88 Trooper II LS
88 Trooper II LS
Postby Psychomidgit » Thu Feb 14, 2013 3:59 pm
Hey y'all, I'm Kevin and I'm working on building my Trooper. So far I've bought plenty of replacement parts and have pulled the drivetrain. Pics will be going up when I get back from the slope. First order of business will be the engine build, then the trans/transfer case and driveline. Following that will be the diffs, hopefully lockers, then a lift and go from there.
Psychomidgit
Trail Scout
Has thanked: 15 times
Have thanks: 6 times
Re: 88 Trooper II LS
Postby shaggydoink » Sat Feb 16, 2013 3:05 pm
Psychomidgit wrote:Hey y'all, I'm Kevin and I'm working on building my Trooper. So far I've bought plenty of replacement parts and have pulled the drivetrain. Pics will be going up when I get back from the slope. First order of business will be the engine build, then the trans/transfer case and driveline. Following that will be the diffs, hopefully lockers, then a lift and go from there.
Hey Kevin, can't wait to see some pics of your 88! :thumbup:
Has thanked: 807 times
Have thanks: 412 times
Postby Psychomidgit » Mon Feb 18, 2013 4:51 pm
Ok, well I'm out in a remote location without the ability to upload the new photos I took before I headed up north, so I'll load the previous photo and tell the story of how my Trooper came to be.
So, in July 2011 I came back from my deployment to Afganistan. I sold my 84 Chevy K10 to my buddy and decided that my H2 was too much attention (broken into twice in a year, once on base :evil: ) and repairing what my ex had done to it was gonna cost too much and I just didn't feel like it. So, I got a good offer for it and picked up something I'd never heard of....
It's an 09 Mustang Bullitt. It's an awesome car, and I owe almost nothing on it, but......
I live in AK, not so good in the winter, even with my abilities, lol. I missed my Chevy, but didn't feel like picking up another overpriced hackjob of a truck, with BAD redneck engineering that you find out here so often (we have no emissions). So, I started looking around, which brought me to a mom & pop dealer. I told them I wanted a $1000 4X4, and not in red. First, they showed me a red Kia Sephia (yes, I know that is not a 4X4, apparently he didn't...). Then he showed me a red Ford Tempo, if I remember correctly, and as you can imagine I was pretty pissed off at this point, lol. When I went to walk away he stopped me and said he had something that would fully fit my description, and showed me this....
He didn't know anything other than it was an Isuzu 4X4 with a 4cyl, so after looking at how good it looked for the most part I picked it up. I knew the coolant looked bad, and 3 days later the head gasket blew. And we also found out that the heater core was unhooked, I knew what that meant being up here especially. So, after trying to find a good replacement I gave up and went to the dealer and got a new one. I also had purchased new tires (the ones you see in the pic)and a battery. Last Christmas my buddy and I stripped the entire dash and replaced the heater core, but it's still not hooked up. I also got mad one day because my tail lights weren't working so I replaced everything in the fuse box, now everything works, lol. Now the Trooper is sitting outside the shop on base with the motor and trans out of it, ready for rebuild. :D
88 Isuzu Trooper II LS w/ 2.6L, Undergoing Drive/Powertrain Rebuild
91 Honda CRX Dx w/ B16A JDM Swap, Rear Disc Conversion, JDM Front End, JDM Rear Interior
13 Chevy Cruze LT RS w/ 1.4L Turbo, Trifecta Tuned w/ Forge BOV, All amber lights changed to white, shifter swapped and interior done with green accents, all silver interior pieces repainted in a Mercedes metallic silver.
88 LS Build Thread
viewtopic.php?f=15&t=68173
Look at this before "converting" to HIDs
http://www.danielsternlighting.com/tech ... d/HID.html
Psychomidgit
Trail Scout
Postby Psychomidgit » Tue Mar 12, 2013 9:46 pm
So, this past week I was back home and got to work on the trooper. Here are some pics from before, during the engine pull process.
That was it while draining fluids
I just thought this was cool, 3 isuzus of different generations, with different owners, in a row at the shop. Only time I've seen that in the last 5 years.
88 LS Build Thread
Psychomidgit
Trail Scout
Postby Psychomidgit » Tue Mar 12, 2013 9:59 pm
When I actually got home, the parts gods/Jerry had blessed me, lol. This is what I saw:
My mini parts heap
This is the Distributor fix, some sensors, and an FPR
power steering pump/lines, MAF, and gearbox
Crosslink and all balljoints
And proof that Moog isn't a cheap taiwanese knock-off :thumbup:
From Jerry I recieved my multifunction switch, heater core components, and wing window components. THANKS JERRY!!! :mrgreen:
88 LS Build Thread
Psychomidgit
Trail Scout
Postby Psychomidgit » Tue Mar 12, 2013 10:14 pm
Nothing was done to the truck at this time, but, over the next couple days we tore the motor completely down....
We placed the motor on a tire, on a roller cart, lol. That's right before teardown.
This is during the teardown.
It's now completely stripped down, but, the block is toast. a thrust washer was in the bottom of the pan so the crank ate the block. Oddly enough, the motor was running strong anyways, into the bay even. It looks like I've found another new motor, but we'll see. Hopefully it'll be there when I get home in 3 weeks.
88 LS Build Thread
Psychomidgit
Trail Scout
Postby shaggydoink » Wed Mar 13, 2013 7:46 am
Sucks to hear the block is shot, but cool to see the work you're doing, thanks for posting up! :)
Postby foytiX » Wed Mar 13, 2013 8:48 am
Bummer man, hopefully the motor you found comes through :) That is a lot of Isuzu's in the shop at once, seems like a bad omen or something :lol:
'90 trooper 2.6 MUA 3" BL 33's, 5.38 gears, 12 bolt locker, and more https://forum.planetisuzoo.com/viewtopic.php?f=15&t=499
'94 Trooper MUA "theBeater"....https://forum.planetisuzoo.com/viewtopic.php?f=15&t=67019
'94 trooper ls.....parts and engine donor
'95 trooper limited.....1" hockey puck lift https://forum.planetisuzoo.com/viewtopic.php?f=15&t=66472
'98 trooper.........parts and trans donor
foytiX
Has thanked: 74 times
Have thanks: 86 times
Postby Psychomidgit » Wed Mar 13, 2013 12:45 pm
I know right, lol
88 LS Build Thread
Psychomidgit
Trail Scout
Postby Psychomidgit » Wed Mar 13, 2013 7:16 pm
Looks like it will, many props to Richey, looks like he'll be my savior, lol. Between him and Jerry, this forum has shown me a new appreciation for it. :mrgreen:
Now I just need to assemble the troops to help me get this motor out of Richey's truck and back to anchorage, lol.
88 LS Build Thread
Psychomidgit
Trail Scout
Postby Psychomidgit » Fri Mar 20, 2015 6:43 pm
Hey everybody! I'm finally back and ready to get this project moving. My transmission rebuild kit just came in so I'm hopefully going to get to work on it this weekend! If I'm not able to pick it up today I will be working on the motor, so plenty of pics will be coming.
88 LS Build Thread
Psychomidgit
Trail Scout
Postby shaggydoink » Sat Mar 21, 2015 6:08 pm
Psychomidgit wrote:My transmission rebuild kit just came in so I'm hopefully going to get to work on it this weekend!
May I ask where you got this kit from?
Postby Psychomidgit » Sun Mar 22, 2015 1:08 am
Six States Distributors
88 LS Build Thread
For this post the author Psychomidgit was thanked by:
Psychomidgit
Trail Scout
Postby Psychomidgit » Sun Mar 22, 2015 2:38 am
This is how she looks after sitting for 2 years
Here's the block. I was tapping all the holes today at the shop.
Once done I'll clean it up and paint it.
Here's the finished head that needs to be assembled.
It's a cast #4! Thanks to Richey
88 LS Build Thread
Psychomidgit
Trail Scout
Postby shaggydoink » Sun Mar 22, 2015 8:26 am
Thanks for the reply on the rebuild kit. The engine is looking good, I hope the rebuild goes smoothly for you!
For this post the author shaggydoink was thanked by:
Psychomidgit
Postby Psychomidgit » Sun Mar 22, 2015 3:12 pm
Thank you, I'm hoping so too. Today I should be able to finish tapping the block, cleaning it and then possibly paint! We'll see.
88 LS Build Thread
Psychomidgit
Trail Scout
Postby 1TNLB » Mon Mar 23, 2015 6:59 pm
Good looking Trooper. Sorry to hear about the motor, but look at all the experience you are getting by having to rebuild.
Thank you for your service!
1TNLB
Postby Psychomidgit » Mon Mar 23, 2015 10:37 pm
Thank you, I was very surprised at its condition when I picked it up. Very true, and thank you for the support! Nice thing is that I was going to tear it down anyway. It's a true testament to how strong these motors actually are. I've never known a vehicle that could run so long and well without thrust bearings.
So I picked up the trans rebuild kit. The seal kit included says MSG on it though. Does anyone know if they use the same seal kit as the MSG? Or if the warehouse made a mistake?
88 LS Build Thread
Psychomidgit
Trail Scout
Postby Psychomidgit » Sun Mar 29, 2015 12:47 am
So I was at the shop most of the day today. I was sidetracked quite a bit helping a friend of mine work on his son's Lumina. But I noticed my engine kit and got curious because in the two years it had been there I'd never opened it... At all...
This is what I found:
New oil pump
Bearings
More bearings, core plugs, and oil galley plugs
Pistons!
And gasket kit with all the gaskets stated above
I thought it had a new camshaft but I'll have to check with the machinist when he gets back.
88 LS Build Thread
Psychomidgit
Trail Scout
Postby Psychomidgit » Sun Mar 29, 2015 12:57 am
And here's what I did with the block today:
This is it taped off
After taping it off I sprayed primer on it:
Tomorrow I'll be back at the shop and should get color and clear sprayed hopefully!
88 LS Build Thread
Psychomidgit
Trail Scout
Postby wmorrisiii » Sun Mar 29, 2015 9:57 am
Looks great, like the orange on the head!
The Duck Marsh Debutante
The Coonhound
wmorrisiii
Has thanked: 93 times
Have thanks: 201 times
Postby shaggydoink » Sun Mar 29, 2015 10:24 am
Keep up the great work, things are looking good!
Postby Psychomidgit » Sun Mar 29, 2015 2:28 pm
Thanks y'all, I'm heading to the shop after breakfast to finish the block.
88 LS Build Thread
Psychomidgit
Trail Scout
Postby Psychomidgit » Mon Mar 30, 2015 2:15 am
Hey y'all! Finally finished the block today at the shop!
This is the block after a couple coats of paint
And the finished block!
88 LS Build Thread
Psychomidgit
Trail Scout
Postby wmorrisiii » Mon Mar 30, 2015 8:39 am
Really nice job, and appreciated the fact that you posted this at 2AM. I think Im a fan of the orange, looks great!
The Coonhound
For this post the author wmorrisiii was thanked by:
Psychomidgit
wmorrisiii
Users browsing this forum: No registered users and 7 guests
