Isuzu 3.2 V6 timing belt question!
Postby 94Rodayo4x4 » Sat Sep 11, 2010 3:18 pm
I was talking to jwood, and he told me that if a timing belt snapped it would not bend any valves and do other damage due to the engine being non-interference (only on the 3.2 v6). If this is true, does this mean if I were to get a Rodeo with a snapped timing belt and be able to put the timing back in place and not have any engine damage?
This could be a major game changer for me if this is all true.
Its the 1993-97 3.2 24valve v6.
Taylor H.
1994 Isuzu Rodeo S, MUA5, 4WD, V6, 31's- Sold :( Rest In Peace, Ticking Green Beast!
2000 TOYOTA 4Runner SR5, V6, Auto, 4WD
1.5" Lift, 265/75 Yokohama Geolandar A/T, PIAA 520's, 22" LED Light Bar, Flowmaster
Isuzu Parts for sale
94Rodayo4x4
Has thanked: 32 times
Have thanks: 47 times
Postby 94Rodayo4x4 » Sat Sep 11, 2010 3:21 pm
most of my question has been answered. the engine is non interference, so if the belt did go while in use, the engine should suffer no damage correct?
Taylor H.
94Rodayo4x4
Postby Dae » Sat Sep 11, 2010 3:32 pm
It shouldnt have caused any damage internally. Are you able to take a peak behind the covers?
Dae
Has thanked: 2 times
Have thanks: 27 times
Postby 94Rodayo4x4 » Sat Sep 11, 2010 3:39 pm
Dae wrote:It shouldnt have caused any damage internally. Are you able to take a peak behind the covers?
no. the car is 2 hours away. but for $800 and (possibly) no engine damage, it could be a steal!
Taylor H.
94Rodayo4x4
Postby Dae » Sat Sep 11, 2010 3:51 pm
Nice! Keep us updated :D
Dae
Postby Hotrod310 » Sat Sep 11, 2010 4:15 pm
I was told that the 3.2 was an interference engine and this is what the Haynes manual says too!
Hotrod310
Drives in Mud
Postby Dae » Sat Sep 11, 2010 4:28 pm
I use my Haynes manual to wipe grease off my hands. The only thing good about them are the torque specs. But some of those are never updated.
The Isuzu 3.2L V6 engine is non-interference. But it still doesnt mean that should wait to replace the belt, until the original breaks. :shock:
Heres a quote.
trooperbc wrote:if it is the isuzu 3.2L V6 engine there is NO doubt
it is NON INTERFERENCE
if it is *ANY* engine in an isuzu
it is long overdue for a change
isuzu change intervals for these engines started out as
60,000 miles
changed to 75,000 miles
changed to 100,000 miles -- the later for the newer engines with newer belts iirc.
nevertheless, most will give you a 100,000 mile window for these engines/belts. and *do not* count on the noninterference part as being your pass around the board, because you will find yourself in isuzu jail anyway when that belt does go, or the water pump freezes and you have severed covers etc etc etc . you are running on borrowed time.
when you do the belt NOW you will do all at the same time
timing belt
timing belt tensioner
water pump
and the timing belt pulley if it needs it (on inspection, bearings)
and some seem to like to do the front cam seals at the same time
//bc
Dae
Postby CatFuzz » Sat Sep 11, 2010 5:51 pm
+1 on the 3.2L being non-interference. Go buy that rodeo with the broken timing belt. The Haynes manual is wrong. Schucks website is wrong.
Your getting a good deal here unless it's trashed in other ways.
99 Rodeo, 3.2L Auto, Manual hubs, "Trooper lift".
“I taught constitutional law for ten years. I take the Constitution very seriously. The biggest problems that were facing right now have to do with George Bush trying to bring more and more power into the executive branch and not go through Congress at all, and that’s what I intend to reverse when I’m President of the United States of America.”
-- Then-Sen. Barack Obama in a campaign speech.
ABS and traction control are for people that don't know how to drive.
CatFuzz
Has thanked: 36 times
Have thanks: 130 times
Postby Hotrod310 » Sat Sep 11, 2010 9:04 pm
That's just what it says. It may be garbage but I was also told this by a napa tech.
Hotrod310
Drives in Mud
Postby 94Rodayo4x4 » Sat Sep 11, 2010 11:01 pm
Dae wrote:I use my Haynes manual to wipe grease off my hands. The only thing good about them are the torque specs. But some of those are never updated.
Heres a quote.
60,000 miles
timing belt
water pump
//bc
Thanks for that info Dae. Definitely adding this into my bookmarks. Hoping I can get this truck. for 800, it is a steal. But, I am not holding my breath. :roll:
Taylor H.
94Rodayo4x4
Postby 94Rodayo4x4 » Sat Sep 11, 2010 11:04 pm
CatFuzz wrote:+1 on the 3.2L being non-interference. Go buy that rodeo with the broken timing belt. The Haynes manual is wrong. Schucks website is wrong.
well, with that, I can only beg my dad to take me all the way down to Cincinnati to look and get it hopefully. :wink:
Taylor H.
94Rodayo4x4
Postby CatFuzz » Sat Sep 11, 2010 11:51 pm
You can't trust professional mechanics on this topic. They are in business to make money. It's easy to convince people that don't know any better that their engine is shot anytime a timing belt breaks because everyone has heard about someone who it's happened to. Add to that, the inaccurate documentation that is all over the place.
The people selling the Rodeo were probably convinced that they needed to have the engine replaced at eleventy thousand dollars plus tax so now they are selling it for whatever they can get.
Myself and others on this board have confirmed first hand that these engines are not interference. When I had my engine out, I did it. I made sure I had a few valves as open as they could get and with the tbelt off, turned the crank. No contact at all.
CatFuzz
Postby 94Rodayo4x4 » Sun Sep 12, 2010 12:01 am
Thanks. I really needed to know this information. My dad and I were convinced that every engine we saw with a broken timing belt and such was a goner. You guys really are a big help, and this could pave the way to getting my truck. I have never been happier to be a Planet Isuzoo member! :D :lol: 8) :wink:
Taylor H.
94Rodayo4x4
Postby CatFuzz » Sun Sep 12, 2010 12:17 am
Cool 8)
CatFuzz
Postby 94Rodayo4x4 » Sun Sep 12, 2010 8:45 pm
Is it common for the head gasket to blow if the timing belt breaks?
Taylor H.
94Rodayo4x4
Postby AzBowman » Sun Sep 12, 2010 9:42 pm
I have never heard of head gaskets going from a bad timing belt but anything is possible i guess i would say highly unlikely though
95 Rodeo stock but lift in the works- Check
Custom Fab roof rack- Almost done gotta fab the mounts then paint will start a thread on the build with pics!
WWW.LEGENDGLASSANDDOOR.COM
AzBowman
Drives in Mud
Postby CatFuzz » Mon Sep 13, 2010 12:23 am
rodeopassportenthusiast wrote:Is it common for the head gasket to blow if the timing belt breaks?
No. No possible way for a broken timing belt to cause a blown head gasket.
CatFuzz
Postby 94Rodayo4x4 » Mon Sep 13, 2010 12:36 am
Ok, my crazy dad is asking all these questions.
Taylor H.
94Rodayo4x4
mileage
Postby Sh_YVR » Fri Oct 01, 2010 11:49 pm
so what happened ?
What was the mileage? i t would be really great to know.. how big the window is. (if it indeed ran till the belt broke)
Sh_YVR
Super Trooper
Postby jeremy_worden » Sat Oct 02, 2010 1:02 am
good luck we all hope you get a rodeo...
1995.5 isuzu rodeo LSD and snowflakes
1988 isuzu trooperII []OlllllllllllllO[] 245-75-R16, yakima load warrior basket, custom rear bumper, and an AUSSIE locker, and AISIN hubs, indy4x shackles 2" lift.
cardomain and May 2011 ROTM
Isuzu Outlaw - Bikini
jeremy_worden
Have thanks: 14 times
Postby Hotrod310 » Sat Oct 02, 2010 1:03 am
I want to clarify my previous statement above on the timing belt. I am a new member and just bought my 2000 rodeo 3 weeks or so ago. I am not completely initiated in the way of the isuzu yet , so to speak. I have learned to trust the knowledge of others on this site, even when it contradicts tech manuals. I now wipe my butt with the Haynes manuals just as Dae wipes his greasy hands with his. :)
Hotrod310
Drives in Mud
Postby Andrea » Sat Oct 02, 2010 11:42 am
:D :D Looks like everyone missed the greatest authorority of all, JERRY, (my Hero), if he says it isn't then it definatly isnt an interference engine! Andie :D :D
2004 Rodeo, 3.2, auto, OME 912's, and a Kangaroo Chaser
05 Saab 9,3
Assorted trucks, 2 Dodges, and a Chevy
Andrea
Postby 94Rodayo4x4 » Sat Oct 02, 2010 12:13 pm
Well, in the end, this Passport vanished. We did get about 4o pics of it though, and it was nice, but something made it look like a lemon....maybe it was the giant hole in the frame near the leaf spring... :shock:
If i had a spare frame, I would have just swapped bodies. It was a nice truck, but really "religious" if you get my drift. (frame was "holy"). but I am still pleased to know what I know now as a result of creating this thread. The right one will show up eventually. I finally got a job, so now I will be making a little money.
read more about my quest here: http://forum.planetisuzoo.com/viewtopic.php?t=43638
Cheers!
Taylor H.
94Rodayo4x4
