My 1995 Rodeo won't even crank.
Postby Crazypunkeguy » Mon Dec 07, 2009 10:28 am
We have had a problem with the rodeo for a few years before I got it from my mom. To start the truck you have to turn the key more then once maybe 5-9 times, sometimes more, sometimes less. Well I was going to to start it and let it warm up. I sat in the truck for about a half hour turning and turning before I just got sick of it. I have searched around and it seems to be kind of common. The starter is newer but has a good 50k on it. We are going to check the grounds and the neutral safety switch. I have tried the trick like trying to start it in neutral or drive then switch it to neutral and still got nothing. Is there anymore I should check?
Also my mom spilled a lot of Coffee around the shifter. I took everything apart and got the brake lock system working better. Is there anything in there I may have messed up well cleaning? It worked for 2 weeks after but now nothing. Thanks everyone in advance for information!
1995 Isuzu Rodeo "The Deo" auto, cup holders!
1989 Ford Probe Gt, 5-speed, turbo and stock
1993 Escort Gt-t, 5-speed,Turbo goodness
Crazypunkeguy
Postby mmPriest » Mon Dec 07, 2009 11:07 am
I had friend with a 96' Ram who had the same problem you did, didnt last that long though. Turned out the copper contacts in the starter had worn out. Yours finally may have gone caput. If push comes to shove remanufactured starters are only $45 if you factor in core cost.
Dont know if that helps,
Mat
Matt - 1997 Isuzu Rodeo 4x4 w/ Manual Transmission and 215K.
Uploaded with ImageShack.us
mmPriest
Trail Rider
Postby driftwood00 » Mon Dec 07, 2009 11:14 am
I just went through the same thing. I cleaned the connections at the starter cleaned all battery terminals and even changed the solenoid to no avail. I'm thinking that your solenoid contacts are bad. Does it make any sounds when you turn the key? Like any click sounds, you will hear the fuel pump, just listen for the solenoid to click when you turn the key. More than likely your contacts need replaced in your solenoid. I know you can buy kits to do this yourself. I will see if I can find a link, if I do I will post it. or just look on ebay. Hope this helps and good luck, Justin
-Justin-
2001 Isuzu Trooper LS 3.5L TOD 4x4 Loaded
1997 Isuzu Rodeo LS 3.2L 4x4 5 speed
1987 Mitsubishi Montero 2.6L 4x4 5 speed (SOLD)
driftwood00
Trail Scout
Has thanked: 2 times
Postby Crazypunkeguy » Mon Dec 07, 2009 10:34 pm
driftwood00 wrote:I just went through the same thing. I cleaned the connections at the starter cleaned all battery terminals and even changed the solenoid to no avail. I'm thinking that your solenoid contacts are bad. Does it make any sounds when you turn the key? Like any click sounds, you will hear the fuel pump, just listen for the solenoid to click when you turn the key. More than likely your contacts need replaced in your solenoid. I know you can buy kits to do this yourself. I will see if I can find a link, if I do I will post it. or just look on ebay. Hope this helps and good luck, Justin
Thanks for the information, It clicks and the lights all come on like normal. I got it to almost fire once but accidentally stopped and it hasn't turned over since. It seems to be the colder it is the worse the problem is my mom said.
Crazypunkeguy
Postby nick1990 » Mon Dec 07, 2009 10:56 pm
Contacts on the starter or cables going to the starter.
My chevy did that. I would have to try it about 15 times before it would hint a start but I would go to fast and have to do it 20 more times before it worked........
nick1990
Postby Ramblin Fever » Mon Dec 07, 2009 11:00 pm
starter itself could just be bad. Do you get a clicking sound when you try to start it?
Alternator, weak battery can also be culprits if it's sat long enough, and or voltage system is really drained.
'97 Rodeo 3.2L V6
KC Fogs; Brushguard;
Yakima loadwarrior;
Maxlife/K&N
197k strong
Ramblin Fever
Has thanked: 8 times
Have thanks: 49 times
Postby firstamigo » Mon Dec 07, 2009 11:48 pm
Sounds like the starter finally bit the dust. From the sounds of it the winding is bad in the starter and has a dead spot, which is pretty common. When the winding's start to go bad they will normally do like you described at first in that after several tries they will work. I'd take the starter off and have it tested to verify it.
93 Amigo XS 4x4
32x11.5x15 Pro Comps
3" body lift
1 1/2" suspension lift
2.6L (stock for now)
90 Trooper LS
2.8L/Auto
firstamigo
Postby jwood1016 » Tue Dec 08, 2009 12:35 am
lol..in my amigo i had to turn the key 30 times sometimes...unitil i got that magical start up...it went away after i while though....WEIRDDDD
John
99 Amigo, 285/75/16's, 5-spd
viewtopic.php?f=30&t=67852
jwood1016
Has thanked: 7 times
Have thanks: 15 times
Postby dbikers » Tue Dec 08, 2009 11:23 am
this happened to me on an infiniti i owned 17 yrs ago...most autos have a switch to either start in P or N. the adjustment was out on ours, sometimes it would start in P but sometimes not. they told us to try to start it in N. we did and it started right up. the dlr towed it to their shop and adjusted / fixed it.
try to start it in N....if coffee was spilt around the shifter perhaps it made its way to the switch...
just a thought....good luck
Outside of a dog, a book is man's best friend; inside of a dog, it's too dark to read. --Groucho Marx
1994 RODEO LS
1989 CYJ-7
2006 FORD FIVE HUNDRED (you should have seen the other guy)
1985 YAMAHA MAXIM-X
1988 BMW K75S
dbikers
Postby CatFuzz » Wed Dec 09, 2009 12:50 am
This is likely the solenoid contacts inside the starter. The side contacts wear out unevenly. It starts as an occasional no-start to more frequent no-starts to finally not starting at all. O'Reilly's has a contact repair kit that will fix the problem without having to invest in a reman starter. I happen to have a Denso starter in my garage out of a Subaru that uses an identical solenoid. I'll take pics to show everyone. Apparently, this still isn't common knowledge.
CatFuzz
Has thanked: 15 times
Have thanks: 69 times
Postby CatFuzz » Wed Dec 09, 2009 1:15 am
Denso starter solenoid with access plate removed:
Plunger pulls straight out, there is a spring beneath it. Don't lose it.
Here are the contacts. The plunger is pulled down by an electromagnet to make the connection between the positive battery cable and the starter motor itself and it also pushes out the starter drive to engage the ring gear. This happens when the small wire is energized when you turn the key to 'start'. Battery cable connection is on the left, solenoid engagement wire beneath it, start motor wire on the right.
It's the side contacts that wear out unevenly. If you could look at this one, you'd see one side is obviously thinner than the other. This accounts for the intermittent no-start and repeatedly hitting the key eventually makes it start again. Also why a jump from another running car makes it work better since you are getting 14+ volts from the other car as opposed to less than 12 when cranking normally. The extra voltage pulls the plunger down harder helping to make contact.
Go ahead and take one apart. It will become painfully obvious how these things work when you do.
CatFuzz
Postby Crazypunkeguy » Wed Dec 09, 2009 6:59 pm
Wow catfuzz thanks, that is probably the culprit. Well it's in the garage I think I am going to clean all the grounds possibly make a few new ones. Take apart and clean the neutral safety switch on the transmission and replace the solenoid in the starter. Then hopefully that will resolve this problem and I can get back to driving this thing. I only got 4 days of daily driving it before it gave out. Thanks everyone else for the idea's as well.
Crazypunkeguy
Postby CatFuzz » Thu Dec 10, 2009 2:36 am
You don't need to replace the solenoid. Just buying a solenoid is incredibly expensive. More expensive than the whole starter. Haven't figured that one out yet. What you need is a solenoid repair kit. Come with two sets of side contact for different applications. Just match your to the ones you need in the kit and then install the new plunger with the old spring.
CatFuzz
Postby jeremy_worden » Thu Dec 10, 2009 4:54 am
well i was going to chime in with my sob story about the starter on my 95 but it looks like you got this covered... good luck :wink:
1995.5 isuzu rodeo LSD and snowflakes
1988 isuzu trooperII []OlllllllllllllO[] 245-75-R16, yakima load warrior basket, custom rear bumper, and an AUSSIE locker, and AISIN hubs, indy4x shackles 2" lift.
cardomain and May 2011 ROTM
Isuzu Outlaw - Bikini
jeremy_worden
Have thanks: 9 times
Re: My 1995 Rodeo won't even crank.
Postby Dtermined_1 » Tue Dec 13, 2011 1:07 am
Mine is doing the same thing, except I had to replace my alternator b/c it was bad and my volt gauge is still under 12 volts but not all the time. Also, when I went to start it, everything turns on except the heater blower?? You guys still think it is the starter?? I hear the clicks, sometimes it will start other times it will not. I have checked all the wiring and the clutch safety switch is wired on always.
Dtermined_1
Postby tj_in_nm » Tue Dec 13, 2011 1:26 pm
Well this is timely, the starter in the wife's Chrysler is doing the same thing. Why is this Isuzu-related? She keeps taking the truck!
TJ Harrell
1991 Isuzu 4WD pickup
3.1LV6, 230k miles
tj_in_nm
Return to Drivetrain Problems
Users browsing this forum: Bing [Bot], jscotttroop and 1 guest
cron
