3.2 Power Steering Pump Removal?
Postby 99passport3.5 » Thu Sep 23, 2010 10:01 pm
I'm in the middle of a 3.2 to 3.5 swap on my 99 Passport. I've got all the accessories off the engine in the Honda except the power steering pump and the A/C pump. Everything I've read (my Haynes manual and Alldata) say the pulley is bolted to the pump, and must be removed before the pump can come out. My pulley looks pressed on, has no bolts or nuts on the front center of it, and it won't clear one bolt for the bracket. Getting a little frustrated on this one, any ideas? I know the obvious answer is to get a puller and take the pulley off, but I really don't want to do that, except as a last resort.
99passport3.5
Postby pmat » Thu Sep 23, 2010 11:24 pm
you will need a puller, should be able to rent one from autozone.
-95 Trooper, 3.2 sohc, 5 spd. 6" lift, RIP :(
- 91 BMW E30 318IS
pmat
Postby 99passport3.5 » Fri Sep 24, 2010 2:56 am
That sucks. What about getting the pulley back on the pump?
99passport3.5
Postby Buster28 » Fri Sep 24, 2010 5:36 am
I have an Isuzu factory service manual for a 2001 Rodeo,which of course has the same engine as your vehicle.
The removal procedure for the PS pump in this manual does not require removal of the pulley. Looking at the
illustration in the manual, it seems to depict 2 bolts holding the pump to the bracket, and 2 bolts holding the
bracket to the engine. The removal of the AC pump does not require removal of the pulley either. The illustration
for the AC pump shows 2 bolts holding the bracket to the engine and 2 bolts holding the pump to the bracket.
http://www.myisuzuparts.com/1998/781/4/ ... parts.html shows the same illustration for the PS pump as the FSM
These are the bolt sizes shown in the illustration
10 X 100 7A
8 X 25 7B
8 X 100 29A
8 X 40 29B
Also note that on the illustration there is an earlier version pump depicted that shows the pulley is bolted on.
_____________________________________
01 Rodeo Sport Ironman 4X4 V6 134K miles
01 Rodeo Sport 4X4 V6 48K miles
02 Rodeo Sport 4X4 V6 65K miles
Buster28
4L30E Guru
Have thanks: 825 times
Postby 99passport3.5 » Mon Oct 04, 2010 2:50 pm
It's bolt #29A that's hanging me up. It won't come out of the bracket with the pulley on. I'll go out there and take another look, but hey, any excuse to make it to Autozone, right? P.S.~I have the later style pump, non-bolt-on, pressed on pulley.
99passport3.5
Re: 3.2 Power Steering Pump Removal?
Postby axiom driverm » Wed Sep 23, 2015 11:30 pm
the problem arises for everyone due to a lack of understanding on the bolts and how they hold the pulley.
three bolts remove pump, two short ones on right (as viewed from front of vehicle) an one long bolt (about 4 inches long ) on the lower left of pump(as viewed from front)
all three are accessed through hples in pulley. there is a fourth bolt behind pulley but not accessible through pulley. it is ti remove the braacket that the pump bolts into.
Now here is where problem occurs. The long bolt (lower left as viewed from front) screws into a metal sleeve embedded in the aluminum pump bracket. When bolt is screwed into the sleeve and tightened, it pulls the sleeve slightly out of housing forward against the back
of the pulley. when you loosen the bolt, that metal sleeve is still tight against the back of the pump making it seem a tight fit to take the pump out or put back in.
However, the solution is easy. remove the long bolt then screw it back in the same hole about half way so several threads are threaded into the back bracket. then place a socket on the bolt so socket protrudes
through the front of hole in pulley. This is so you can gently tap it with hammer to push metal sleeve back into the aluminum bracket located behind the pulley.
watch the socket for movement as you tap the socket. only needs to move 1/4 to 3/8 inch or so until pump is really easy to insert or remove. When you reinstall and tighten. it will pull back out against the pump.
the reason this works is that the bolts are flange bolts and socket pushes bolt when hit. if however, someone has replaced factory bolt with nonflange bolt, you can use short socket extension instead of socket and tap with hammer.
There has been a lot of misinformation on how to remove this pulley, hope all goes well for you and others.
axiom driverm
Return to Drivetrain Problems
Users browsing this forum: chimpboy and 3 guests
