Replace wheel bearing in '90 Trooper??
Postby Justin_J » Sat Feb 27, 2010 2:31 am
So I pulled the wheel and brake rotor off and got down to the hub. On all hubs I've seen there is a large nut that needs to be removed to get to remove the hub and the bearing, but on the trooper there is no nut, but instead a surface that looks like accepts some sort of special tool in order for removal and hub/bearing access. Anyone know anything about this, or have a link to some step by step instructions? Thanks!
-Justin
Justin_J
Postby justwork » Sat Feb 27, 2010 3:04 am
Chris
Cherry 1991 Trooper LS. Gone. 3.4L V6 conversion, 2.5" exhaust, MUA5 Transmission, Aisin hubs, stainless brake lines, Independent lift shackles, Surco basket rack, all sitting on 235/75R15 BFG AT's
justwork
Postby beretta92 » Sat Feb 27, 2010 3:05 am
well if it is anything like my rodeo it should have two holes 180 degrees from each other and if it is that in my haynes it says to just use a screwdriver and unscrew it
-Ryan
95.5 rodeo
3in susp lift
Black snowflakes
1in diff drop
aussie locked up front
3in tube bumper
beretta92
Postby beretta92 » Sat Feb 27, 2010 3:06 am
lol or you can use that
-Ryan
95.5 rodeo
3in susp lift
Black snowflakes
1in diff drop
3in tube bumper
beretta92
Postby justwork » Sat Feb 27, 2010 3:07 am
Buy the right tool, they're not expensive and when it takes you 15min to do you'll be thankful, instead of trying and trying and cursing and slipping with a screw driver. Take anything in a haynes manual with a grain of salt.
This thread might help you, if not there should be plenty more on the site.
http://forum.planetisuzoo.com/viewtopic.php?t=37100&highlight=bearing+torque
Chris
justwork
Postby beretta92 » Sat Feb 27, 2010 3:16 am
ya it also says to use a picklefork on the ball joints and that never ends up good. i just use the driver cause im broke :D
-Ryan
95.5 rodeo
3in susp lift
Black snowflakes
1in diff drop
3in tube bumper
beretta92
Postby Justin_J » Sat Feb 27, 2010 4:52 am
ok thanks guys, but just one thing. I am replacing the rear wheel bearing not the front, and it is a 90 trooper not a passport or rodeo. I don't know if its different or not, and i'm sure you guys know what you're talking about, just thought it'd be good to check before i go and buy the tool.
Justin_J
Postby RustyZu » Sat Feb 27, 2010 10:39 am
yep, mae sure to use the right tools. I needed to drive my truck soon, so I did it ugly way by using a screw driver and hammer. Was it ugly by the time I was down with it, and had to get 2 new wheel bearing locks. It sucked.
1994 Toyota P'UP 3.0Li V6 with 31's Good Year AT's
1991 Isuzu Trooper Stock 4X4 2.6Li 4cyl
RustyZu
Mi Amigo
Postby justwork » Sat Feb 27, 2010 1:33 pm
Chris
justwork
Postby :::Matski::: » Sat Feb 27, 2010 2:06 pm
I just use a punch and hammer.
1989 2.8TDI Isuzu Bighorn Hybrid
Front Aussie Locker - Rear LSD - Petrol Diffs
2" Lift - 1" Body lift - +2" shocks - 32" KL71s
2.5" free flow stainless system - TMIC - 20psi Boost
Suckin' Diesel Baby!
:::Matski:::
Super Trooper
Postby shooter » Sat Feb 27, 2010 2:25 pm
Justin_J wrote:ok thanks guys, but just one thing. I am replacing the rear wheel bearing not the front, and it is a 90 trooper not a passport or rodeo. I don't know if its different or not, and i'm sure you guys know what you're talking about, just thought it'd be good to check before i go and buy the tool.
Are you talking about the rear wheel bearing? If so, most likely need to pull the axles and have the old pressed off and new pressed on. If you're referring to the inner bearing on the front wheel, it's rather simple. The lock nut loosens easily with a phillips head screwdriver, round shank, etc stuck in one of the two holes and a little whack with a hammer, etc.
1989 Isuzu Trooper S/ 4WD / 2.6 Litre 4 Cyl 4ZE1 Converted to Weber 32/36 Carb / 5-speed Manual (MUA5) / Warn Premium Hubs / Fancy Radio / Deluxe Intermittent Combination Wiper Switch
I'd rather laugh with the sinners than cry with the saints
Some people are like Slinkies; they are not good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
shooter
Has thanked: 35 times
Have thanks: 150 times
Postby Justin_J » Sat Feb 27, 2010 4:43 pm
Alright thanks a ton for all the info guys, the tool is ordered and on its way. Thanks again!
-Justin
Justin_J
Users browsing this forum: Oregon RS, Zenit and 5 guests
