1992 Isuzu Pickup - What is the factory gear ratio?
Postby littlegray » Fri Apr 22, 2011 3:44 am
I'm trying to decide on the best tire size. Does anyone know how I can find the factory gear ratio? It's a 1992 Pickup 3.1L.
Thanks! 8)
1992 Isuzu Pickup - 3.1L V6 - 5 Speed - 4WD : Revenge Fab Winch Bumper + Rear Tube Bumper + Sliders + Exo/Rack, Warn m8000 + Wireless Controls + Amsteel Blue Sythetic, Yellow Top, CB w/ weather, Alpine Deck w iPod, BFG KM2 33x10.5s, 15" Snowflakes, Matching Spare w/ Custom Tire Carrier, Thule Rack w/ bike carrier, Diamond Plate Tool Box, ARB RTT, ARB Compressor, 4.56 Gears, ARB Locker Front & Rear, OME Springs/Shackles/Bushings/Shocks, Sway-a-way Torsion Bars, Ball Joint Flip, SS Brake Lines, Big Brake Upgrade, Ball Joints/Bearings/Seals/rotors/pads, HD Tie Rods, Exedy Clutch, Revolution 3:1 tcase gears - Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53023
http://www.gitout.com - Off Road Enthusiasts
littlegray
Trail Scout
Re: 1992 Isuzu Pickup - What is the factory gear ratio?
Postby JLEMOND » Fri Apr 22, 2011 11:26 pm
littlegray wrote:I'm trying to decide on the best tire size. Does anyone know how I can find the factory gear ratio? It's a 1992 Pickup 3.1L.
Thanks! 8)
IF IT CAME WITH THE 235 15 IT HAS 4.30 ,IF IT CAME WITH THE BIG TIRE PACKAGE 31 1050 15 IT HAS 4.55 GEARS
JLEMOND
Have thanks: 70 times
Postby littlegray » Sat Apr 23, 2011 3:08 am
Thanks for your help.
Which vehicles have 4.55 gears that are easily found in junk yards?
littlegray
Trail Scout
Postby gb89amigo » Sat Apr 23, 2011 3:55 am
Littlegray,
Amigo's 89-94, troopers to '97. More details in: http://www.zu4x.com/modules.php?name=Co ... age&pid=21
Hope this helps,
GB:)
'89 Amigo XS RWD, 4ZE1, MUA5, HC6
Future: Upgrade to '95 Passport front rotors (11.04"), G80 rear.
More FUN!!! :)
gb89amigo
Has thanked: 7 times
Have thanks: 12 times
Postby JLEMOND » Sat Apr 23, 2011 1:02 pm
littlegray wrote:Thanks for your help.
ALL TROOPERS CAME WITH ONLY 4.55 92-97 12 BOLT
LOTS OF AMIEGOS THAT CAME WITH THE 2.6 HAD 4.55
IF THE AMIEGO CAME WITH THE 2.3 IT HAS A 10 BOLT REAR. AND ONLY CAME WITH 4.10 GEARS
EVEN THE 12 BOLTS THAT CAME WITH DRUM BRAKES ON THE AMIEGO AND THE PICKUP WITH THE 12 BOLT ,A LOT OF THEM COULD HAVE HAD THE 4.55
ALLSO SOME DID COME WITH 4.30
AND A LOT OF THE 2WD ESP THE AUTOMATIC CAME WITH A 4.10 12 BOLT REAR AXLE
MOST ALL THE AUTOS CAME WITH 4.10 AND DISC BRAKES AND THE 5 SPDS CAME WITH DRUMS
ALL TROOPERS FROM 88 THRU 91 CAME WITH THE 4.55 ALL SO EXCEPT THE ONES WITH THE SNOW FLAKES WHICH ABOUT IMPOSSIBLE TO FIND NOW .
JLEMOND
Postby recon » Sat Apr 23, 2011 10:51 pm
my 95 truck has 4.30 gears.i counted 10 on the pinion and 43 on the ring gear when i had it apart last october when i was installing an aussie locker in the rear end. 8) recon
http://forum.planetisuzoo.com/viewtopic ... n&start=25
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53703&hilit=evolution+of+my+truck
recon
Have thanks: 17 times
Postby littlegray » Sun Apr 24, 2011 3:56 am
That's perfect. Thanks for the information. I'll find a good donor trooper for gears before installing lockers.
littlegray
Trail Scout
Postby JLEMOND » Sun Apr 24, 2011 10:48 am
recon wrote:my 95 truck has 4.30 gears.i counted 10 on the pinion and 43 on the ring gear when i had it apart last october when i was installing an aussie locker in the rear end. 8) recon
THAT WOULD BE CORRECT, THE 4WD CAME WITH THE 4.30 AND THE 4.55 A LOT OF 2WD CAME WITH 4.10
SOME HAD DISC AND OTHERS HAD DRUM BRAKES
JLEMOND
Return to Drivetrain Mods
Users browsing this forum: Google Adsense [Bot], iiapoxii and 1 guest
