Toccoa's 2002 Amigo Sport
Postby Toccoa » Sat Nov 03, 2012 6:43 pm
Got her in July of 2012.
And then the adventure began...
Had issues trying to remove the spare tire
Hit 100,000 miles!
Replaced the Engine Oil Cap
Added various missing caps in the engine bay
2002 Rodeo Amigo Sport
V6 Auto RWD
Currant Red Mica Lagoon Blue Matte Metallic Thundercloud Metallic
1" Wheel Spacers
General Grabber AT2 255/70/16
1" Suspension Lift (coil spacers from Indy4X)
Build Thread Vinyl Wrap Samurai
Toccoa
Has thanked: 69 times
Have thanks: 58 times
Re: Toccoa's 2002 Rodeo Sport
Postby Toccoa » Sat Nov 03, 2012 6:47 pm
Went to a junkyard and found a soft top
Replaced all rubber coolant hoses because of a SMALL leak
Replaced EGR Valve
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby Toccoa » Sat Nov 03, 2012 7:19 pm
First Mod!
Removed Mud Flaps (only had three anyway)
BEFORE
AFTER
How it's done
Tools:
10mm socket wrench (use the short one)
Gloves (your hands will thank you later)
Pre-step for Front Wheels
Turn front wheel to full lock in the direction of the wheel you are working on
Step 1:
Locate and remove the following 4 bolts
Step 2:
Remove the mud flap
Step 3:
Replace screws back in their holes
Same steps for the other 3 wheels. Back wheels are easy. The fronts have one screw (inside one) that doesn't have a lot of room. That's why you turn the wheels and need the smaller wrench.
When you are all done. Your ISUZU will thank you.
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby Trooper King » Sun Nov 04, 2012 5:48 pm
Looking good Toccoa keep up the good work. 8)
Trooper King
Has thanked: 49 times
Have thanks: 10 times
Postby Doowrag » Mon Nov 05, 2012 3:00 am
Cheers for the mudflap write-up, always wondered how it was done.
I bet i made a big difference with new oil cap and no flaps, looking forward to seeing it evolve.
D
Doowrag
Postby Toccoa » Thu Jun 13, 2013 10:23 pm
Last time I got an oil change, I found this under my hood. :evil:
After a nice discussion on how a dirty rag is no substitute for a window washer fluid cap...
I got a new one. :D
This one even has the attached ring so they won't lose the cap next time.
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby Toccoa » Sat Jul 13, 2013 4:43 pm
Scored a Rodeo Sport cargo mat on eBay. Turns out the seller is also a planet member. Small world.
V6 Auto RWD
1" Wheel Spacers
For this post the author Toccoa was thanked by:
truelion07
Toccoa
Postby Toccoa » Thu Aug 01, 2013 8:59 pm
Sometimes it's the little things.
The door switches on my Rodeo Sport look every bit of 11 years old. Time to replace them!
PARTS: You will need ISUZU Part # 8971682070 for each door switch you plan to replace. NOTE: This is not the part # for the tailgate switch.
STEPS:
STEP 1) Open door. Locate door switch. Unscrew door switch.
STEP 2) Gently pull switch out from the body. Be sure to pull it far enough out so that the wire plug doesn't try to to back into the hole.
STEP 3) Unplug switch from wire plug. The trick is to push in the catch on the bottom. I had to use pliers or my driver side, but I used my fingernail for the passenger side. You could probably use a flat-tip screwdriver too.
STEP 4) Compare your parts. I think this was a good decision. The old one just looks awful.
STEP 5) You are basically reversing steps here, but be sure to slip the top part in first a slight angle. This will allow it to lay up close to the body.
STEP 6) Replace the screw and admire your work.
NOTEWORTHY:
The driver side, which is what I showed in the pictures, will have two wires coming out of the plug. The passenger side will have one. Don't freak out and think you yanked out a wire. You didn't (unless you have no wires and in that case you did).
And that does it. Not a big update as far as things go, but it takes your Isuzu one tiny step closer to looking like new again.
V6 Auto RWD
1" Wheel Spacers
truelion07
Toccoa
Postby Toccoa » Sun Aug 04, 2013 12:20 pm
Badges? We don't need no stinking badges!
Well, actually I did. The "Sport" part of the Rodeo Sport badges on my Zu were looking pretty sad. Thanks to gilaman for getting the part # (2-90042-008-0).
First, a little before and after.
Here's how I did it.
1 ) I taped off my Sport badge. I lined it up from the right side (the "T"), the top and the bottom from about the "O" to the "T". This is enough to allow perfect fitment of the new badge when you are done. Then you Goo Gone. Let is soak about three minutes. The badge should start feeling weak around the edges.
2 ) Take some dental floss and saw your way through the adhesive backing. You might need to reapply some more Goo Gone as you go.
3 ) Once you have enough of it separated, you can gently pull the rest off.
4 ) The old badge is now gone, but I still have a lot of work to do.
5 ) More Goo Gone and a plastic scraper were needed to get off the hardened adhesive. This took about 30 minutes to do.
6 ) Finally got it all cleaned up. You will need to get some soapy water to remove the Goo Gone residue. Be gentle. The painters tape can easily be moved at this stage.
7 ) You can see the difference between the new and old here.
8 ) Now carefully peel the backing from the new badge from the right ("T") to about the "R". This stuff is very sticky, so take your time. Once you get it laying down how it needs to, just keep pulling more of the backing away until you are done. Now that it is on. gently press the badge in all over to make sure it has a good bond. Pull off your painters tape, hit is with some spray wax and enjoy the chrome!
V6 Auto RWD
1" Wheel Spacers
gilamantruelion07
Toccoa
Postby Toccoa » Tue Oct 29, 2013 5:31 pm
Chronicled in great detail in my "Vinyl Wrap Samurai" thread.
I took my Rodeo Sport from this:
... to this!
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby Toccoa » Thu Aug 21, 2014 8:28 pm
Decided it was time for my Zu to spread its wings... er wheels. :)
Gave my Zu a wider stance with 1" wheel spacers and it came out great!
The Spacers:
Here's the comparison pic:
Another view with the spacers on:
I debated going with 1.5" spacers, but with no lift, stock wheels, and skinny tires (245/70/16), my Zu is no trail rig. These pics don't do it justice, but my Zu really does have a more athletic stance now.
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby Grumpfrompahrump » Thu Aug 21, 2014 9:17 pm
Those little cooling hoses at the throttle body are largely forgotten, so they tend to spring leaks later in their life. I found this out the hard way. If you have never changed them, I would recommend it. They are cheap and still available from Honda.
Steve
2000 Amigo Ironman, 3.2L Auto 4WD
1982 Cadillac Fleetwood Hearse
1927 Ford Model T Roadster w/327 Chevy
Grumpfrompahrump
Has thanked: 4 times
Have thanks: 51 times
Postby Toccoa » Fri Aug 22, 2014 8:12 pm
Grumpfrompahrump wrote:Those little cooling hoses at the throttle body are largely forgotten, so they tend to spring leaks later in their life. I found this out the hard way. If you have never changed them, I would recommend it. They are cheap and still available from Honda.
Agreed. Replaced all of my coolant hoses a few years back after my Zu's "smoking" incident. :lol:
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby Toccoa » Fri Aug 22, 2014 8:23 pm
I've heard it said before from others, but with the 2" wider track, my Zu really does feel more planted. 8)
I'll try to take some more pics tomorrow.
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby Toccoa » Sat Aug 23, 2014 9:28 pm
As promised, more pics. :mrgreen:
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby bradzuzu » Sun Aug 24, 2014 2:09 am
Looking great !! But,,, what's going on with the two silver sections ?? It's amazing what that spacing does huh ??
Has thanked: 220 times
Have thanks: 390 times
Postby Toccoa » Sun Aug 24, 2014 10:46 am
bradzuzu wrote:Looking great !! But,,, what's going on with the two silver sections ?? It's amazing what that spacing does huh ??
Thanks. It really is amazing what such a small change can make. It will look even better when I get more aggressive tires and a small lift.
About those colors. I'm playing around with changing the color again. :drunken: I've been sticking a few colors on and driving around to see how they look at different angles and different lighting. So far, everyone likes that one the best.
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby bradzuzu » Sun Aug 24, 2014 1:55 pm
Haha like a big kid !! It looks cool , I'll be watching :)
Postby Toccoa » Mon Sep 15, 2014 8:05 pm
Scored a mint (but stinky :lol: ) soft top from tonnydoodles. :thumbright:
Gave it a nice bath and now I have a sweet smelling soft top WITH WINDOWS! Switching out the tops every few weeks because of rain was getting a little old. Now I can run a soft top until winter. 8)
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby bradzuzu » Mon Sep 15, 2014 9:33 pm
Very nice !! I do and don't miss my soft top, it's so much quieter with the hard top...
Now I see the silver stripe on the back corner :) yet no new pics or explanation...
Looks sweet man !!
Postby Toccoa » Mon Sep 15, 2014 9:53 pm
bradzuzu wrote:Very nice !! I do and don't miss my soft top, it's so much quieter with the hard top...
Looks sweet man !!
Had a feeling you might notice that. :lol:
Did it as a what-if and it came out pretty nice. Starting to dig it better than the darker color. With Fall weather finally starting to take effect, you might see some more action on the vinyl front. :wink:
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby benjammin8807 » Tue Sep 16, 2014 10:42 am
awesome ride! I have a RS same year I'm slowly modifying but was wondering where I could find a write up for removing the hard top?
'02 Rodeo Sport Hard-Top 3.2 V6
'95 Rodeo 3.2 V6 (Blown Head Gasket)
Image Image Image
benjammin8807
Have thanks: 5 times
Postby Toccoa » Tue Sep 16, 2014 12:46 pm
benjammin8807 wrote:awesome ride! I have a RS same year I'm slowly modifying but was wondering where I could find a write up for removing the hard top?
Thanks! Start a thread so we can all see your RS.
Here are the instructions I used to take my hard top off.
http://www.walkerdowney.com/ryanendres//isuzu/amigotop.pdf
It's pretty straight forward. I would recommend having someone else help with removing the top and rear window. To make things easier, remove the rear sunroof before you begin. You'd be surprised how heavy that thing is. Once I have the top on the ground (moving mat), I reinstall the sunroof. Note: Have your helper hold the front edge of the top when you reinstall the sunroof. The weight and force of you putting it back on can make the hard top want to lean forward. I also like to store my bolts and brackets in ziplock bags for safe keeping. Hope that helps.
V6 Auto RWD
1" Wheel Spacers
Toccoa
Postby benjammin8807 » Fri Nov 07, 2014 12:38 pm
Very nice I'm about to go outside and take the mudflaps off of my 02 rodeo sport. Thanks for the little write-up for me haha
Image Image Image
benjammin8807
Postby Loser » Sun Feb 01, 2015 9:04 pm
How are you painting your Rodeo and what is the cost?
Loser
Has thanked: 2 times
Users browsing this forum: No registered users and 6 guests
