Planetisuzoo.com Forum Index Planetisuzoo.com
Welcome to the Planetisuzoo Forums!
 FAQFAQ   SearchSearch   MemberlistMemberlist   UsergroupsUsergroups   GalleryGallery   RegisterRegister
 ProfileProfile   Log in to check your private messagesLog in to check your private messages   Log inLog in
1991 Trooper Restoration
Goto page Previous  1, 2, 3 ... 9, 10, 11
Post new topic   Reply to topic    Planetisuzoo.com Forum Index -> Member's Rides
View previous topic :: View next topic
Author Message
justwork
PostPosted: Wed Jul 28, 2010 2:21 am    Post subject: Reply with quote
btw1549 wrote:
I'm leaving September 13. The body is going on the frame this weekend and then I will start driving it around as I am putting it all back together for the trip and then finish everything else when I return.
Just checked out your latest pics on FB, looks sick. The progress you've made is awesome. What's the story with the bright red under side, not the primer but the BRIGHT red?
If your road trip takes you through Ontario give me a heads up, the wife and I are moving there in a few weeks.
_________________
Chris
Cherry 1991 Trooper LS.
3.4L V6 conversion, 2.5" exhaust, MUA5 Transmission, Aisin hubs, stainless brake lines, Independent lift shackles, Surco basket rack, all sitting on 235/75R15 BFG AT's
Back to top
View user's profile Send private message
Ads by Google:
btw1549
PostPosted: Wed Jul 28, 2010 9:00 pm    Post subject: Reply with quote
It's the same color I did the drive shaft, shackles, sway bars, calipers, sway bar links and soon to buy heavy duty torsion bars. It will match the frame stuff under the truck and allow me to pick out spots of rust or damage easily.
As for going into Canada, that's next years trip. Across Canada and into Alaska! This year is just a U.S. trip.
_________________
BtW - 1991 LS Trooper In Progress, Complete Restoration with 3.4L Swap! (The Tank)
http://forum.planetisuzoo.com/viewtopic.php?t=33157
http://www.facebook.com/album.php?aid=2028368&id=211501242&l=ee54b89a09
http://www.facebook.com/album.php?aid=2028932&id=211501242&l=5df63efdaa
http://www.facebook.com/album.php?aid=2030921&id=211501242&l=d0b01a4d37
RED DRAGONS!
Back to top
View user's profile Send private message Visit poster's website AIM Address MSN Messenger
hessmess
PostPosted: Wed Jul 28, 2010 10:41 pm    Post subject: Reply with quote
If Elko Nevada is on the trip, give me a shout. I-80 in Northern Nevada
Dick
_________________
85 Trooper (sold to brother)
88 Trooper (for sale, sick)
91 Trooper, Stock, Fiero valve covers, starting to build an upgrade engine
Back to top
View user's profile Send private message Send e-mail
btw1549
PostPosted: Thu Jul 29, 2010 1:38 pm    Post subject: Reply with quote
Dick
I'm going to start a thread in one of the other locations for the trip with the stops that are planned. I have around 55 stops so far.
_________________
RED DRAGONS!
Back to top
btw1549
PostPosted: Mon Aug 02, 2010 9:19 pm    Post subject: Reply with quote
I hate posting the week after I do something because I forget everything that I accomplished; but I will try and fill you in the best I can.
Step 1, seam seal all openings that dirt and debris can enter and cause rust.
As you can see when I said all openings, I meant all openings.
Step 2, Undercoating
I was going to use herculiner originally to coat the underside but could not find any store that carried herculiner in the spray-able bottles for my schutz gun and wasn't sure how the gallon role on kit would spray, so went with plan B which I think was a better option in the end anyway. You know the rough coating under the paint on the rocker panels of German cars (VW in my case), called chip guard, went down to my body shop guys and picked up two bottles of the stuff to spray with my schutz gun. Can't believe how awesome it worked and looked. I sprayed it at 65 psi which gave it texture but not like 60 grit sandpaper texture as the herculiner is.
Pictures...
I'm going to do the front wheel wells with this as well once I reinstall them. It is supposed to reduce noise as well so we will see how it helps. I can honestly say the stuff really is chip resistant. Your local autoparts or body supply store only sells it in aresole cans though and I'm not too sure how that compares to this stuff.
Step 3, Top coat.
Wasn't 100% sure what color to make the underside. I had a couple choices to use that day, Gloss Sunrise Red, John Deere Yellow, Gloss Hunter Green, High Gloss Black (the same as the frame), and Regal Red. I was thinking yellow because I was still unsure what color I was painting the truck and was thinking yellow so going yellow would make sense in that aspect. Then I thought black but if I started to have rust and things occur black would make it hard to notice. Then Regal Red wouldn't match anything. Gloss Sunrise Red is the color of the sway bars, calipers, shackles, soon to be torsion bars, and drive shaft so it would match my frame colors. End pick, Gloss Sunrise Red. Pictures...
It looks better in person than in the pictures. I really like the way it turned out. As you can see in the first picture I painted the firewall black as well anticipating putting the body back on and not getting to the firewall later on.
Also you won't see the red unless you're under the truck because I am leaving the wheel wells black.
So know the body is ready to go back on the frame! As soon as I get the next pictures loaded I will post this weekends progress. Schools over this week too so I will have more time next week to work on it after work.
Enjoy the pictures!!
_________________
RED DRAGONS!
Back to top
govno88
Deer in the headlights
PostPosted: Mon Aug 02, 2010 11:58 pm    Post subject: Reply with quote
btw1549 wrote:
Yea I was surprised when I saw what "good" shape it was in. It was far from perfect but it was better than 98% of the ones I've seen around my area! Here are a few shots of the worst spots.
The rear DS section. If you look close to the back portion you can see how it is rotted out.
This whole section of the back PS was extremely week from the body mount back. Where the visible crack is I took my body hammer to it and it went right through. I was surprised the Shackle hadn't pushed through like most of them I see.
The rear bump stops were gone. The base was still bolted to the mount but the rubber was gone!
This is one of the four holes that were found on the passenger side.
The trans mounting bar mounts were pretty bad.
damn! i'm glad i live in southern california!
_________________
it's OK for you too!
1990 trooper XS 2.8L auto
currently building 3.4L
Back to top
Metal88
Old Timer
PostPosted: Tue Aug 03, 2010 12:17 am    Post subject: Reply with quote
coming out fancy! Very Happy
_________________
who needs fake wood on cars to make them look luxurious when you have aluminum diamond plate!
-BRUTAL WAGON's first run-
http://www.youtube.com/watch?v=ewQpxCItR2c
Back to top
JLEMOND
PostPosted: Wed Aug 04, 2010 10:32 pm    Post subject: Re: Painting inside of frame Reply with quote
btw1549 wrote:
Well the next step after spraying the rust reformer inside of the frame and letting it dry for a week I was to go ahead and coat the inside with this stuff...
Rust-Oleum Industrial Gloss Black. This is what I'm doing the whole frame with. It's that "Rust Proof Guarantee" That I have used and seen work in the past that made me go with this. Plus, like I said before I plan on coating the inside of the frame once a year with this stuff and you can both buy this and spray this easily. Here's some pics of the finished project.
I used my same rust proofing gun but had to modify my holes with a little bone saw to give them more of a fan pattern because the paint was thick, even after thinning it. It worked well though and coated the inside sufficiently. Now the inside of the frame should be coated and protected very well! I'm hoping it holds up very well in my PA winters. I guess well have to wait and see. Definitely not this winter. Hopefully next winter though since my trip is planned for august!! Here's the link you can go to to see all the pictures of the frame up to this point. Now I just have to sand the outside from all the runs and stuff that got on it while doing the inside and put the final coats on it. Then it will be time to put things back together.
GREAT LOOKING JOB MATT JERRY
Back to top
nickgust44
Found The Light
PostPosted: Thu Aug 05, 2010 3:28 pm    Post subject: Reply with quote
I've been watching this thread for awhile now, but haven't said much. But i gotta tell ya that you're doing one hell of a job bro
_________________
1995 Honda Passport 168k miles
2" Calmini T-bar+Shackle lift/ 1/4" BJ spacer + flip
33" x 10.5" BFGoodrich TA KO's
K&N Intake / NGK Spark Plugs
Tint = 45% (front) 5% (rear)
100 Watt Pro Comp slim lights
Back to top
btw1549
PostPosted: Thu Aug 05, 2010 8:04 pm    Post subject: Reply with quote
Thanks everyone for the comments! More to come soon.
_________________
RED DRAGONS!
Back to top
btw1549
PostPosted: Fri Aug 20, 2010 10:18 pm    Post subject: Back on the frame and fire wall painted Reply with quote
I haven't updated because every night after work I have worked on the truck until going to bed to do it all over again the next day. It's coming along nicely. Here are shots from like two weekends ago of the work I did after dropping the motor back in the ranger.
Got the firewall painted with the color that the truck will be in. It called Ignition Orange Metallic. It's a GM color for the G8. not many in this color were sold and I'm not sure why because it is a sweet color.
It has a lot of gold metal flake in it!
Here are some shots of the body back on the frame. Had a few issues putting it back on like my fuel tank vent line just happened to be mounted in the exact, and I mean exact same spot as the body harness. Cargo box fits perfect and leaves plenty of room for a muffler. I used all stainless steel bolts for the body mounts. Got super surprised by how high the back end sits, this first pic will actually show stock and mine next to each other! Even all the cross bars for the rear floor where in the exact location they needed to be!
Then we seam sealed the rear inside so I could topcoat and get the carpet back in.
That's all I have uploaded for now. I'll tell you I have made a lot of progress though but haven't taken as many pictures as I normally have because it's been no stop. I'll update with the rest next chance I get.
_________________
RED DRAGONS!
Back to top
Metal88
Old Timer
PostPosted: Sat Aug 21, 2010 12:39 pm    Post subject: Reply with quote
oh its gona look sweet! what are you gona do about the front? crank the t bars?
_________________
Back to top
btw1549
PostPosted: Sat Aug 21, 2010 9:16 pm    Post subject: Reply with quote
Yeah, I'm copying squatch and cranking the front a little but not all the way so it will have a little bit of a rake. I am planning on buying the indy heavy duty torsions soon as well so that will help.
_________________
RED DRAGONS!
Back to top
rondolfo1983
Newbie
PostPosted: Sat Aug 21, 2010 11:02 pm    Post subject: Reply with quote
excellent work! This beautiful being!
Back to top
justwork
PostPosted: Mon Aug 23, 2010 9:27 pm    Post subject: Reply with quote
Update. I think I saw on your FB page that you ordered that lizard skin.
_________________
Chris
Back to top
shooter
PostPosted: Mon Aug 23, 2010 9:45 pm    Post subject: Reply with quote
I tip my hat. Simply incredible. Lost for words. Hell of a lot of work is definitely paying huge dividends. Makes me proud to see you going after this thing. Job well done.
_________________
1989 Isuzu Trooper S/ 4WD / 2.6 Litre 4 Cyl 4ZE1 / 5-speed Manual (MUA5) / Warn Premium Hubs / Fancy Radio / Deluxe Intermittent Combination Wiper Switch / Applied Date: Jan. 89
I'd rather laugh with the sinners than cry with the saints
Some people are like Slinkies; they are not good for anything, but they still bring a smile to your face when you push them down a flight of stairs.
Back to top
VX1032
PostPosted: Tue Aug 31, 2010 10:08 pm    Post subject: Reply with quote
Amazing how much work you are doing, and how qucikly. Gonna be the newest trooper on the road when you are done.
_________________
Ryan Christiansen
99 Vehicross 1032
OME 912's, Stric9 Sliders, Definity Dakota MT 285/75 R16, Aussie Lockers Front and Rear, 4.77 gears and Warn Premium Manual Hubs.
88 Trooper 2.6 Auto with Snowflakes and 235/85's, and a pickup bed! In progress http://picasaweb.google.com/RyanVehiX/ProjectBruiser#
Back to top
stusvend
PostPosted: Wed Sep 01, 2010 10:52 am    Post subject: Reply with quote
Simply amazing Matt. Doing great brother. The seam sealing alone is incredible. And yeah, your right. That underbody coating they use on VW's is some serious s---. It seems to do an awesome job stopping rust and my Jetta was pretty damn quiet too. Is that stuff commercially available? I think these trucks are supposed to rake forward anyways. I cant remember what you have on your rear suspension. Did you add a leaf or are they just new springs? If it's that high with that HD steel floor and wheel wells you put in there, imagine what it would be like with the stock set up.
Oh yeah, loving the color too. Best thread ever.
_________________
Matt
88' Trooper LS 2.6L manual "Smokey" & 69' Toyota FJ40 Land Cruiser "Sherman"
Smokey's story and build: http://forum.planetisuzoo.com/viewtopic.php?p=304331#304331
my music: www.myspace.com/mattgreermusic
Back to top
btw1549
PostPosted: Wed Sep 01, 2010 1:53 pm    Post subject: Reply with quote
Thanks for the great comments. If nothing else it makes me feel proud of my work.
That coating unfortunatly is not avaiable to regular consumers but the body shops can get it. One of the reason I haven't listed the name of the stuff or the body shop that got it for me!
I do have OME spings in the rear but stock height shackles. And I was also amazed because the back definitely weights more not to mention the extra weight of the frame.
Sorry I haven't updated latelty either but I have been spensing everynight after work down the garage to finish her. A little side update it does run and has all it's components together. just need to bleed the brakes before driving and put a temporary exhaust on it to get it to my buddies place so I can use his mandrel bender. I am leaving the 15th of september for the trip so I have to start driving it this weekend.
_________________
RED DRAGONS!
Back to top
justwork
PostPosted: Fri Sep 03, 2010 6:11 pm    Post subject: Reply with quote
If you poke up to Canada in the Toronto area shoot me a message, we'll have a beer!
_________________
Chris
Back to top
Display posts from previous:
Post new topic   Reply to topic    Planetisuzoo.com Forum Index -> Member's Rides All times are GMT - 4 Hours
Page 11 of 11
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
