Hatfield's 2000 Trooper Build
Postby Hatfield » Thu Mar 01, 2012 1:02 am
Well, I figured it's about time I made a build thread. I am horrible about remembering to take pictures, and am no Dr. Suess so bare with.
As many of you know, I've got a 2000 Trooper. Bought it bone stock back in 2007 from a older couple with 80k on it, and I've had pretty big plans ever since. I always loved the rugged styling of the Troopers, but what really sold me on them is that you rarely see one modified and they're great bang for your buck.
First thing I did was throw on a Yakima roof rack so I could haul my mtn bike to the local trails. I also spent plenty of time roaming out in the nearby National Forest.
Next on the list was to replace my old tires. I found a hell of a deal on some BFG KMs when they were being phased out, so I picked up 5 in 255/85. I had no lift, and they rubbed some in the front on the top inside edge of the fender flares, but it wasn't too bad.
Shortly after that, I rear ended a BMW M Coupe :-| . The damage wasn't very bad, but it bent up my bumper support. I saw Endo selling his Independent4x bumper in the classifieds, so I snatched it up.
She was starting to come together quite nicely. I soon started trying to piece together a lift with the money I had on a college budget. Luckly, I found a set of used OME N85s for the rear for $40, so I was able to stay under $400 with those and new 929 and N65s for the front. The N85s offer a ton of flex out of the Troopers.
Now that I had a lift, it was time to do a little off roading. I kept it off the hardcore stuff since I didn't have sliders on yet.
Also went mudding enough to finally get stuck. 10ft farther and I would have been home free. She got a little dirty.
I wanted to add a set of sliders, but am too cheap to pay $400 for pre made ones. I found a local guy who was doing a big order from Trail Gear with free shipping, so I had him order me a set of 67" sliders. Only bad thing was the Trooper's frame hangs a nut hair lower than the rocker panels, so I installed a 1" body lift to solve that problem. I spent about $45 on the body lift by ordering the pucks from Performance Accessories and the bolts from Fastenal, not bad. Here's the final ride height she sits at today. I have a 1" spring spacer in the garage, but I don't think I want to go any higher right now.
2000 Trooper - AR5 swap, 4.77s w Aussie & ARB, TeraLows, 285/75 Goodyear MTRs,
Indy4x bumper, OME lift with N85 shocks, 1" BL, TG sliders, M8000, 20" LED, dents
2007 Acura TL Type S - the daily
1995 Nissan 240sx - the racecar
Hatfield
Have thanks: 25 times
Re: Hatfield's 2000 Trooper Build
Postby Hatfield » Thu Mar 01, 2012 1:09 am
Sadly I haven't gotten around to welding the sliders on yet, but they are the perfect length for Troopers. We did need to cut the mounting legs to length to match the curvature of the frame rails. Hope to have them on in the next weekend or two, and at the same time move my front bumper up 1" to fill the body lift gap. The sliders kick out at about a 20" angle to keep the body from taking too much damage.
I heard John had a RS he was parting out, so I picked up his 4.77s. I also bought some goodies to put in them, an Aussie for the front and an ARB for the rear. I had the ARB installed locally for $100, and did the Aussie myself. Aussie was not hard at all, but I never could get the clearances between the cam gears to match the specs in the manual with the stock shims. It was a lot tighter than specified, but Matt at Indy4x said they set them up tight all the time and they've never had one break. I'm not as worried about the Aussie as my 4.77 Ring gear. Oh well, if it blows I will just chop off that IFS. Image
Around Christmas time, Amazon had M8000s for under $500 shipped, so I decided it was as good a time as ever to get one. I did not have room to mount the control box on top of the winch, so I chose to mount it under the hood (pics to come). Also got a 20" light bar, which is awesome. The way the Indy4x bumper is made, round aux lights would stick up too far and look funny, but the light bar looks tits.
I've got a ton of stuff I need to install, just have to get the beater running good so I can quit DDing the Trooper and start wrenching. The transmission started to slip between 1st and 2nd the other day, and it bummed me out for a while but then I had an idea. I found a nearby 99 5spd parts Trooper, and I am going to go pull everything I need off it and convert mine. I honestly can't wait to have a 5spd under her, the driving experience will be so much more fun. Plus with the 4.77s, 3:1 tcase, and 3.75 1st gear, I'll have a 55:1 crawl ratio. :mrgreen:
Right now here is what I have for the Trooper (not all installed yet):
OME N65 shocks front and N85 shocks rear with 929 coils
1" Body Lift
BFG KM Mud Terrains in 255/85r16
Trail Gear 67" Sliders
Independent 4x bumper
Warn M8000
20" Rigid knockoff lightbar
4.77s with Aussie Front and ARB Rear
3:1 Transfer Case nonTOD
Independent4x HD Tie Rods
Swaybar Disconnects
B&M Transmission Cooler (if you want it lmk, won't be installing)
Magnaflow muffler with 2.5" pipe from merger back
Now that I got a phone with a decent camera, I am going to try to remember to take pictures of the project. It always helps me to see pictures, and hopefully I can be a little help to others in the same boat.
For this post the author Hatfield was thanked by:
ozfest
Hatfield
Postby beto » Thu Mar 01, 2012 12:20 pm
Man I had been waiting for a while for your build thread. The trooper is looking great with the winch and light bar, and front and rear lockers!? Dude that´s awesome :cheers: Keep the pics coming!
2002 Trooper, 3.1 Turbo Diesel Intercooled
Front Aussie Locker // OME 919´s // Daystar 1.5" spring spacers // Pro Comp ES9000´s // ARB Bumper // 12,000lb Winch w. Synthetic Rope // BFG KM2 255.85.16 on Snowflakes
Lifetime Led Headlights // RigidIndustries Dually D2´s // Aisin Hubs // 4 LED Roof Spot Lights // OEM Yakima Roof Racks // Airtec Snorkel // K&N Filter
video // video // 12/2010 ROTM
beto
Have thanks: 38 times
Postby onebadtrooper » Thu Mar 01, 2012 8:12 pm
sweet trooper love that color combo, How you liking the 255x85's? I'm thinking of that tire in a KM2.
_Chris..
89 trooper, 6"lift, 35x13.50R15 baja claws, tera low 3.07's and 5.38's.custom bumper F&R, built 3.4L,safari snorkel.
93 trooper s SOLD..
2001 trooper 3.1L turbo diesel conversion ,yokahama geolander a/t's 265x75r16, ARB bull bar. 2wd to 4wd conversion, rock sliders, ARB roof rack with IPF lights, ARB front locker.
two troopers in a family of isuzu's
onebadtrooper
Postby Hatfield » Thu Mar 01, 2012 9:41 pm
Thanks guys!
I really like the 255/85s. Sometimes they don't track as well as I'd like, but I've heard the same about every tall tire.
Hatfield
Postby COYOTE102076 » Thu Mar 01, 2012 10:28 pm
That is one SWEET Trooper! :thumbright:
-==Kevin J.
1994 Trooper "The Phoenix": given to my 16 year old son
My Rides: 1) 2015 Ford Fusion 2) 1984 F150 5.8L H.O. engine 3) some sort of 1st Gen. Trooper coming soon ….. I HOPE. :headbang:
COYOTE102076
Has thanked: 76 times
Have thanks: 37 times
Postby Med!c » Thu Mar 01, 2012 10:28 pm
so I'm a little puzzled by your 4.77 approach. Is the ARB for the 12-bolt modified or the regular good old 12-bolt? I know people install the old 12-bolt axle in the rear so they can install other gearings, but you never mentioned getting a 12-bolt so Im a little confused on how you're going to do this. I just dont want you to find this out later on. Though I suspect you've already done your research. Anywho, the trooper is coming along real nice! love that gray color! Really wanna see those rock sliders get on there!
00' Trooper 4x4- V6 3.5L
5-Speed Manual Aisin AR-5
Isuzu 12-Bolt Modified LSD
Isuzu 10-Bolt Aussie Locked
BGF AT T/A KO 285/75/16
Miss my old rodeo.
Med!c
Have thanks: 87 times
Postby Hatfield » Thu Mar 01, 2012 11:16 pm
The ARB is for the regular 12 bolt. I already have the 4.77s installed on it, waiting to get a wide 95-97 12 bolt rear to put them in. Good call, don't want someone to read that and think the 4.77s will work in a 98+ modified 12 bolt.
The rock sliders will be on very soon. Might not be this weekend, but definitely within the next two.
Hatfield
Postby streetersam » Thu Mar 01, 2012 11:52 pm
So first of all, sweet trooper! Looking really good...
But I'm a little confused...I was under the impression the newer troopers (98-02) had the wider track rear axles
I cant change the gearing until I swap the axles?
streetersam
Has thanked: 23 times
Have thanks: 17 times
Postby Hatfield » Fri Mar 02, 2012 12:10 am
Correct, 98-02 have modified 12 bolt rear axles, which are the same width as the 95-97 wide track "regular" 12 bolts. The only way to get lower gear ratios is to swap in a regular 12 bolt, unless you stumble upon Iceland gears (more rare than 4.77s).
Hatfield
Postby streetersam » Fri Mar 02, 2012 12:14 am
Yuck! That totally sucks. What the heck was the benefit of that, I wonder?
streetersam
Postby Hatfield » Fri Mar 02, 2012 12:24 am
Benefit of what, Isuzu switching to the modified 12 bolts? I guess they did it for extra strength since the 3.5L puts out so much power haha. I've never really heard of anyone breaking regular 12 bolts though, so I don't know. There was rumor of Troopers getting v8s before they pulled out of NA, so that might be why.
I doubt you are referring to regearing, but I am doing it to gain some mpg and power back after adding bigger tires. It also increases your crawl ratio, which is good for offroading. It isn't hard to swap rear axles, but the front is a different story.
Hatfield
Postby Med!c » Fri Mar 02, 2012 1:39 am
Yup. V8 was in the plans, hence why the 98+ troopers also got a new manual transmission as well. It was going to be a 4-4.5L v8. Something in that range. According to measurements the 12-bolt modified is as good as a Dana 60 while the regular 12 bolt is comparable to a Dana 44, but a bit stronger.
This is why I feel like 98+ troopers should be called 3rd gens. New trans, engine, facelift, rear axle. Now days all they do is do a facelift and call it a new geneneration . It would help with some confusion as well.
Anyways can't wait till you're done! :D
Miss my old rodeo.
Med!c
Postby streetersam » Fri Mar 02, 2012 4:55 pm
Hatfield wrote:Benefit of what, Isuzu switching to the modified 12 bolts? I guess they did it for extra strength since the 3.5L puts out so much power haha. I've never really heard of anyone breaking regular 12 bolts though, so I don't know. There was rumor of Troopers getting v8s before they pulled out of NA, so that might be why.
Yeah I was referring to part I
That totally sucks that I have to switch axles though, I've been considering regearing when I move to 33's
Anyways, sorry to take you off track, I'm stoked you finally started a build thread! Love what you've done so far
I'm surprised you havent upgraded the t-bars after the weight of the bumper & winch! Unless you did and I missed it...
streetersam
Postby Hatfield » Fri Mar 02, 2012 6:08 pm
No worries about keeping it on track. I don't really think any build thread on this site has stayed much on track.
I honestly think it rides pretty well with stock tbars. That makes it hard for me to justify spending $500 on HD tbars, but I might pick some up if I can find used ones for cheap. At some point I want to hack the IFS off and put it on FJZ80 axles with coilovers in the front :twisted:, so I'll probably just save the $$$ for that project.
Hatfield
Postby onebadtrooper » Fri Mar 02, 2012 11:26 pm
Same here, I'm pretty happy with my stock t-bars. I'm not sure if 2wd t-bars are different or not but mine are going great after adding the front diff, bumper, and winch.
93 trooper s SOLD..
onebadtrooper
Postby streetersam » Fri Mar 02, 2012 11:38 pm
Hatfield wrote:No worries about keeping it on track. I don't really think any build thread on this site has stayed much on track.
Good point, I keep forgetting about that! I do plan on SAS in the future, so it's good to know I can do a lot with what I have!
Yet another great thing about Isuzus- there's some damn stout hardware on these things!
streetersam
Postby Hatfield » Sat Mar 17, 2012 9:06 pm
Did a few little things today. I installed 3 "OH SH1T!!" handles, one on the DS A pillar, and two in the very back.
Also got around to wiring up my winch all the way. I still need to relocate a few brackets on the bumper before I winch on it hard. Here's how I mounted the box. Don't hate, it's holding up good so far.
Friday I had some time off, so I did a little wheeling at Stoney Lonesome, the local OHV park. It's a decent park, plenty of easy/moderate stuff, and a few advanced hill climbs. I was solo so I only got one poser pic.
I also received confirmation on starting a new job with Boeing April 27th, so Monday I am putting in 2 weeks notice. That should give me 3.5 weeks off to replace my trans, put gears/lockers in, and do a few little other things that need to be done. This thing will be a blast after that.
Hatfield
Postby RoadRanger » Sat Mar 17, 2012 9:25 pm
AWSOME rig man!! i'd love to do a build like that to mine, it really looks perfect so far. love the dark grey color too!!
'99 Isuzu Trooper SE, 3.5 litre DOHC V6, 4x4, 5 speed manual trans. mostly stock :D PIAA fog / driving lights, 265 series mastercraft courser AXT's, aftermarket no-name muffler, 1" OME rear lift coils
RoadRanger
Postby TrooperBeast00 » Sat Mar 17, 2012 9:33 pm
Just wanted to comment on 2 things...
Your truck looks awesome and the color is just right 8)
Also, your profile icon is great.. my all time favorite movie is Office Space.. so win win in my book :wink:
-Randy-
2000 Trooper 3.5L V6 automatic (LS Wannaba)111,000 on the ODO Rebuilt Engine now a rebuilt Tranny!
Incubus 511 16x8", 265/75/16 Nitto Terra Grapplers, OME 929 Coils=1.5" Lift, Pro-Comp ES9000 SWAYAWAY T-Bars, WAAG tail guards, Polar Bear bumper guard, Diesel Hood Scoop, Recon running lights, custom class lll hitch w/backup lights, RAM brush guard - Hella 500FF lights, Yakima Roof Rack, CompuSTAR security, Chrome LS kit, Multimeter/Map light Installed, Euro Window Visors, body molding, Rugged Ridge Inclinometer
http://www.cardomain.com/ride/2829025
TrooperBeast00
Postby jwood1016 » Sat Mar 17, 2012 10:13 pm
Looks like someone is making some money :D Can't wait for the build your troop is looking sweet.
John
2002 Trooper
3 inch lift and 33's
jwood1016
Have thanks: 18 times
Postby streetersam » Sun Mar 18, 2012 1:40 am
Awesome dude! No one should hate, that's a great place for the winch box! I was wondering where I'd put it when I get one myself...
You get some SERIOUS flex too
And congrats on the new job! Can't wait to see the troop in action after the upgrades
streetersam
Postby chuffer » Sun Mar 18, 2012 1:09 pm
Winch controller under the hood is a good idea. As for where you mounted it, not a huge fan, but if it works and is securely mounted, then great.
Just a question, though, was it a cable length problem or is there no other space under the hood in the newer troopers?
-Chris
Shiba Wichern Cellars - Pinot Noir from Oregon -
chuffer
Has thanked: 58 times
Have thanks: 137 times
Postby Hatfield » Sun Mar 18, 2012 4:35 pm
Thanks for the compliments guys!
I mounted the box right there due to lack of room under the hood on newer Troopers. It is a little close to the fan and the radiator hoses, but I put the wires in heat resistant tubing and zip tied them out of the way. Thought about mounting the box in the drivers side corner by the brake booster, but since I am converting to 5spd, the clutch reservoir will be there. There really isn't any better solutions that I could see without fabbing a bracket and drilling new holes in something.
Hatfield
Postby beto » Mon Mar 19, 2012 10:44 am
Hey congrats on the new job! Good things to come for you and your trooper.
That last pic is awesome. By any chance do you know the extended length of the N85´s?
beto
Users browsing this forum: No registered users and 8 guests
