Planetisuzoo.com Welcome to the Planetisuzoo Forums!
| View previous topic :: View next topic |
| Author |
Message |
justwork Donor
Posted: Fri Aug 28, 2009 9:25 pm Post subject: Block Heater - and winterization idea's? |
Anyone install one in a 2.8L 6cyl? Would it be the same as a 3.4L? Is there an "isuzu" block heater that would be best for a 3.4L? Or anyone have great experience with an aftermarket heater?
Like I have said before, the wife and I are trying to move out to the East coast, it's a little colder than the Pacific NW, and I wouldn't mind starting some winterizing project. I was also thinking about a battery heater, and potentially oil pan heater. I've seen a couple oil pan heaters that are pretty much glued onto the outside of the pan. I'd like to have them all wired together so I only have 1 plug, but I'm thinking the current draw may overwhelm 1 socket.
Thoughts and idea's? Only thinking this to the extreme because I'm a pilot, and my Trooper is often left in a parking lot for DAYS. I could see after working 3 days on heading out to my truck in the dead of winter and it not wanting to turn over. ugh. _________________ Chris
Cherry 1991 Trooper LS.
3.4L V6 conversion, 2.5" exhaust, MUA5 Transmission, Aisin hubs, stainless brake lines, Independent lift shackles, Surco basket rack, all sitting on 235/75R15 BFG AT's |
| Back to top |
Ads by Google:
justwork Donor
Posted: Tue Sep 01, 2009 11:45 am Post subject: |
nothing? Everyone lives in warm climates? _________________ Chris
| Back to top |
stusvend Donor
Joined: 08 Jul 2009 Posts: 2257 Location: Nashville, TN
Posted: Tue Sep 01, 2009 12:47 pm Post subject: |
I used to live in a very cold climate, but all I ever used was an oil pan heater. It was just like the one you described. At any rate, it seemed to be quite sufficient. I lived at an elevation of about 8,000 feet in the rockies of Montana. It routinely got 20-30 degrees Farenheit below and winter lasted about 7-8 months. I'm not sure how that compares to where you're going, but maybe it will help. _________________ Matt
88' Trooper LS 2.6L manual "Smokey" & 69' Toyota FJ40 Land Cruiser "Sherman"
Smokey's story and build: http://forum.planetisuzoo.com/viewtopic.php?p=304331#304331
my music: www.myspace.com/mattgreermusic |
| Back to top |
Grumpfrompahrump Has a Trail Truck
Posted: Tue Sep 01, 2009 3:17 pm Post subject: |
I had one installed on (block heater) my 2.6 when I was stationed in North Dakota. I was only able to get one at a dealer (in Fargo). My experience with much colder weather than you will have, is a block heater and battery warmer are all you need. They will run off one plug. The warm coolant gives you instant heat too when you start it up at -40!!
Also, look around for a radiator cover. They make them for most SUV's, and are like the ones big trucks use when it is cold. You start up, nice and warm, but the minute you drive away the bitter cold air will make your engine cold again! So you need to block the air flow. _________________ Steve
2000 Amigo Ironman, 3.2L Auto 4WD
1988 Trooper, 2.6L Auto, 4WD, Calmini Cam/Headers
1982 Cadillac Fleetwood Hearse
1927 Ford Model T Roadster w/327 Chevy |
| Back to top |
justwork Donor
Posted: Tue Sep 01, 2009 4:07 pm Post subject: |
thanks for the tip _________________ Chris
| Back to top |
deaconball21@gmail.com Mud King
Joined: 26 Feb 2008 Posts: 620 Location: Winston-Salem, NC
Posted: Tue Sep 01, 2009 4:50 pm Post subject: |
Where are you planning on moving to? _________________
99 Passport, BFG A/T, 3" Taller, 120k, Flowmaster, Audio system, 4x Hella |
| Back to top |
Ditchdoc Old Timer
Joined: 07 Aug 2008 Posts: 1543 Location: Fayetteville, NC
Posted: Tue Sep 01, 2009 5:35 pm Post subject: |
| deaconball21@gmail.com wrote: | | Where are you planning on moving to? |
x2 You said east coast........ I guess your refering to the North East Coast  _________________ Peter
My Cardomain Page ; Tread Lightly ; SFWDA ; The BlueRibbon Coalition ; Equal Tire Balancer
92 Trooper LS 3.2L DOHC, AT, Stock, 185K, Blown head(s) and bad water pump??
94 Trooper LS 3.2L DOHC, AT, Stock, 132k Future ECORS Class B race rig
94 Trooper LS Parts Trooper
85 VW Vanagon Family Hauler (For Sale)
88 Ford F250 Extended Cab Long Bed, 460, 4X4, New Tow Rig, AKA: The Beast
| Back to top |
justwork Donor
Posted: Tue Sep 01, 2009 5:48 pm Post subject: |
East coast Canada... Nova Scotia - and the winters there can get pretty cold. I just want some mods that will ensure trooper starts EVERY time. _________________ Chris
| Back to top |
Pilsner Newbie
Posted: Fri Sep 04, 2009 12:10 pm Post subject: |
a block heater is all i use in northern B.C. and run 10w30 oil in the cold months. haven't had an issue and it's normally around -30 to -50. _________________ '95 rodeo, 3.2, 5speed, stock for now.........
" leave it to me to find a 4 foot snow drift in may....... pass me the shovel." |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
Powered by phpBB © 2001, 2005 phpBB Group
