Planetisuzoo.com Forum Index Planetisuzoo.com
Welcome to the Planetisuzoo Forums!
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   GalleryGallery   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
Project: Trail rig to daily driver
Goto page 1, 2  Next
Post new topic   Reply to topic    Planetisuzoo.com Forum Index -> Drivetrain Mods
View previous topic :: View next topic
Author Message
Starchild
Old Timer
PostPosted: Tue Nov 10, 2009 2:43 pm    Post subject: Project: Trail rig to daily driver Reply with quote
I'm underway so I figured I'd post my progress on this.
A little background:
My passport has undergone several stages of modifications, and once I did the SAS, I never intended it to see much pavement time (The basic specs are in my sig). As they have a habit of doing, circumstances have changed, and I'm in the process of trying to sell my tow rig/DD to free up some cash for a growing family.
My daily commute is all of 2-3 miles, and nothing over 35 mph, so the plan is to make the old passport more street friendly and use it as a DD for the time being. This is one way I can justify keeping it around.
Against my will, I've recently put about 200 highway miles on the rig, so I know what areas need some attention. Here is my list of items to address in order of inportance:
-replace welded rear with open diff
-new rear driveshaft (current one is heavy and unbalanced)
-fix exhaust rattle
-build rear t-case mount
-fix speedometer
-install line locks (makeshift e-brake)
-replace AC compressor
-smaller more street friendly tires
I've put the tires at the bottom of the list because of price, but if I find a decent set of used 35's, I'll jump on them.
Here is my new DD Cool
This past week, I've been working on replacing the rear diff. I welded up my spider gears, so I picked up an old set for free from a friend. I failed to take pictures, but the corporate 14-bolt is a interesting axle to work on. It's a full floater, which means you can pull the axle shafts without removing the tires. One was a bit stubborn, so I had to weld a nut onto the flange since there is nothing else to grab onto, and use a slide hammer to get it out. Everything about this axle is heavy. The carrier with ring gear has to weigh 60lbs easy! The carrier is two pieces, so once you unbolt the ring gear, it splits in half, which makes replacing the spider gears simple. I just need to seal the axle back up before I move onto the driveshaft.
I've got some stock driveshaft parts that I will be combining with new parts to build a one piece shaft. It will use an Isuzu D44 flange up top, and I need to get a new 1410 yoke for the back to match up with the 14-bolt. I can only find half of a stock slip yoke, so I'll have to see if a new one is cheaper/easier than going to pull one from a yard. Going to have it professionally built and balanced. The one I'm running was re-tubed by a friend after I pretzeled it playing on some rocks. He used something like 3/8" wall drill pipe so I wouldn't have that problem again, but at any speed, it wants to shake the truck apart.
I'll keep this updated with my progress. I've gotten a couple promising calls about my Chevy today, so I need to get my butt in gear on this.
Andre
_________________
1994 Trooper - Delightfully close to stock
Back to top
View user's profile Send private message
Ads by Google:
bigpoppax2
Forum Admin
PostPosted: Tue Nov 10, 2009 7:21 pm    Post subject: Reply with quote
I think you will be glad you went this route.
I'm glad to hear you are making progress. The drive shaft will make a huge difference in getting it DD ready, the welded rear was probably no fun either.
Joe
_________________
After concealed carry guy shot a gun wielding robber....."I'm just a Law abiding citizen dumping some chlorine into the gene pool"
Back to top
View user's profile Send private message Send e-mail AIM Address
bigpoppax2
Forum Admin
PostPosted: Tue Nov 10, 2009 7:23 pm    Post subject: Reply with quote
http://jacksonville.craigslist.org/pts/1457891499.html
http://jacksonville.craigslist.org/pts/1456035115.html
Here is the best deal: 4 Pro Comp Xterrains for $175
http://jacksonville.craigslist.org/pts/1426529740.html
Look look!!!
Joe
_________________
Back to top
DAMUDKING
ReZuzuHab
PostPosted: Tue Nov 10, 2009 9:06 pm    Post subject: Reply with quote
just trade me rodeo's, much less work....and just because i like you ill through in a 3.4 and a set of new tsl's Very Happy
_________________
92 V6 RODEO, 12 bolt rear, LSD, 4.56's, 4.5" lift, 33x13.5 LTB's
Back to top
maxwell417
Old Timer
PostPosted: Tue Nov 10, 2009 10:50 pm    Post subject: Reply with quote
My daily drive is 30 miles, max speed of 65. With welded rear diff and 35s it is a pretty comfortable ride. Only times I wish for a locker or open is parking lots. If I only had to go 2-3 miles, I wouldn't bother at all. I have a balanced cv type rear driveshaft, getting driveshaft vibes gone made me very happy.
_________________
Curt B. Isuzu Troopers 89RS Delta Cam, Calmini Header, 33s & '90 3.4v6, SAS D44 ARB /Horbart 5.38s 35s my pictures
Back to top
View user's profile Send private message Visit poster's website AIM Address Yahoo Messenger MSN Messenger
Starchild
Old Timer
PostPosted: Tue Nov 10, 2009 11:40 pm    Post subject: Reply with quote
What size TSL's? Wink
I probably could have lived with the welded diff. I guess I started with that since it was free, and I needed to change the fluid anyway.
_________________
Back to top
Ditchdoc
Old Timer
PostPosted: Wed Nov 11, 2009 7:17 am    Post subject: Reply with quote
Hummmmm Idea Idea Man I really like your port.... I might have a Trooper or two that I'd trade ya if you really wanted a DD....... Wink Wink Twisted Evil
_________________
Peter
My Cardomain Page ; Tread Lightly ; SFWDA ; The BlueRibbon Coalition ; Equal Tire Balancer
92 Trooper LS 3.2L DOHC, AT, Stock, 185K, Blown head(s) and bad water pump??
94 Trooper LS 3.2L DOHC, AT, Stock, 132k Future ECORS Class B race rig
94 Trooper LS Parts Trooper
85 VW Vanagon Family Hauler (For Sale)
88 Ford F250 Extended Cab Long Bed, 460, 4X4, New Tow Rig, AKA: The Beast Twisted Evil
Back to top
Bansil
PostPosted: Wed Nov 11, 2009 7:28 am    Post subject: Re: Project: Trail rig to daily driver Reply with quote
Fixed it for you
headbang
-replace welded rear with open diff(Corporate big wigs don't like the idea someone speeding and going to run them over in the parking lot.........only to find out it's a giant monster doing 2mph).......
-new rear driveshaft (current one is heavy and unbalanced) Shocked True dat Wink
-fix exhaust rattle........should of been done years ago Laughing
-build rear t-case mount...good call
-fix speedometer...why bootyshake
-install line locks (makeshift e-brake)..Why???? ........you don't have hills down therethefinger
-replace AC compressor................ dontknow ......roll the windows down,come on 3 miles Rolling Eyes
-smaller more street friendly tires.........makes since and truck will be like a drag car with it's gearing Mr. Green vroom vroom
Andre
_________________
The Turtles' site
http://www.cardomain.com/ride/505863
My Amigo build "Lowrider"
http://forum.planetisuzoo.com/viewtopic.php?t=18800&highlight=lowrider
Back to top
marshall
Newbie
PostPosted: Wed Nov 11, 2009 10:04 pm    Post subject: Reply with quote
What size rims do you have? I'm about 1/2 way through my SAS and would like some 38" tires, the 35's look small.
Back to top
Starchild
Old Timer
PostPosted: Thu Nov 12, 2009 3:30 pm    Post subject: Reply with quote
Thanks for the commentary Doug Laughing
I never said all those items were necessary. Hell, I'll be happy with a balanced driveshaft and no leaks Wink
Marshall, my wheels are 16x8. I'm actually going to be in Tallahassee this weekend.
Andre
_________________
Back to top
younggun
Found The Light
PostPosted: Thu Nov 12, 2009 3:47 pm    Post subject: Reply with quote
it just looks weird seeing another marshall.
there arent many marshall's around.
Back to top
Smiley
Forum Admin
PostPosted: Sun Nov 15, 2009 8:31 am    Post subject: Reply with quote
Progress report?
I guess I just need to see some photos (or perhaps even a scant few words) depicting a real-live, running/driving, White 1st Gen Rodeo/Passport......... for encouragement's sake, you understand.
Cheers!
Smiley
_________________
“I don’t know what you’re painting that drive shaft for… it’s not like anyone’s ever gonna see it” ~ Joe Berry (circa 2004)
Back to top
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
Bansil
PostPosted: Mon Nov 16, 2009 7:46 am    Post subject: Reply with quote
Andre
Wink
_________________
The Turtles' site
Back to top
Starchild
Old Timer
PostPosted: Mon Nov 16, 2009 9:47 am    Post subject: Reply with quote
I was out of town this weekend, so no progress. I need to get down to the pick and pull for a drive shaft to retube.
_________________
Back to top
Starchild
Old Timer
PostPosted: Mon Nov 30, 2009 9:52 am    Post subject: Reply with quote
Sold the Chevy on Friday! Got a pretty decent price for it. Glad that's done with.
I got some work done on the Passport over the holiday as well. I was sealing up the axle shafts, and I couldn't find my torque wrench (I think it actually broke), so I was torquing the bolts with a breaker bar. The first side went fine, but I guess my arm isn't calibrated for a 2' breaker bar, because I ended up stripping out half the bolts on the passenger side hub Mad
Fortunately, when I bought my axles, the guy threw in two sets of spare axle shafts and a set of hubs. I grabbed one from the shed, and had it swapped in less than an hour.
I also got some pieces cut for the rear T-case mount. The battery is charged, so I should be rolling this week.
I also started perusing craigs list for a possible cheap DD. I found a 95 Rodeo 4x4, 5-speed locally for $400. The guy probably needs a timing belt (probably tensioner, 168k), and a clutch. I mentioned this one to the wife, and she said it sounded for a piece of junk for that price, and that she was thinking more along the lines of $2-3k for a more reliable vehicle.
Since I always listen to my wife, I started looking in that range, and came up with an '01 Rodeo 4x4, 5-speed with 122k for $2500. I'm going to call about that one today.
_________________
Back to top
Bansil
PostPosted: Mon Nov 30, 2009 11:05 am    Post subject: Reply with quote
Cool deal with chevy,5spd is the way to go,and no head issues with the 01 Wink
_________________
The Turtles' site
Back to top
Ditchdoc
Old Timer
PostPosted: Mon Nov 30, 2009 11:09 am    Post subject: Reply with quote
I like your wifes thinking, sounds like a really good women, and for sure would take her up on her suggestion, BUT I'd try to swing getting the 95 also for let's say $250-300 because if it's many issues Wink because we all know how easy those things can be fixed ad about that much cash into it with new T/B, tensioner & clutch the resell for a nice profit Smile Smile all said & done your 01 should only cost you around $1000-1500.. Twisted Evil
I hope to do this with my fleet at a yet undetermined time in the future. Now all the vehicle I have need to be running in various stages to keep the three drivers in the family driving. Not to mention the occasional buddy that needs a ride cause his s--- broke down.
Andra, on a side note I got my 2010 season trail rig from Joe D. last week,, I'm really happy she's white, 95 passport bone stock Smile I'm going to be rockin the (H) on the grill in april..
Stay tuned there will be a 95 port build thread coming your way I a few months
I known I know baby hitch hike, SORRY..... ttyl, keep use posted
_________________
Peter
Back to top
Tad
Site Admin
PostPosted: Mon Nov 30, 2009 12:47 pm    Post subject: Reply with quote
Great news. Have you made progress on the t-case to trans leak problem?
-Tad
_________________
tad@planetisuzoo.com
http://www.planetisuzoo.com
2001 Trooper - 4.77s, 3xARB, OME 919HD springs. 255x85 Maxxis Bighorn MTs
1999 Rodeo - rebuilt DD
1980 300GD
2000 Suburban
2000 E320
Back to top
Starchild
Old Timer
PostPosted: Mon Nov 30, 2009 12:51 pm    Post subject: Reply with quote
Not really. I think the leakage comes from the bolts constantly backing out. I decided to work on the rear mount, which will connect the back of the T-case to the skid plate/cross member before I pull that off to tighten up the connection. That way I can do the final welding and paint while it's off.
_________________
Back to top
Starchild
Old Timer
PostPosted: Mon Nov 30, 2009 1:01 pm    Post subject: Reply with quote
Ditchdoc wrote:
I like your wifes thinking, sounds like a really good women, and for sure would take her up on her suggestion, BUT I'd try to swing getting the 95 also for let's say $250-300 because if it's many issues Wink because we all know how easy those things can be fixed and about the much cash into with new T/B, tensioner & clutch the resell for a nice profit Smile Smile all said & done your 01 should only cost you around $1000-1500.. Twisted Evil
I hope to do this with my fleet at a yet undetermined time in the future. No I need all the vehicle I have need to be running in various stages to keep the three driver in the family driving. Not to mention the occasional buddy the need a ride cause his s--- broke down.
Andra, on a side note I got my 2010 season trail rig from Joe D. Last week,, I'm really happy she's white, 95 passport bone stock Smile I'm going to rockin the (H) on the grill in april..
I'm trying to justify keeping my rig around, so I'm not looking to pick up any more unnecessary projects.
I already got this question after I explained that I couldn't sell the passport for half of what it's worth. "If it's worth so much, why is there something wrong with it?"
Without going into the intricacies of re-engineering a highly capable, state of the art vehicle such as this, I cleverly responded with "I don't or can't spend enough time on it to get everything perfect, so I settle for good enough, which sometimes turns out to not be."
Congrats on the new trail rig!
_________________
Back to top
Ditchdoc
Old Timer
PostPosted: Mon Nov 30, 2009 5:58 pm    Post subject: Reply with quote
I totally understand so nuff said Smile good luck getting the 01,
I'm not to familiar with your current t-case/tranny issue so please fill us in on what exactly the problem was and how you fixed it (w/pic's) Smile
I'd like to build a twin to your port one of these days Twisted Evil
_________________
Peter
Back to top
Starchild
Old Timer
PostPosted: Mon Dec 28, 2009 10:40 pm    Post subject: Reply with quote
I've finally been getting some time to work on the truck over the holidays. Here's what I've been working on.
rear t-case mount
here is how it mounts
I'll get a pic of it mounted to the skid plate in the morning.
My cable shifter vibrated apart and lost several parts. This is one of the two stand-off's. It's a 12" piece of 3/8" all thread sleeved with tube to mount the cable ends.
I also lost one of the rod ends. The one on the right is the replacement.
Here it is mounted up
I have everything painted, installed and sealed. Just need to fill the t-case in the morning and take it for a drive. Depending on how it goes, I may be getting a new driveshaft this week.
_________________
Back to top
Bansil
PostPosted: Tue Dec 29, 2009 7:26 am    Post subject: Reply with quote
cool,and congrates on the calender pic,that was a fun day in the rocks Wink
How in the H--- did you "lose" a heim end?? it's threaded on the end and had a bolt in it???
Washing machines vibrate as much as those boggers and they don't "lose" bolts thefinger
_________________
The Turtles' site
Back to top
Smiley
Forum Admin
PostPosted: Tue Dec 29, 2009 9:45 am    Post subject: Reply with quote
Bansil wrote:
...Washing machines vibrate as much as those boggers and they don't "lose" bolts thefinger
There ya go! --- Just find yourself an old washing machine and scavenge all of the drum isolation apparatii Razz Laughing Laughing
I'm looking forward to seeing more pix Cool
Cheers!
Smiley
_________________
Back to top
Starchild
Old Timer
PostPosted: Tue Dec 29, 2009 9:48 am    Post subject: Reply with quote
You know how when you get a badly unbalanced load in the spin cycle, that thing wants to walk across the floor? I thin it was like that Laughing
What calender?
Andre
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    Planetisuzoo.com Forum Index -> Drivetrain Mods All times are GMT - 4 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
