2002 Trooper LTD. Power Drive light stuck on.
Postby nick5555 » Fri Sep 10, 2010 1:51 am
2002 Trooper LTD.
The Power Drive Light is stuck on. Pushing and repushing the Power Drive switch has no effect. (ie, the Power Drive lamp remains lit and the transmission continues to operate in Power Drive mode).
Also, since this started occurring, the Check Engine Light will come on and off periodically. For example, the Check Engine Light was on for 5 days until one day it "magically" turned off. And now, this afternoon, the CEL has turned on again.
Any ideas for troubleshooting?
Thank you.
nick5555
Postby CatFuzz » Fri Sep 10, 2010 3:54 am
I'd be checking the power drive switch first. Could be shorted. As far as the CEL, have the codes read and post them here. Shouldn't matter if the CEL is on or off, there will still be stored codes.
99 Rodeo, 3.2L Auto, Manual hubs, "Trooper lift".
“I taught constitutional law for ten years. I take the Constitution very seriously. The biggest problems that were facing right now have to do with George Bush trying to bring more and more power into the executive branch and not go through Congress at all, and that’s what I intend to reverse when I’m President of the United States of America.”
-- Then-Sen. Barack Obama in a campaign speech.
ABS and traction control are for people that don't know how to drive.
CatFuzz
Has thanked: 36 times
Have thanks: 129 times
Postby nick5555 » Fri Sep 10, 2010 1:03 pm
OK. I'll check the power drive switch. How? Do I need to take off the console? Can I pry off the switch cover? I have a voltmeter but not quite sure how to investigate other than 1) Figure out how to get access to the switch's wires and 2) Look for obvious wire disconnections/discoloration, etc
nick5555
Postby Amigo-2k » Fri Sep 10, 2010 3:33 pm
You can just pull the switch out and unplug it. I think the winter and power button come out together.
Also you need to buy a code reader to see what the CEL is. it could be about 1000 different things.
Amigo-2k
Forum Admin
Postby trprluvr » Fri Sep 10, 2010 3:55 pm
I had probs with my power/winter mode switches and it was because they were gunked up and sticking. They pop right up out of the console. It will also allow you to disconnect the wires to see if the switch is stuck.
1999 Trooper, 168,000 miles, I luv this Trooper ! Use it for hunting and 70 mile round trip to work every day. 2005 F-350 Superduty 4X4 Supercab W/6 Liter Diesel. LSD rear end and short bed, single wheels on back. Manual locking hubs, manual windows, and door locks...no carpet :) Warn 9500i winch. I love this truck yall !!!
trprluvr
Trail Rider
Postby nick5555 » Sat Sep 11, 2010 12:46 am
The plastic blade inside the switch was broken. I've been searching parts websites and can't seem to find the switch listed on any of them. Any ideas on how to determine the part number and find a site that sells them?
As for the code reader to determine why the CEL is on intermittently. Any brand or feature recommendations?
Thank you.
nick5555
Postby willdieh » Sat Sep 11, 2010 2:11 am
Just get one on ebay... (Power/winter switch)
Or grab one at a wrecking yard.
-William
willdieh
Postby nick5555 » Sat Sep 11, 2010 7:13 pm
For anyone else looking, the part number and name for the Power/Winter Mode Switch appear to be:
Trans Cont Select or Switch ASM Selector
8-97170-708-2.
Thanks for the ebay tip, William.
Regarding the intermittent CEL. There are 4 codes stored:
P0135: O2 Sensor Heater Circuit Bank 1 Sensor 1
P0141: O2 Sensor Heater Circuit Bank 1 Sensor 2
P0155: O2 Sensor Heater Circuit Bank 2 Sensor 1
P0161: O2 Sensor Heater Circuit Bank 2 Sensor 2
Going to start looking around for more info about the codes now. Any advice greatly appreciated. Thanks.
nick5555
Postby nick5555 » Sun Sep 12, 2010 2:19 am
Going to start a new thread about the CEL codes.
nick5555
Return to Drivetrain Problems
Users browsing this forum: Google Adsense [Bot] and 5 guests
