Call me stupid but...
Postby TroopDawg » Mon Oct 26, 2020 11:23 am
I have the head completely off a 4ze1 engine. Oil pump is removed. Water pump is also removed!
Just bought the truck and the past owner said he put some sort of sealant in the coolant system in 2006 that was supposed to be delluted with water. He said the truck instantly over heated then felt like it was running on 3 pistons.
My guess. Warped head and a failed gasket.
When i removed the head... Holy hell! Every port was filled and clogged with a “metalic like jb weld sealant”.... i unclogged all the ports while using a vac to avoid dropping anything into the ports. I will be buying a new radiator and water pump... one question i have that might be a stupid one, is this...
While looking at the top of the block, what ports are water and what ports are for oil. I have a micro power washer that id like to chase out the water passeges with. I dont want to fill an oil port lol.
The “Green New Deal,” is the genicide of “Classic American Culture and our Generational Past Time.” -California Citizen
NO DEAL
TroopDawg
Has thanked: 79 times
Have thanks: 7 times
Re: Call me stupid but...
Postby TonkaToy » Mon Oct 26, 2020 12:31 pm
My first thought is...
Run Forest, run!!
Mike M.
Richmond, VA
1994 Trooper LS 3.2 DOHC 5spd Trail pig
2002 Trooper SOLD
1989 Trooper LS SOLD
2015 Honda Accord (DD)
2016 F-250 (Tow rig/Workhorse/Plow truck)
1987 Country Coach 40' 300hp Turbo Cat Diesel Pusher (restoration project/family camper/neighbor annoy-er/Prius deterant)
TonkaToy
Has thanked: 36 times
Have thanks: 24 times
Postby TroopDawg » Mon Oct 26, 2020 2:49 pm
Well. I did it. I was able to look at the head and spot the oil ports. I took a pic and marked them for anyone here to see. All the other holes are for bolts and water.
NO DEAL
TroopDawg
Postby gwana66 » Mon Oct 26, 2020 3:26 pm
If it clogged those ports, it also clogged the radiator. And the heater core. And who knows what else. Coolant also circulates through the head.
Even the hubs are manual now.
2002 Grille and headlight swap
gwana66
Has thanked: 14 times
Have thanks: 266 times
Postby DSUZU » Mon Oct 26, 2020 4:29 pm
If I understand him correctly, he already managed to unclog the head. On the block, I would also go as far as removing the coolant pipe from the driver side, the pipe plugs from each side at the bottom, And to be sure, as long as it is this far opened up, pop the freeze plugs out of each side of the block. Dennis
Has thanked: 278 times
Have thanks: 919 times
Postby TroopDawg » Mon Oct 26, 2020 6:29 pm
The head is getting hot tanked and i already have a new radiator and heater core! But you are right
NO DEAL
TroopDawg
Postby TroopDawg » Mon Oct 26, 2020 6:31 pm
I hadnt thought of the freeze plugs! That would make for great access! Btw, i also used a nitrogen tank with a regulator set to 300 to blow loose whatever i could in the block! I did NOT pressurize the block to 300 of course. There is plenty of ventelation in the block to not be effected by a 300 psi blast of air! Broke up surface rust well between rinses
NO DEAL
TroopDawg
Postby Skeletor » Mon Oct 26, 2020 7:15 pm
TonkaToy wrote:My first thought is...
Run Forest, run!!
exactly.....well, until you tear it down..and be able to see what damage was done...and crush the numbers..in terms of what it needs
a true labor of love...
1990 Trooper V6 (sold) 1991 Trooper LS V6, (sold) 1990 Trooper V6, 2006 Pontiac Solstice,(sold) 1966 MG Midget, 1987 Pontiac Fiero GT
Skeletor
Have thanks: 42 times
Postby TroopDawg » Mon Oct 26, 2020 7:39 pm
The block is in great shape. No rust in the oil ports and the cylinder walls are great. Drained the oil and that was looking great as well! I can fill up the cylinders with WD-40 and they will stay filled over night! So i know the rings are tight. I have the cab off right now so i plan on doing the fuel pump and a new clutch just because.
All the damage has happened within the water system!
So the head is being hot tanked, remachined and rebuilt. New radiator, water pump, heater core and hoses. Ive rebuilt a few duramax engines that were in worse shape. I have a feeling this is going to be a good running engine. Just had a shitty owner in its past.
It beats the 2.3 block that im replacing it with. That one had a hole the size of a basketball in the bottom of it.
NO DEAL
TroopDawg
Users browsing this forum: No registered users and 7 guests
