Planetisuzoo.com Forum Index Planetisuzoo.com
Welcome to the Planetisuzoo Forums!
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   GalleryGallery   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Pinouts for 2004 Axiom changer/CeNet capable?
Post new topic   Reply to topic    Planetisuzoo.com Forum Index -> Audio & Electronics
View previous topic :: View next topic
Author Message
2004Axiom
Newbie
PostPosted: Thu Feb 09, 2006 3:40 pm    Post subject: Pinouts for 2004 Axiom changer/CeNet capable? Reply with quote
Hey all.
I've got a 2004 Axiom and have been dying to add an aux input to it. For a quick back story, I've been looking for Axiom adapters and came up empty handed because I guess it's not profitable for a company to develop aux input adapters for a vehicle with low production numbers.
Anyway, I thought I'd go the other route and look for "Clarion" aux input adapters as they make the deck and changer for the Axiom. And sure enough, it uses that same "plug" as the CeNet sytems that they sell.
So I bought the CLR-AUX product from pie.net and I was axiously pacing until it arrived. I hooked it and up and got the following conditions:
1. Audio from changer is good
2. Deck can control changer
3. Data displayed on info center correct
4. Switch to aux input and it goes silent.
5. To restore CD audio requires unplug/replug and turn ignition back on
I've used 2 different RCA to 3.5mm cables, with an MP3 player and a Sirius PnP and got a second CLR-AUX. So I've basically used two of everything.
So where I stand is this: the Axiom cable looks like CeNet but must have a subtle difference. 8 of the 13 pins pass straight though the PCB, with the 5 remaining pins running into the audio relay circuitry. So I assume we're looking at L+/- and R+/- with one other mystery line.
But the fact that the unit plays audio from the changer and you can control everything leads me to believe that the pinouts for the Axiom match the CeNet standard. I mean it's not going to work if the VDC line is on the Data line or the ground is on the R+ line right? Evil or Very Mad
I'm going nuts here trying to get this to work. I'm getting to the point where I may disassemble the PCB and make my own relay setup. I've decided this is going to be a project that I'm going to see through to the end. What I'm hoping is that other Axiom owners and Isuzu fans can pool our collective ideas/info and figure this out. I'm sure I'm not the only Axiom owner that would love to have Sirius play directy instead of a crappy FM rebroadcast.
So if anyone has info on the Axiom and/or CeNet pinouts any help posted here would be greatly appreciated. I love my Isuzu and this is about the only gripe I have.
_________________
Dear Isuzu, build the Kai and GBX and I will buy one of each.
Back to top
View user's profile Send private message
Ads by Google:
bigpoppax2
Forum Admin
PostPosted: Thu Feb 09, 2006 4:33 pm    Post subject: Reply with quote
I'd also like a way to connect directly in. I hate my FM modulator with my XM radio. I don't remember how Tad did his IPOD, I'm thinking he's running a aftermarket headunit.
Joe
_________________
After concealed carry guy shot a gun wielding robber....."I'm just a Law abiding citizen dumping some chlorine into the gene pool"
Back to top
View user's profile Send private message Send e-mail AIM Address
Canucklehead
Has a Trail Truck
PostPosted: Thu Feb 09, 2006 4:51 pm    Post subject: Reply with quote
Not sure if this is available for XM (I don't see why it wouldn't) but I have one of these for my Sirius Sportster. No static and no more having to change radio stations.
_________________
Steve
'97 Rodeo 5spd. 3.2L SOHC V6 4WD
Back to top
2004Axiom
Newbie
PostPosted: Thu Feb 09, 2006 4:52 pm    Post subject: Reply with quote
Aftermarket is not going to cut it for me. I've seen one decent install of an aftermarket NAV system in an Axiom and the guy put the head unit in the center console to keep the climate controls. I'm not going that route. Opening my center console to adjust the fan or AC would drive me nuts. This should be easy to figure out, but it's kicking my a--. Like I said, I may do manual switches. Either a 4PDT Rocker (very hard to find in my size requirements) or 2 2PDT rockers mounted in my coin holders (seat heaters on the XS). I'm just looking for some pinout info before I start.
_________________
Back to top
2004Axiom
Newbie
PostPosted: Fri Feb 10, 2006 12:22 pm    Post subject: Reply with quote
Wired modulator won't work for me either, because I bought the Xact XTR2CK which has no FM out. I had the Sirius One which has it but moved it to my wifes car. She has a blue dash to match and I wanted a multi-line orange display to match the Axiom's interior.
Besides I want this to work for my MP3 player as well so it needs to be a true Aux-in.
_________________
Back to top
martinrjensen
Newbie
PostPosted: Sat May 05, 2007 2:08 am    Post subject: Re: Pinouts for 2004 Axiom changer/CeNet capable? Reply with quote
So have you got an answer to this yet? I am in exactly the same place as you. Same car, same desire, except I am only interested in connecting up an MP3 player (Creative Zen M). I did read in a different forum where this apparently worked fine in an (earlier?) Axiom.
martin
2004Axiom wrote:
Hey all.
_________________
04 Axiom
Back to top
View user's profile Send private message Visit poster's website
Display posts from previous:
Post new topic   Reply to topic    Planetisuzoo.com Forum Index -> Audio & Electronics All times are GMT - 4 Hours
Page 1 of 1
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
