Front Wheel Movement
Postby MonsterD » Thu Jun 10, 2010 1:36 pm
I recently installed OME 929's springs to my rig which then required me to crank my torsion bars some to level out the vehicle . I doubt there is any relationship between this but I now notice that when I grab my front wheel, I can move it back and forth a bit. Meaning I can push it towards the engine and pull it back towards me. It's the same on both sides. It's not loose lugs bolts. The truck has 193,000 and I don't believe the bearings have ever been repacked. Would that have anything to do with the movement?
Thanks
98 Trooper LS Oil Consuming DOHC 3.5 V6 and BF Goodrich All Terrain 285/75 16's otherwise stock driver which I absolutely love! Portland, OR
MonsterD
Postby caveman » Thu Jun 10, 2010 2:31 pm
Possibly. Another thing to consider is that if you raise a vehicle you need to loosen the upper and lower control arms to relocate them to the new ride height. If you don't then the rubber bushing will tear and become useless and cause your issue.
jack up your truck and shake the wheel hard. Look carefully to see if your upper control arm is moving. Shake it in ALL directions to see movement
A loose bearing will cause a hard clunk.
1988 to 98 Isuzoo Trooper II. rebuilt with american pride! Built and tested now parked and resting until the next adventure!
caveman
Have thanks: 34 times
Re: Front Wheel Movement
Postby emmagator » Thu Jun 10, 2010 5:16 pm
MonsterD wrote: The truck has 193,000 and I don't believe the bearings have ever been repacked. Would that have anything to do with the movement?
Thanks
Yes
1990 Trooper 2.6L, 5 speed
emmagator
Postby jwood1016 » Thu Jun 10, 2010 5:55 pm
since you lifted it in the front you probably toasted your already old shocks and ball joints. Replace those also if you have not already.
John
2002 Trooper
3 inch lift and 33's
jwood1016
Have thanks: 17 times
Postby IsuzuGeek » Thu Jun 10, 2010 6:22 pm
That is generally how you can tell if your bearings need to be repacked. If you have that kind of play, you need repacking. There is a good tutorial on here for how to DIY or you can bring it to any decent tire shop and they should be able to do it.
Bart
IsuzuGeek
Have thanks: 196 times
Postby MonsterD » Fri Jun 11, 2010 11:50 am
I just put new shocks on the front a month ago. Are you saying I may have toasted them?
MonsterD
Postby IsuzuGeek » Fri Jun 11, 2010 12:58 pm
MonsterD wrote:I just put new shocks on the front a month ago. Are you saying I may have toasted them?
I still say wheel bearings need to be repacked.
Bart
IsuzuGeek
Postby MonsterD » Fri Jun 11, 2010 1:18 pm
I'm packing them this weekend. Then I'll make the adjustments and see what happens. I was planning on putting on the robust bearings and tie rods from Indie4x anyway. Just might be a little sooner than planned.
MonsterD
Postby 98passport » Fri Jun 11, 2010 4:06 pm
I agree with jwood, check your ball joints because the movement can be caused by worn out ball joints.
98passport
Have thanks: 7 times
Postby caveman » Fri Jun 11, 2010 7:14 pm
I agree, bearings don't suddenly come loose after a lift. But a different ride level will stir up some (if not all) front end demon's. Get you wallet out dude! :cry:
caveman
Postby IsuzuGeek » Fri Jun 11, 2010 8:05 pm
rollintroopers wrote:Get you wallet out dude! :cry:
:lol: Tell me about it! One thing after another. Will I ever be mechanically sound all around for at least a year?
You might not have a car payment with an older vehicle, but you certainly have a parts & payment with one...I guess that's the price for riding in style.
:? Bart
IsuzuGeek
Postby caveman » Fri Jun 11, 2010 9:16 pm
nfpgasmask wrote:I guess that's the price for riding in style. :? Bart
Well put. :P
caveman
Postby recon » Sun Jun 13, 2010 1:19 pm
i changed all my wore out ball joints and up graded my tie rods when i lifted mine and checked bearing preload when i lifted mine.i bought a spindle bearing nut 2 prong socket from northern tool when i did this 8) neo
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53703&hilit=evolution+of+my+truck
recon
Has thanked: 109 times
Have thanks: 47 times
Postby MonsterD » Sun Jun 27, 2010 1:02 pm
Been meaning to follow up with the results for awhile now. I repacked the bearings and that solved the wheel movement. Holy Sh*t! Big improvement in steering and bearing clunk noise went away. Surprisingly the job isn't all that hard. Unfortunately I have some clunk happening up front still. Seems like its coming from the right side. I've taken to two shops and both tell me they see no wear on the bushings nor do they feel the movement you would feel if my ball joints were worn out. The easiest way to hear/feel it is going over a small bump such a a speed bump. If I go real slow over the bump, like creep over it, no noise or clunk. If I go over it at 5mph it will be noticed. I want to believe it's ball joint or joints. They have 194,000 miles on them but if it's not I don't wish to replace them. I'd rather use that money for new Indie4x4 torsion bars.
MonsterD
Postby emmagator » Sun Jun 27, 2010 1:32 pm
Ball joints most likely need replaced. First time doing it will be kind of a pain, but after that youll know how to do it. Go for it :wink:
emmagator
Users browsing this forum: Google [Bot] and 8 guests
