Need Gen 1 Trooper front wheel studs & lugs
406 views 3 replies 3 participants last post by  giusedtobe
#1 ·
Need 4 studs for the front. Rock auto ones are not correct. E-mailed Jerry Lemond but have not heard back. Anybody know a reliable source? Also need 4-6 lug nuts like the ones for the wheel below. Original Isuzu 5 spoke aluminum rim.
Thanks
Alan
#2 ·
Dorman makes wheel studs. You'll just need the size of course. Once you get it apart you may see that you'll need oversize studs if the splines are wallowed out so it might be better to pull it first.
Napa can helpyou with the right studs if you're having trouble finding them online
#4 ·
Shawn Anthony said:
Autozone, Napa, O'Reillys, Monument, Summit Racing, Local fastener supply company..... Pick one. If the store doesn't have a listing take a sample into the store and match one up.
I actually got them from Jerry. Had mixed results trying to find them locally. Got the rears at O'Reilly after several no-gos at some you mention but the lugnuts they had were not close and a different size. All good now.
