thermal valve
thermal valve
Postby Trooper2Guru » Thu Dec 10, 2009 2:32 pm
working on the the rig today and found that the thermal valve has one of the ports broke off, now my question is what does this valve do. 1989 trooper 2 2.6l 4ez1 engine thanks
1989 ISUZU TROOPER 2.6L 5SPEED MANUAL
2001 ISUZU TROOPER 3.5L AT
Trooper2Guru
Postby CatFuzz » Thu Dec 10, 2009 3:21 pm
It is a thermally operated vacuum switch. Couldn't really tell you exactly what it does but if you follow the vacuum line, that might give a clue. As long as you plug any vacuum sources, you can usually get away with not even having them hooked up unless it's operating something that is needed.
99 Rodeo, 3.2L Auto, Manual hubs, "Trooper lift".
“I taught constitutional law for ten years. I take the Constitution very seriously. The biggest problems that were facing right now have to do with George Bush trying to bring more and more power into the executive branch and not go through Congress at all, and that’s what I intend to reverse when I’m President of the United States of America.”
-- Then-Sen. Barack Obama in a campaign speech.
ABS and traction control are for people that don't know how to drive.
CatFuzz
Has thanked: 36 times
Have thanks: 129 times
Postby isuzufool » Thu Dec 10, 2009 5:24 pm
It is really a useless valve and can be eliminated from your system. It was originally designed to up the idle speed if the engine gets too hot to pull more air through the radiator I think, but that is stupid anyway. The later model 2.6L engines did not use them at all, nor did they have the air induction pump for the exhaust system for that matter!
'89 pickup, 2.6L with .040 over pistons, MUA5 tranny, calmini header, custom air intake, 2.5" exhaust, 3" lift, stock axles, 33" regal trailblazers, aussie lockers, 217k miles and counting, 80k on engine
'88 Trooper II LS, 2.6L automatic (still a work in progress)
'05 F-150 crew cab 5.4L V-8 with custom exhaust and SCT Livewire tuner/monitor :-)
'00 Rodeo LS, 3.2L automatic
CV shafts are made for breaking, right?
isuzufool
Postby SurferJoe » Thu Dec 10, 2009 5:31 pm
isuzufool wrote:It is really a useless valve and can be eliminated from your system. It was originally designed to up the idle speed if the engine gets too hot to pull more air through the radiator I think, but that is stupid anyway. The later model 2.6L engines did not use them at all, nor did they have the air induction pump for the exhaust system for that matter!
If it's that one with the big ports up by the thermostat housing, then you only need to use one on each side - one side only has one nipple anyway.
It is supposed to do two things - speed up the water pump and also the fan.
One nipple goes into the clean air side of the intake runner and the other into the plenum. It acts as a bypass to allow extra air into the plenum and the idle speeds up - that's all.
I use mine although I have an electric fan and temp sensor that I installed as it can tell me if for some reason my fan has failed to run. The engine will speed up and you'll know that something's happening.
Unfortunately there are multiple "thermal valves" on these engines and without a placement hint - it's kinda hard to say which one you are pointing to.
Joe Vreeland - In The Bitterroot Valley, Montana
SurferJoe
Has thanked: 23 times
Have thanks: 24 times
Postby Trooper2Guru » Thu Dec 10, 2009 9:04 pm
Thanks guys it was the one in the T-stat housing but after searching the planet i did indeed find alot of information on the subject, so i replaced it with a plug. and all is well.
Trooper2Guru
Users browsing this forum: moteinzuzu, MSNbot Media and 3 guests
