2nd Gen Trooper Monster IFS Build Thread - 35's & Locker
ASIN
Postby TrooperPR » Wed Mar 04, 2009 10:57 pm
From what vehicle are the manual hubs? who sells the discos? 8)
TrooperPR
Postby lorenzo816 » Wed Mar 04, 2009 11:10 pm
Mi gente, Busque por favor.
Usted puede comprar todo que usted necesita de Independent4x.com
1997 Solid Axle Rodeo :: Ar5 swap :: Revo 4Lo :: 5.29/5.36 :: Front OX :: Rear ARB :: Full Float :: Chromoly Bling Bling
Build: 3-link coilover front 44 & rear FZJ80 on 37's
PM me if you need anything - Need a Skull Planet Isuzoo sticker?
lorenzo816
Has thanked: 111 times
Have thanks: 129 times
Postby tbecktold » Thu Mar 05, 2009 2:10 am
Is usted too formal? Posible solamente 'necesitas'?
I've downgraded to just lusting after regular cab 4x4 Pickups.
tbecktold
Postby jcochrane » Fri Apr 17, 2009 8:36 pm
looks awsome its got me wishin
97 trooper 92.024miles 3.2l auto lockers 2in up on t bars 31s and hella fun aka po lil tink tink-76 chev k5 ricky sanders 383 "450 hp" munci 4 speed corp 14 bolt rear custom corp 14 bolt front 40x17x15 aka the beast<<<sold :(
jcochrane
Postby -Deleted- » Mon Nov 30, 2009 5:28 pm
:D wow what a great trooper.mine will be simular between now and the next 15 to 16 months 8) neo
-Deleted-
Postby mdocod » Tue Dec 15, 2009 9:58 am
wow, very interesting read and a great build.
The most interesting thing for me is seeing that it would appear that one can swap the "longer" upper control arms from later model isuzus onto the older ones. I didn't think this was possible but now that I see the pics I'm thinking that this might be my best option to get my front end to run with proper alignment and better handling. I have a 95 rodeo with the short arms (4 bolt upper ball joint). I've seen plentiful quantities of isuzus in salvage yards around here, I should be able to pull the half-shafts, lower joints, and UCA and get my front end a little wider. I think wheel spacers in the rear should work fine as well. Very cool information here.
Thank You,
Eric
95.0 rodeo, 3" lift, trooper front suspension/axles/tie-rods, 1.25" diff drop, terra-low 3:1, Warn premium manual hubs, custom rear drive-shaft, 235/85-16 Duratrack, ~240 billion miles and counting,
mdocod
Postby Cavmedic » Wed Jan 13, 2010 12:04 pm
awsome build great looking trooper :cheers:
JP U.S. Army Cavalry 84-05 (Ret)
90 Isuzu Amigo Superwinch hubs 4.3 V6 5 Speed 33x12.5x15 lifted -Trail Truck
90 Isuzu Trooper 2.6 5 Speed Aisin hubs, Rear Aussie locker
99 Chevy Suburban 4x4 stock -Hunting/Tow Rig
Cavmedic
Postby Camiel » Wed Jan 13, 2010 12:45 pm
mdocod wrote:wow, very interesting read and a great build.
Thank You,
Eric
You can't swap the control arms from the later models (3 bolt) to the older models (4 bolt) :!:
The upper control arm isn't a straight bolt over!
There are 3 IFS wides used through the years:
Trooper:
1981-1991 4 bolt upper balljoint
1991-1995 3 bolt upper balljoint (1.5" wider each side)
1995+ 3 bolt upper balljoint (1" wider than the 1991-1995 models)
Rodeo:
1991-1995 4 bolt upper balljoint
1995-1998 3 bolt upper balljoint (1.5" wider each side)
1998+ 3 bolt upper balljoint (1" wider than the 1995-1998 models, but totally different, R&P steering etc.)
The swap you saw here is the swap from the early 3 bolt model, to the later 3 bolt model Trooper.
The control arms of the 4 bolt models are less width as the 3 bolt models.
So the bolt holes on the chasis won't line up.
I can take some pics if you want :wink:
Camiel
Camiel
Postby -Deleted- » Wed Feb 10, 2010 12:42 pm
here is the buildup thread on my humble trooper 8) neo
https://forum.planetisuzoo.com/viewtopic.php?t=36807
-Deleted-
Re: 2nd Gen Trooper Monster IFS Build Thread - 35's & Locker
Postby Strongway » Sat Oct 04, 2014 3:30 pm
Thanks,for the info,I just bought a 95 2 gen,,to my daugther and she was looking to build a proyect on it,,and I'm no mechanic,,so your proyect was perfect for her,,will keep you posted for further assistance
Strongway
Postby muddingrodeo » Tue Jan 13, 2015 1:23 am
That was a fine write up. I love your trooper and it gives me something to shoot for.
98 Isuzu rodeo 4x4 4" lift 32" tires all black ( mudding truck)
98 Isuzu trooper 4x4 4" lift (fixing transmission)( got this one fixed finally and running on 33" tires)
02 Isuzu trooper 4x4 parts car(may fix up)(my kid wanted this one so its being fixed) Update! this one is now fixed non mudder
98 white Isuzu Trooper 4x4 supposed to be parts car ( having trouble sticking to this idea!)
450 kodiak x 3 (the kids like mud too)
91 300zxtt
07 G35 brembo
KLR650
YT450
muddingrodeo
Have thanks: 7 times
Postby totten » Mon Nov 23, 2015 10:47 pm
Great work and thanks for pictures. Tony :mrgreen:
totten
Have thanks: 107 times
Re:
Postby BigSwede » Tue Nov 24, 2015 10:26 am
Camiel wrote:
mdocod wrote:You can't swap the control arms from the later models (3 bolt) to the older models (4 bolt) :!:
Trooper:
The quoted post is 5 years old, but I thought I would correct this information.
All 92-02 Troopers use the same upper ball joint. In 95 (in USA) they went to wider upper control arms to achieve the wider track.
Lower ball joints are the opposite story. in 95 they went to a longer lower ball joint, and all 92-02 use the same lower control arm.
Formerly the owner of a 95 Trooper LS - 4" lift, 35" tires, 5.38 gears, ARB lockers
Indy4x Revolution 3.07:1 low range gears, Indy4x HD tie rods, homemade sway bar disconnects, Calmini HD sway bars, Darlington diff drop, OME 929 coil springs + 1" poly spacers and 1" body lift, Indy4x HD torsion bars, Indy4x HD rear axle links, Indy4x Kevlar brake lines, ARB bullbar, custom rear bumper with swing-out dual jerry can carrier, rock sliders, Sears Platinum Group 31 battery, ARB mini-compressor, Indy4x kevlar air lines, Warn M8000 winch, Blue Sea 6006 winch cutoff switch, Yaesu FT-1900R 2-meter ham radio, Larsen MHW-150C 1/2 wave antenna, Cobra 18WXST CB radio, Firestik II CB antenna, IPF driving lights, generic fog lights, two (2) Blue Sea auxiliary fuse panels, sleeping platform, and outofrshell Dave's custom 1" shifter extension. (I actually typed this list as a joke but people seem to like it.)
BigSwede
Has thanked: 17 times
Have thanks: 262 times
Postby PhilD » Tue Nov 24, 2015 6:43 pm
Regarding using the bedliner spray in the wheel wells and elsewhere: does it work better than undercoating spray? Thanks.
PhilD
Postby Bushcreature » Mon Mar 14, 2016 7:02 am
Amazing build, I have a wide track petrol Jackaroo (Aussie version of Trooper) rolling shell and was going to put a diesel in it but there is so much that needs to be swapped out I'm just going to pull the parts off and put them under a standard track Jackaroo and this post gives me some more ideas.
BC.
Bushcreature
Postby BigM35 » Fri Oct 28, 2016 5:45 pm
What size bolt / nut did you use to secure the transfercase to the front drive shaft? The part that I circled in red?
BigM35
Postby 1995pickup » Fri Jun 30, 2017 12:47 pm
:D My favorite 2nd generation trooper of all time 8)
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Recent 2.6 rebuild with a "Jerry Cam"all parts for engine rebuild came from Jerry Lemond. Bored .40 thounsands and Engine rebuid performed by the Legendary Johnny 5 .
1995pickup
Has thanked: 33 times
Postby Enemigo » Fri Jul 24, 2020 2:27 pm
How have the front axles been holding up on this thing?
Postby mudoilngears » Fri Jul 24, 2020 2:59 pm
Enemigo wrote:How have the front axles been holding up on this thing?
OP last visited in 2013. I think it’s safe to say he won’t answer.
Build in progress...
mudoilngears
Have thanks: 150 times
Postby lorenzo816 » Fri Jul 24, 2020 7:40 pm
I called him last year and we talked. He’s still got it just doesn’t wheel it as much. I haven’t seen him lately as he’s on the other side of town from me and he stays busy working.
If I hear from Wayne again, I’ll let y’all know.
lorenzo816
Postby Enemigo » Sat Jul 25, 2020 1:01 am
I figured, but also figured that since Lorenzo was buddies with him, he might have some input. I was right.
Return to Hall of Fame
