Well, I've finally gotten myself an Isuzu, and I'm working to get a few things squared away to get it 100% into shape. The truck came from Florida, and the heater core has been bypassed, presumably because it was leaking, but I suppose it's technically possible that someone did that so that the the core wouldn't be hot all the time, making the A/C work better (yeah right). I figure I'll hook it back up and be pleasantly surprised if it doesn't smell like coolant.
Anyhow, while digging about online, I found the following instruction list from BroncoDave042163 in this old thread:
My question comes down to #s 12 and 13, which refer to the instrument panel, but I assume are actually for the dash itself? Also, the truck has A/C, so I'm guessing there's more to it, such as evacuating the A/C system and then re-charging it?
Perhaps I just need to leave well enough alone?
Tom
- Disconnect battery ground cable and drain radiator.[/*]
- Disconnect heater hoses at core and plug core tubes. [/*]
- Remove glove box hinge pins and slide out glove box.[/*]
- Remove steering wheel.[/*]
- Unscrew instrument cluster hood screws and cluster assembly screws.[/*]
- Remove meter hood and cluster assembly.[/*]
- Disconnect speedometer cable.[/*]
- Remove side trim.[/*]
- Remove fuse box screws.[/*]
- Remove right and left air defroster ducts.[/*]
- Remove steering column bolts and lower steering column.[/*]
- Pry out instrument panel screw covers.[/*]
- Remove 10 instrument panel screws and remove instrument panel.[/*]
- Remove heater assembly bolts.[/*]
- Remove heater assembly.[/*]
- To install, reverse removal procedure.[/*]
Tom
