98 Honda Passport torque spec
Use this forum to test posting messages and pictures before posting on the actual forum. If you are a new user, this is a great place to learn how to post
Postby Richard10 » Sun Aug 09, 2020 3:02 pm
Need help
What is torque specs on rear differential bolt ?
And EGR ? I have a manual but it doesn’t show.
Thanks
Richard10
Re: 98 Honda Passport torque spec
Postby joens » Wed Sep 02, 2020 11:25 pm
When there is a bolt I want to torque and the service manual doesn't give a torque I use a standard torque chart such as this one from Fastenal https://www.fastenal.com/content/merch_ ... 0Guide.pdf just find your bolt dimensions and grade . I would think the items you mentioned might not have a spec different than standard torque specs.
1995 Trooper
2000 Trooper converted to Manual Transmission
2001 Trooper , Parts Donor
joens
Postby joens » Thu Sep 03, 2020 8:52 am
Keep in mind most standard torque specs are based on the fastener going into steel or iron , if the fastener is threading into aluminium the torque spec will be decreased. so look for a spec sheet that includes that.
1995 Trooper
joens
Postby 99isuzorodeo » Fri Feb 12, 2021 4:33 am
Richard10 wrote:Need help
Thanks
My Manual Says 30 Foot Lb DOR DIFF bolt, EHR , I couldnt find
99 rodeo LSE; brush guard; rear spoiler; tail guards; OME 2912 rear coil springs for 3" lift; OME rear shocks 60004; OME front shocks 60031; 2000+ corner lights; led head lights; led fog lights; t-bars cranked 3" front end lift
99isuzorodeo
