I recently replaced the timing belt in my newly acquired 1988 Trooper II with an automatic transmission. To loosen the crankshaft pulley bolt, I used a breaker bar with wood blocks and cranked the starter. To hold the crankshaft pulley while torquing the crankshaft bolt, I used an 8" chain wrench and a leather belt to protect the crankshaft pulley.
Everything was fine until I tried to set the ignition timing 12 degrees BTDC. After fiddling for several days, I finally determined that the timing mark on the crankshaft pulley was not in the correct position.
The part of the pulley that is keyed onto the crankshaft is a harmonic balancer. The balancer is made of three parts; an inner flange keyed to the crankshaft, an outer ring which functions as a pulley, and a rubber ring that separates them. The balancer dampens torsional vibration of the crankshaft. While torquing the crankshaft pulley bolt the harmonic balancer must have slipped.
To make a new timing mark on the crankshaft pulley I removed the top timing belt cover, rotated the engine to the timing mark on the camshaft, and etched a new TDC mark with a Dremel on the crankshaft pulley that lines up with 0 degrees BTDC on the engine block.
Since the balancer only dampens torsional vibration, the angular relation between the inner and outer parts should make no difference. I'll have to check that the balancer doesn't slip anymore, by periodically checking the ignition timing against the new TDC mark. Next time I replace the timing belt, I'll have to replace the harmonic balancer.
