After being told by the dealer that the thunk in the driveshaft is something that all the Rodeos do when starting and stopping, I decided to do something about it. I pulled off the drive shaft and cleaned the old crappy grease out the slip joint. Repacked the slip joint with new moly grease and put it all back together. The inital test drive showed no sign of the clunk, problem solved, took about an hour to do. I used CV joint metal clamps on the boot ends but I think a big nylon tie-wrap would work just fine.
HTH Randy
If we only had GREASE FITTINGS :roll: !!! That's as good a job your gonna get Randy! Like you did- use the best quality grease you can possibly get & keep a leak proof seal on the boot. How many miles did you get out of it before you had to grease it?
Joel
JOEL,
39,000 miles, I just bought it about 2 months ago. It was thunking when I drove it away from the car lot. I would imagine it could be replaced with a zerk style slip-joint for about $200. It's not really that bad of a job.
I tried to get my Isuzu dealer interested in the fix but they like to keep their head-in-the-sand.
Later....Randy
¡Oracle!,
You won't slip..It's really easy to do. The hardest part is breaking loose the driveshaft bolts, PB blaster would help. It's not necessary to hold the bolt head, it will be held by the yoke. Just get a long 14mm or 9/16 box end wrench and go for it. I found that brake clean removes the old grease really well. Make sure you mark the driveshaft alignment with the yokes and slip joint using a grease pencil. Jack up the rear wheels so you can rotate the driveshaft and your in business. Also use a good quality grease like a moly or synthetic. Use CV joint metal straps or large tie-wraps to secure the boot ends.
HTH.... Randy
The reason I asked is because I happen to have a bunch of spare CV boot straps, 2 cans of synthetic Duralube, and lots of free time.
I happen to have this nasty habit of accidentally splitting/cutting boots when I'm working near them that's all. Never happens to any other fragile parts, just boots... Must be all the grease
DONT GET TOO EXCITED FOR THE NOISE WILL RETURN NEXT TIME GO DOWN TO THE NAPA STORE AND PURCHASE RED CROWN IT IS A THICK GREASE TRY NOT TO GET THE NASTY STUFF ON YOU FOR IT IS DREADFUL TO WASH OFF THIS SHOULD LAST MUCH LONGER THAN CONVENTIONAL DRIVESHAFT LUBE AOR AXLE GREASE
I had my dealer repack mine a couple months ago. I took it in with 7k and asked about the thump and they said it was normal (yeah right!). So at about 38k I paided to have it repacked. 2wks later the thump was back. I'm use to it now.
Ryan,
The dealer should have packed your slip-joint under warranty at 7K miles. Their isn't a lubrication schedule for the slip-joint, so the failure and drivability problems wasn't your fault. Contact Isuzu customer service and see what can be done. I think there was a TSB on the problem.
HTH :lol: Randy
Jeeze Mike, If you've done all that work to your truck, you shouldn't
need to ask how to take off the driveshaft..maybe you need to buy a service repair manual.
Just roll up your sleeves and crawl under the truck and see for yourself. It's pretty self explanatory once you actually see it the for the first time.
HTH...Randy
Howdy, I'm can't remember if this is a one piece or 2 piece set up. Mike, if 2 piece start at the center and work toward the axle, if one piece start at the axle end. Just unbolt the shaft and when it is free the slip joint should pull straight out. Clean it out really well and repack with grease. Choose a high quality grease here. Let us know if you have any difficulty.
Randy, everyones experience is different. No need to blast someone for asking a question.
Come on Kevin,
Somebody that has to ask how to take off a drive shaft, either hasn't actually looked at the task or really shouldn't be working on the truck.
That would be like asking "how do I take off a tire".
I'm not mad, everybodys different and has varing degrees of abilities. You've just got to know your limitations.
Thats why they have a service dept at the dealeship. HTH....Randy
I just like doing as much homework as possible before starting on a project, small or big. Hopefully it minimizes on head scratching time and critical parts hunting at the local parts store.
Those Haynes/Chilton manuals usually aren't the best at explaining the actual procedure. I much prefer people's first hand experiences/tips.
Howdy folks. Mike I applaud you for doing your homework before the job.
Randy, I meant no offense. Still, what looks simple not always turns out that way.
Let's take your tire theory. I once bought a truck a few hundred miles from my house. I got it from a friend, so I knew it was good to drive, but the tires were shot. So I went down to Les Schwab and had the kiddies down there put on some new tires. I TOLD them the lugs on the rear axle were left hand thread. Still, needless to say the morons broke off 3 studs before reading the work order. Since they couldn't find any LHT that were correct for my drums, I made them replace all the studs on both sides.
hey i notice the same noise sometime on my 99 Trooper it Thunk or Clunk when i stop or take off from at a stop is this a Rodeo/Amigo only problem? if not is it the same fix for the Trooper?
NYCoffroading, this is getting to be a habit :lol: No problem as I am glad to try and help.
Yep a clang can be caused be lack of grease in the slip joint. Like already noted Troopers have a zerk fitting. Thus, we have an easy cure. We can just squirt some grease in there rather than having to ubolt the shaft. Might as well also do the 2 on the ujoints while you are down there.
hehehe THANKS TOMSTER!
I can be quite a fanatic as u can see and I am a natural born worrier(especially things that will cost me big $$$ to fix) and as an Engineer I can't help but be inquisitive about things like this especially about this kinda stuff unfortunately I am a Techsupport Engineer, union law forbid us to touch the stuff and that good considering I am abit spazzy with my hands(or just lack confidence), but i swear this Trooper will make a Grease monkey outta me yet GRRRRRRRR ! thats a good thing! hehehe but again thanks for your help and all on here this Suzu newbie really appreciate it!!! :lol:
The 3 fittings are on the rear drive shaft. Follow the shaft out of the TOD unit. The first one is in the ujoint about 1' away fromt the TOD. It may take 1 or 2 squirts of grease. Won't help with the clunk but while you are down there you might as well do all the zerks. The next one is about 1/2-1' further past the ujoint. This is the one that should help with the drive shaft clunk (the tranny downshift from 2nd to 1st is something else and unfixable AFAIK). This one could take up to a half dozen squirts of grease. The third and final zerk is in the ujoint at the rear of the shaft by the rear diff.
Depending on how lucky you are all three fittings could be pointing straight up and therefore hard to see/grease. This is especially the case with the ones in the ujoints. You may need to move the vehicle a foot or or so to move the zerks into view.
IHTH but I am doing it from memory so some of my mearsurements may be off some.
Related Threads
Isuzu SUV Forum
895.9K posts
38.1K members
Since 2003
