The ozarkduck truck
The ozarkduck truck
Postby comerz » Fri Jan 02, 2015 11:17 pm
YES, the ozarkduck truck. The name came from my handle I use on my Cb radio, which came from a mixture of the song convoy (my dad and I use to listen to it together when i was just a little kid), and where I live, the Ozark mountains. I have done a lot of stuff to my rig, but there is much more to come. I use to have a build thread, but it was in the wrong section and I barely ever updated it. So now I'm just gonna use this one.
So far, I have: lifted the front by torsion bar(the back comes next friday), ball joint flip, new mau5 transmission with only 100000 miles on it, removed restrictors in y-pipe, cut everything out of cat conv, removed front bumper valence, wig wag turn signal mod, cobra cb radio, led red underflow dash lights in the interior (I can make them solid or flash with the bass), added drivers side "oh ----" handle, all new gaskets on top end of engine, all new gaskets in exausht system, all new stereo equipment including two 10 kicker comps (the good ones not the cheap Walmart kind), one dual 12in sub, jl audio 6.5s in the front door, eclipse in the back, jl audio 300/4 and mosfett 400 amps, and jl audio tweeter system all around.
--Link to my progress page https://forum.planetisuzoo.com/viewtopic.php?f=15&t=80525
--94 isuzu rodeoport 3.2L. lifted in front 3 inch 4 in back (2 in leaf, 2 in shackle)
--"the person who says it cannot be done should not stand in the way of the person doing it"
--Link to easiest way to bleed clutch https://forum.planetisuzoo.com/viewtopic.php?f=1&t=80414
comerz
Have thanks: 13 times
Re: The ozarkduck truck
Postby comerz » Fri Jan 02, 2015 11:24 pm
I will eventually upload pictures, but right now my phone is being a POS and won't let me.
comerz
Postby comerz » Fri Jan 02, 2015 11:41 pm
Some pictures
comerz
Postby comerz » Sat Jan 03, 2015 12:23 am
My lift kit. Going on next friday
comerz
Postby totten » Sun Jan 04, 2015 11:06 am
Like the sunroof,c.b.,nice first generation rodeo. Will look good with lift. Tony
2004 rodeo 4x4,3.2,aw3040ls automatic,Stock springs with Independent4x 2"coil spacers, Zone 2" Body Lift, 285/75/16 Mastercraft Courser HXT Tires. Cobra 29LTD CB,Transmission cooler,Functional hood scoop,kyb shocks
For this post the author totten was thanked by:
comerz
totten
Have thanks: 107 times
Postby TrooperJ2 » Sun Jan 04, 2015 8:32 pm
I've talked to you on Instagram haha... Good to make the connection on here as well. Truck looks good. I'm still interested in what that lift ends up looking like and its' performance. Any reason you went wth that particular kit as opposed to, say, a shackle, or a a more traditional leaf you add to the bottom of the pack?
-J 8)
-1990 Trooper 2.8 5sp. "Dallas"
1.5" susp/1"BL, 10 bolt Aussie, 4.77's, 33x12.5 BFG AT on 15x8 steelies
-1997 Rodeo 3.2- Blown engine and sold for scrap
-1990 Trooper 2.8 5sp. SOLD
TrooperJ2
Mi Amigo
Has thanked: 8 times
Have thanks: 14 times
Postby comerz » Mon Jan 05, 2015 12:03 am
Thanks guys. And yeah I own 4x4isuzu on Instagram. Lol. And well, I wanted the rear to be stiffer and I couldn't find the traditional add a leaf, supposedly auto zone discontinued them, and this was only $45!! I really hope it works. Kinda nervous about it...
comerz
Postby mustanger999 » Mon Jan 05, 2015 1:41 am
Does it go in the bottom of your spring pack to curve the springs?
Truth. The pill that everyone wants, but cant seem to swallow.
'93 Trooper RS, 3.2, SOHC head swap, 3" suspension lift, ARB bullbar, 16" Rodeo Flakes, 285/75r16 Corsa A/T,
'89 Trooper RS, 2.6 5spd, Smittybilt rear bumper Sort of build thread
GONE'89 Trooper: 2.6 5spd, Weber 32/36, Round eye swap, 3" body lift, Sliders, Auto-Meter center cluster, Hand throttle. Build thread
SOLD '93 pickup: 2.6 mfi, 4x4, 5spd, Passport Bucket Seats, Intermittent wiper added. Build Thread: forum.planetisuzoo.com/viewtopic.php?f=15&t=72720&p=639130#p639130
mustanger999
Has thanked: 48 times
Have thanks: 82 times
Postby comerz » Mon Jan 05, 2015 12:44 pm
Yes it does
comerz
Postby comerz » Thu Jan 08, 2015 4:33 pm
Some more pictures. Tad is the man. He helped me figure out how to fix the picture problem
comerz
Postby comerz » Thu Jan 08, 2015 4:45 pm
More pictures
comerz
Postby comerz » Thu Jan 08, 2015 4:50 pm
The lift goes on tomorrow
comerz
Postby TrooperJ2 » Sat Jan 10, 2015 11:02 pm
Any updates? Get the lift on?
-J 8)
TrooperJ2
Mi Amigo
Postby comerz » Sat Jan 10, 2015 11:15 pm
Yeah buddy!!! 3.5 inches of difference
comerz
Postby comerz » Sat Jan 10, 2015 11:24 pm
Also bought a bigger shackle to put on there. I plan on putting those on there tomorrow. At some point in time I'll do a long a arm setup with calmani torsion bars, short bump stops, and balljoing spacers to get even more lift out of her. Then when I get money, SAS.
comerz
Postby TrooperJ2 » Sun Jan 11, 2015 1:23 am
Gonna worry about a diff drop or just leave that alone till SAS?
-J 8)
TrooperJ2
Mi Amigo
Postby comerz » Sun Jan 11, 2015 2:10 pm
I might. When you do the diff drop, do you have to take the cross member that runs from a arm to a arm and lower it somehow?
comerz
Postby comerz » Sun Jan 11, 2015 2:33 pm
More shots of the lift
comerz
Postby comerz » Wed Jan 14, 2015 1:07 pm
Havent gotten to add the shackle yet. I gotta go find some bigger bolts for it and also get some metal to weld in between the shackles to keep it from swaying and bending lol.
comerz
Postby comerz » Thu Jan 15, 2015 7:57 pm
New cb hooked up.
comerz
Postby comerz » Sat Feb 07, 2015 2:06 am
Finally. Put the new shackle on. Put it on the lowest notch and cut it. Got about 2 inches out of it. Sitting at 4 inches over stock now. Very happen with it
comerz
Postby comerz » Tue Feb 10, 2015 12:51 pm
I dont have pictures yet, but last night i got my rims painted graphite and painted my tire carrier black (it was really rusty). Tonight I plan on painting my side mirrors and the panels behind the back windows and above the back windshield. Im really hoping I can run across some black bumpers and get rid of the chrome ones. At some point Im gonna try to find a new grille because all my clips are cracked. Not to mention I want an isuzu logo lol
comerz
Postby comerz » Wed Feb 11, 2015 4:58 pm
Last night I smoked all my lights. All of them are still as bright as usual because I used transparent paint. I did a light coat on my headlights and dark coats on all my others. Pictures to come tonight. I will be installing leds (theyre ordered and on the way) so if I get pulled over I can tell them I installed leds to compensate for the darkness (even though I didnt lose any light to them lol) and because I like my lights being bright as all hell.
comerz
Postby comerz » Wed Feb 11, 2015 11:04 pm
Pictures as promised
comerz
Postby TrooperJ2 » Thu Feb 12, 2015 4:51 pm
Lookin good, buddy.
TrooperJ2
Mi Amigo
Users browsing this forum: No registered users and 37 guests
