gm wheels on isuzu??
What fits and What performs
Re: gm wheels on isuzu??
Postby Black99Amigo4WD » Wed Aug 07, 2013 6:55 pm
Hi everyone!
I found a parts truck for the replacement of my rusted out frame on my truck. I only have 60,000 miles on her and it would be a shame to junk it when the running gear is still solid and the interior is leather and mint.
The parts truck is a 99 Amigo and has everything but the wheels. Any idea what cheap steel wheels I could get to allow it to be transported by car hauler from out of state to me?
I won't be running the steel wheels on the road, just need to get it on the truck and be able to move it around so I can separate the body from the frame and do the replacement work.
Thanks in advance! :wink:
Debbie
Black99Amigo4WD
Trail Rider
Has thanked: 31 times
Have thanks: 6 times
Postby Toccoa » Thu Aug 08, 2013 5:11 am
Black99Amigo4WD wrote:Hi everyone!
Debbie
Do you live near any pull a part places? You could grab some steel wheels off a Rodeo for cheap. Like $8.50 cheap.
2002 Rodeo Amigo Sport
V6 Auto RWD
Currant Red Mica Lagoon Blue Matte Metallic Thundercloud Metallic
1" Wheel Spacers
General Grabber AT2 255/70/16
1" Suspension Lift (coil spacers from Indy4X)
Build Thread Vinyl Wrap Samurai
Toccoa
Has thanked: 69 times
Have thanks: 58 times
Postby Luis95LS » Sun Aug 25, 2013 1:22 am
On my 1995 Trooper LS I have Nissan Titan / Armada wheels 18 by 8, with 265/65R18 Tires...
31.5" tall by 10.7" wide
Isuzu wheels have 4.5 inches of back spacing the Nissan Titan/Armada have 5.0 inches of back spacing...
Machine shop bored the center hole to Isuzu hubs size for $100.00... :D
1995 Trooper LS - 3-1/2" lift w/32" tires. Diff drop, HD tie rods, Bilstein shocks. (Soon DOHC heads)
2002 Trooper S - 3-1/2" lift w/34" tires. HD tie rods, Bilstein shocks, Smittybilt bumper.
2006 GMC Yukon SLT - 2" lift 33" tires.
2015 Infiniti Skyline Q50S
Motorcycles, 2005 and 2006 SV650 naked, heavily modified. 2007 Suzuki GSXR1000 streetfighter superbike. 1990 GSXR1100 Super Cafe Racer
Luis95LS
Trail Rider
Have thanks: 12 times
Postby Luis95LS » Mon Sep 02, 2013 5:59 pm
I am going to paint the centers of the wheels Flat Black with a Satin Clear Coat...
Rear...
Front...
Luis95LS
Trail Rider
Postby Toccoa » Mon Sep 02, 2013 6:53 pm
Luis95LS wrote:Image
Wow! That looks like it came that way. The larger size looks good on the Trooper. Find some Isuzu center caps and you would really have everyone fooled.
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby -88- » Sun Sep 08, 2013 9:18 pm
Anyone with 17s? Or what other zu's came with 17s beside the axioms? I love the axiom wheels but their back spacing is a little much. Need something thats a little further out from the frame, can use spacers sure but if I dont have to y? kind of stuck with 17s to get the overall tire profile im after.....least at a friendly price.
Ada-99 Trooper;3.5 TOD, Luxury, 2inch crank front,+2in calmini springs&spacers rear, 265/70/r17's (axioms)-Wife's whip
Tin Cup-90 Amigo; 2.6 4x4, 5spd, ala mexican special for the time being
Dr.Molly- 94 Amigo; 2.6 2wd, 5spd, 5% smaller goodyear wranglers on 15in snowflakes, predominantly stock, cruiser (& staying minimally modded)
José Rosé-92 Pu't Spacecab; 2.6 2wd, auto, future 16inch steelies, old skool street rubber,
Frank-95 Pu't Reg. Cab; 2.3 2wd, 5spd, T-bar crank and cheap shackle lift... Mild down a bit & sold, but still near & dear.
My garage- viewtopic.php?f=15&t=76464#p674958
Have thanks: 103 times
Postby Luis95LS » Sun Sep 08, 2013 11:09 pm
Nissan has a nice back spacing, you have to take the wheels to have the hub bored out...
GM wheels I do not know the back spacing space, you have to take the wheels to have the hub bored out...
Toyota need spacers... You DO NOT have to take the wheels to have the hub bored out...
Luis95LS
Trail Rider
Postby subdriver » Sat Oct 19, 2013 2:12 am
I've got a 1992 Isuzu Trooper that I put 17"x9" aftermarket wheels that came off a 02 GMC Yukon XL. I had a machine shop open up the bore from 4" to 4.25 ". They work great. Running BFG KO's.
subdriver
Postby -88- » Sat Oct 19, 2013 3:17 am
Aftermarket....or yukon stock......pix? Or do tell brand......yours maybe my route.
Postby subdriver » Sat Oct 19, 2013 8:45 pm
They are "V-TEC Raptor's" from Americas tire or Discount Tire. New ones are $109 each. I bought 4 used ones with tires for $220. Score.
subdriver
Postby Ripah27 » Sat Nov 23, 2013 4:13 am
Wood31 wrote:
95 Trooper with 06-09 16inch GM H3 rims, 285/75R16 bridgestone dueler a/t's No lift...for now lol
H3 rims with 285's with zero lift?
Ripah27
Postby drb930 » Thu Jul 30, 2020 11:32 pm
Any updates on this thread on running 17’s?
drb930
Postby Enemigo » Fri Jul 31, 2020 1:15 am
I just put Axiom 17" wheels on my Trooper. There are two different styles of Axiom wheels though. The wheels with flush center caps only fit on the rear and would need to be bored out to fit the front.
Has thanked: 7 times
Have thanks: 40 times
Postby drb930 » Fri Jul 31, 2020 3:11 pm
Enemigo wrote:I just put Axiom 17" wheels on my Trooper. There are two different styles of Axiom wheels though. The wheels with flush center caps only fit on the rear and would need to be bored out to fit the front.
So you are saying that the flush mounter center cap Axiom wheels are not 108mm center hole?
drb930
Postby 87_troopaII » Fri Jul 31, 2020 10:44 pm
Hey uncle rico can you post a picture of the kind of lug nuts that came on your rodeo, I have a set of factory center caps that I want to install on a factory set of 15" steel rims, but the lug nuts on my Trooper don't appear to be correct. The area where the lug nut seats on the center cap gets crushed when I tighten down the lug nut. I don't want to ruin these so I'd really appreciate it if you can post a picture. BTW your Rodeo looks sharp!
87_troopaII
Postby Enemigo » Sat Aug 01, 2020 1:00 am
Kind of. The main hole is 108mm, but there is an extra ring about 1/4" thick and wide around the inside that prevents the wheels from fitting over the front hubs.
Postby drb930 » Sat Aug 01, 2020 1:10 am
Thanks for that.
2002 they changed the hubs to the sealed bearings that don’t protrude with a “Hub Cap”.
I’ll get the ones like you have with the raised centers as mine is a 98.
drb930
Postby jc_in_az » Mon Jun 21, 2021 1:13 am
Dang! I've got the flush caps wheels from an 02. Where can I get them bored out?
jc_in_az
Postby Enemigo » Mon Jun 21, 2021 1:26 am
I've talked to a machinist that said he could do it, but I would have to take the tire off and for just one, I think it would have cost me more than I paid for all the wheels together from the junk yard. I didn't get an actual quote, but I was thinking it was going to be around $100. I eventually got 1.5" wheel spacers, and then that style wheel would fit over the SuperWinch manual hubs I was running. However, I recently switched to the Aisin manual hubs, and now that wheel won't fit on front again.
I guess Toyota guys have some wheel with a similar issue, and guys have been just using a router with a guide bearing and taking the lip off themselves. Apparently that drove all the machinists crazy, but they apparently didn't have any problems with anything.
Postby jc_in_az » Mon Jun 21, 2021 1:29 am
Enemigo wrote:I've talked to a machinist that said he could do it, but I would have to take the tire off and for just one, I think it would have cost me more than I paid for all the wheels together from the junk yard. I didn't get an actual quote, but I was thinking it was going to be around $100. I eventually got 1.5" wheel spacers, and then that style wheel would fit over the SuperWinch manual hubs I was running. However, I recently switched to the Aisin manual hubs, and now that wheel won't fit on front again.
Thanks for the reply. Might be cheaper and less stressful to grab a second set of rims. I'll be running Aisin hubs after the 4wd conversion.
jc_in_az
Users browsing this forum: No registered users and 10 guests
