + water pump kit (Gates TCKWP220) -- $120
FelPro head gaskets along with various other gaskets to bridge the gap when using DOHC heads with the SOHC intake manifold (the preferred combo when starting with a 1992-1995 SOHC truck):
head gasket (HS 9174 PT) -- $10
conversion gasket (CS 9174) -- $20
2x manifold gasket set (MS 95751) -- $2 for each
2x 1992-1995 DOHC upper timing cover pairs (used; to be clear, I have two sets of...
left gear front timing cover
left gear rear timing cover
right gear front timing cover
right gear rear timing cover
...I don't have the bottom cover since your existing SOHC bottom cover thru 1997 can be re-used)
-- $50 for pair with their bolts, $40 for the pair without
1992-1995 DOHC timing gear pair and the associated bolts (used)
-- $80 for pair
2x 1992-1995 DOHC valve cover pairs (used; to be clear, I have two sets of...
Left valve cover
Right valve cover)
-- $120 for the pair with their hex-head bolts, or $100 for the pair without
Head Bolts (A&B Brothers HB6270) -- $20
EGR pipe (used, purchased from Jerry) -- $50
[][]ENGINE GASKET/SEAL[][]
2x seal kit for camshaft front + crankshaft (Dayco SK0021) -- $15 each
3x camshaft rear seal plug set (FelPro TCS 45868) -- $2 each
1992-1997 SOHC valve cover gasket set -- (FelPro VS 50469) -- $3
spark plug tube seal set (FelPro ES70691) -- $1
throttle body gasket (FelPro 61034) -- $2
[][]ENGINE COOLING/HOSES[][]
Radiator (Denso 221-9369, box was opened upon receipt to check condition; a few bent fins but in 15 years of wrenching I've literally never unboxed a radiator with all perfectly straight fins) -- $80
5x o-ring for the big coolant pipe in the cylinder head valley (purchased from Jerry, OEM 9-09561338-0) -- $5 each
4x o-ring for the small coolant pipe in the cylinder head valley (purchased from Jerry, OEM 1-09623130-0) -- $4 each
Fan clutch (used, still good, replaced preemptively) -- $20
Fan mount (Gates FB1016) -- $60
Thermostat (OEM 8-97032508-0, purchased from Jerry) -- $10
new OEM hoses purchased from Jerry:
2x "water, eng to" (8-94376339-1) -- $10 each
2x "water, by-pass" (8-97088139-0) -- $8 each
2x "water, htr un" (8-94376341-1) -- $6 each
1x "water, htr" (8-97018914-2) -- $3
1x "water, htr" (8-97071865-1) -- $3
used hoses (still in good enough condition to keep as spares):
1x "water, htr" (8-97018914-2) -- $1
1x "water, htr" (8-97071865-1) -- $1
1x "hose, rubber, throttle" (8-94379199-0; this one goes from the cross pipe to the throttle body) -- $2
2x thermostat gasket (FelPro 35599) -- $3 for both
4x water manifold gasket (FelPro 35590) -- $5 for all
2x water outlet housing gasket (FelPro 35591) -- $3 for all
Radiator cap (used, still good, replaced preemptively) -- $1
[][]FUEL/AIR/IGNITION/EXHAUST[][]
7x new OEM (i.e. NOT aftermarket or reman'd) injector purchased from Jerry (8-17120-271-0) -- $80 each
3x Ignition coil (Hitachi IGC0047) -- $40 each
2x Ignition coil (used; 1 is good, other is unknown) -- $15 for both
1x ICM (used, from Ballard Wrecking in Hurricane, Utah; specifically bought from a junkyard in the desert since these are automotive electronics from the 90's) -- $80
1x ICM (used, was my truck's original; went bad and caused ign ckt #6 misfire but I kept it in case somebody knows how to repair solid-state electronics) -- $10
Air filter (Bosch 5270WS) -- $2
Mass airflow sensor housing + sensor (Carquest MQ7320) -- $70
Fuel filter (Ultra Power 33310) -- $2
Fuel filter (used, still good, replaced preemptively) -- $1
O2 sensor (Denso 234-4012) -- $20
Fuel Pressure Regulator (Beck Arnley 158-0947) -- $25
Sensor-end of knock sensor wiring harness pigtail (used, rubber sheath is split but actual wires are good; had to cut off the other end because replacement didn't include it) -- $1
Alternator (seems to be OEM, works but could use a coil rewind [FYI there is a shop in Richardson TX that specializes in this service]) -- $15
6x spark plug (used, about 5k miles on them, NGK BKR5EGP) -- $5 for complete set
2x EGR base gasket w/ mesh screen (WVE 3F1160) -- $10 for both
2x gasket for where EGR base bolts onto intake manifold (FelPro 70832) -- $2 for both
2x gasket for where EGR pipe bolts to exhaust manifold (FelPro 70794) -- $2 for both
[][]STEERING/SUSPENSION/DRIVETRAIN/BRAKES[][]
Power Steering high-pressure hose (Edelmann 2647-273006 [alt p/n 80097]) -- $25
2x greaseable lower ball joint (AC Delco 46D2274A; fits 1995-2002 Troopers) -- $75 for both
Rear right loaded brake caliper
(Raybestos RC10407; "loaded" means it includes pads and bracket) -- $60
Rear left loaded brake caliper (Raybestos RC10408; "loaded" means it includes pads and bracket) -- $60
Complete set of brake hoses
2x rear outer hose (Sunsong 2201291) -- $10 for both
1x rear center hose (Sunsong 2206710) -- $5
2x front (Sunsong 2201290) -- $10 for both
Clutch master cylinder (Exedy MC144) -- $10
Clutch slave cylinder (Exedy SC550) -- $5
Clutch hose (Sunsong 2204240) -- $5
1992-1997 power steering pump rebuild kit (AC Delco 36-348419) -- $15
[][]ENGINE GENERAL[][]
SOHC Timing belt + water pump kit (was on my truck when I bought it, replaced preemptively; unknown mileage but appears to still have some years left) -- $15
Oil pump (new but no box; purchased from Jerry who said it's AISIN brand) -- $50
[][]ENGINE SENSOR[][]
Temp sender for dashboard gauge (used, still good, replaced preemptively) -- $2
Temp sensor for ECU (used, still good, replaced preemptively) -- $2
Knock sensor (used, still good, replaced preemptively) -- $5
Crank sensor (Ultra Power 5S1632) -- $60
[][]INTERIOR/BODY[][]
Windshield side-molding trim pieces along with the metal caps that attach to them on the roof (used, has some RTV that needs to be cleaned out) -- $5 for complete set
Cargo area floor mat (used) -- $20
Cargo area cover (used, handle plastic is missing and spring has lost its tension, but cover could still be used static) -- $5
Cargo net (used) -- $10 for set
2x seat spring for front seats (used) -- $10 for both
Driver side sunvsior (used) -- $20
Weatherstripping for all 4 doors (used) -- $60 for set
Dust shield (aka tar paper) for inside each door (used) -- $20 for set
Rearview mirror (used) -- $5
2x replacement switch panel for driver door (used) -- $40 each
2x replacement switch panel for front passegner door (used) -- $15 each
window switches for both rear passenger doors (used) -- $5
both rear tail light assemblies (used) -- $80 for pair
front left headlight and side marker (used) -- $80 for pair
2x battery tray (used) -- $2 for the one with a crack, $5 for the one without
footrest for rear passenger (bolts onto flood under front seat) -- $15
Complete set of 4 rubber cushions for hood (used) -- $5 for set
Trim cover for rear set "fold forward" hinges (used) -- $5 for set
Cargo hook + cover (used) -- $5
Seat slide rail trim covers for both front seats (used) -- $5 for pair
Door handles for all 4 doors (used) -- $10 for set
Door sill kick plates AKA kick panels (used) -- $10 for complete set
Air conditioning compressor belt (ROADMAX 4K320AP) -- $2
Power steering belt (used, replaced preemptively; still has some years left) -- $1
Pair of mismatched bolts for spare tire (used) -- $5 for pair
4x4 shift lever (used) -- $2
Turn signal flasher (used; suspect bad but not certain) -- $1
