project towboat(6-5-10 flares)
Postby squatch » Mon Apr 02, 2007 12:26 am
I thought I'd start a project file in case anyone wanted to follow my buildup. This is the 86K mile trooper that tad posted under hot deals. http://forum.planetisuzoo.com/viewtopic.php?t=10098 I bought this to replace a new pickup that was a lemon and was repurchased by manufacturer. I needed something that I could work on that would tow my newly restored bassboat. http://s172.photobucket.com/albums/w3/s ... ation%202/ http://s172.photobucket.com/albums/w3/s ... storation/ anyway here is the link to pics of "88 trooper http://s172.photobucket.com/albums/w3/s ... 20towboat/ http://s172.photobucket.com/albums/w3/s ... wboat%202/ I will try to update as project continues. I'm upgrading suspension, brakes, exhaust, engine power, and fixing what probs there are. Just doing what I did on my 1st one yrs ago with a few changes. Any questions feel free to ask.
viewtopic.php?t=12172
viewtopic.php?f=15&t=43909
viewtopic.php?f=15&t=56442
For this post the author squatch was thanked by:
btmseb
squatch
Has thanked: 66 times
Have thanks: 328 times
Postby Slinky » Mon Apr 02, 2007 1:53 am
Nice work Image Looks like they did a great job on the gas tank. Keep us posted.
93 Rodeo 3.2 auto 4x4 205,000 miles
Indy4x 3" lift, HD tie rods, SS brake lines
DOR diff drops, UB Skidders
31" BFG A/T's
91 & 02 Ford Explorer 4x4s, Both bone stock
Slinky
Postby DREDnot » Mon Apr 02, 2007 3:29 am
Looks nice!
I guess that Nu-Finish car polish really works
89 TROOPER ,2.6L ,5 spd,T-bar crank and shackle lift, 235/75R15 Goodyear Wrangler Radial,(31x10.50R15 geolandar MT+)
07 Dodge 2500 Megacab,4x4,5.9L diesel,6 spd
74 Jeep CJ-5,4.2L,3spd.
"Non Vi Sed, Arte"
DREDnot
real paint
Postby squatch » Mon Apr 02, 2007 9:57 am
It's amazing what you can do with real paint and some rubbing compound. These old trucks don't have basecoat-clearcoat paint. Haven't done the whole thing yet. Working on mechanicals first.
squatch
new frame pics
Postby squatch » Mon Jul 30, 2007 12:00 am
Like most projects life has gotten in the way since I started this thread. I have taken pics of all work done but haven't posted much yet. Recently I found a hole in the frame after having done much work. This was a show stopper for a while. I wasn't sure if I wanted to keep going on this project, but decided WTH. I've already got too much in it. I found a sweet and clean rust free frame(rolling chassis really)frame locally that spent most of it's life in N. Carolina. It was close to home and delivered to my drive for under $500. This project has gone from a fixer upper to a frame off almost resto. here is the frame pics. http://s172.photobucket.com/albums/w3/s ... t%20frame/ I intend to clean, paint and move my OME suspension, and gas tank from other frame then swap body. Then reinstall engine and trans replacing rubber hoses,seals and clutch as I go. Honestly if I had known I would be getting in this deep I probably wouldn't have started this project. It has gotten way out of hand!
squatch
Postby Hack » Mon Jul 30, 2007 12:31 am
Nice looking frame. That bad boy must have spent most of its life down south.
Mario
Hack
Has thanked: 7 times
Have thanks: 128 times
Re: real paint
Postby onetouch » Tue Jul 31, 2007 2:22 am
squatch wrote:It's amazing what you can do with real paint and some rubbing compound. These old trucks don't have basecoat-clearcoat paint. Haven't done the whole thing yet. Working on mechanicals first.
Some did, some didn't.
My 89 has the clear coat.
It's good, much redder.
The down side is that every summer a new patch of clear coat decides to start peeling off, so I have to get out there and wet sand, feather, rub it out and try to shoot some clear on the area, wet sand some more and get it to match.
I figure that at the rate I'm going, I'll have it all replaced in about five years. :roll:
My 91 didn't have the clear coat.
Much easier to deal with.
Washed it, rubbed it out, waxed it and forgot it till the next time.
Not quite as bright, but good enough.
Jim
Red-1 89 Trooper, 2.6, 5 speed, bunch of stuff.
Red-2 91 Trooper, 2.8, 5 speed, acquiring stuff.
If you can read this thank a teacher - and if it's in English thank a soldier.
onetouch
links added
Postby squatch » Sat Aug 04, 2007 2:05 am
I finally got some pics together of work done before frame issue. Some stuff such as suspension will be moved to new frame. It has now been stripped to bare frame and lower a arms and degeased(gunk and pressure washer). I hope to start painting frame tomorrow. http://s172.photobucket.com/albums/w3/s ... t%20frame/ I have painted most of the black parts with duplicolr bedliner applyed with special roller. http://s172.photobucket.com/albums/w3/s ... d%20parts/ The rear of frame and body underside has been cleaned and painted and rear supension and new brakes installed http://s172.photobucket.com/albums/w3/s ... uspension/ I also repaired rusted out part of core support with new part from california. It was not as rust free as thought so we added metal, drilled out old welds and used bolts to reinstal. http://s172.photobucket.com/albums/w3/s ... %20repair/ and pass part of interior has been CLEANED and new vinyl flooring put in to replace NASTY carpet. Just had to take back out to remove shifter and body bolts for frame swap http://s172.photobucket.com/albums/w3/s ... 0interior/ Iwill try to update as work progresses. Slideshow button is good way to view. Enjoy!
squatch
Postby Hack » Sat Aug 04, 2007 9:04 am
Looks like you are making good progress. Don't forget to give me a call when you are ready for the move.
Mario
Hack
yep
Postby squatch » Sat Aug 04, 2007 6:30 pm
Got the frame primered today. Man it was hot out there. I'm hopeing to pull old frame out next weekend. If I can get motor out during the week. Then I figure 2 weeks to set up parts on new frame then put it under.
squatch
Postby Hack » Sat Aug 04, 2007 7:32 pm
Priming in that heat! You must be really motivated. Between the fumes and the perspiration dripping into your eyes, I don't know how you did it.
Mario
Hack
updates
Postby squatch » Mon Aug 13, 2007 11:21 pm
Since last update. I have removed everything from new frame. cleaned it twice. Primered and painted 1st coat of black. One more to go. It is brush painted with rustolium industrial paint. There are some drips but under the hot conditions it turned out well anyway. I have pulled the tranny and engine out of the trooper and intend to pull out bad frame this weekend. some pics http://s172.photobucket.com/albums/w3/s ... 0progress/ If you go to my photobucket page::click on my user name "squatchout" and you can see all the albums. clicking the slideshow botton on each is a good way to veiw. Enjoy!
squatch
Postby Hack » Tue Aug 14, 2007 8:29 am
Mark,
Are you changing the timing belt, hoses, etc. while you have the motor out?
Mario
Hack
Postby slurpeemcnacho » Tue Aug 14, 2007 8:31 am
Nice paint job on the frame....I wish I did that on my frame swap.
"Water, water, every where,
And all the boards did shrink ;
Nor any drop to drink."
'94 Isuzu P/U 3.1L - SOLD!!!
Currently Isuzuless.....
slurpeemcnacho
Postby squatch » Tue Aug 14, 2007 8:40 am
Hack wrote:Mark,
And the whole cooling system and the body,motor,trans mounts, and all the hard lines, gaskets and seals. swapping the front suspension from the old frame(except lower a arms) including steering parts And anything else that looks questionable or might be a pain to get to later.
squatch
frame swap
Postby squatch » Sun Aug 19, 2007 9:41 pm
The old frame is out. The rear suspension has been swapped from rusty frame to new. The process: lifted trooper with big floor jack at rear diff and front cross member. The truck was set on 2 courses of concrete blocks under each wheel. Then rear was raised and temp concrete+wood blocks placed inside of frame to support rear of body. Lowered back down enough to slide timbers between frame and body. raised back up(at rear diff) enough to remove temp supports and put permanent supports under timbers. Then removed 1 course of blocks under R wheels and lowered frame. Same process in front. Then raised rear again to remove last course of block then same in front. Little by little as I did this job alone. Once wheels were on ground I realized I had mismeasured and had to roll front of frame on jack to remove as front tires wouldn't fit under front timber support for body! Later in day a friend dropped by and we swapped recently rebuilt rear suspension onto new frame. Once front suspension is removed and cleaned and painted, that and steering parts will be moved to new frame. here are some pics. All told it went very well. http://s172.photobucket.com/albums/w3/s ... ame%20out/
squatch
Postby Hack » Sun Aug 19, 2007 11:58 pm
Looks like this was a lot of fun.
Mario
Hack
Postby onetouch » Mon Aug 20, 2007 3:51 am
My hat's off to ya.
Pretty big piece of work to pull off working alone.
Looks like you got er done though.
Jim
onetouch
thanks
Postby squatch » Mon Aug 20, 2007 9:18 am
Well it's not like I was picking the truck up or anything. I usually work alone so I just take a few extra steps to make sure things are safe. And work slowly. The jack did all the work. I'm getting to old and too many miles on me for heavy lifting. The worst part is getting up and down out of the floor dozens of times.The biggest fun was several trips to get more blocks and timbers in the wifes Honda crv. Thats the next best thing to a Trooper. I have been suprised at what it will carry if I don't get stupid about it! Every notice how you always need a truck when your working on your truck?
squatch
Re: thanks
Postby Hack » Mon Aug 20, 2007 9:41 am
squatch wrote:Every notice how you always need a truck when your working on your truck?
:lol: :lol: Sort of like you always find what you are looking for in the very last place that you look.
Man, you used a lot of blocks. That poor CRV must have been dragging its body on the ground.
Mario
Hack
nah
Postby squatch » Mon Aug 20, 2007 12:05 pm
Nah the small ones 8" I had. The big ones 12" I had to buy. I wanted it stable enough to work under. I took 2 trips only 12 blocks each trip. Only about 520 lbs not to bad. I was more worried about the soaking wet(heavy PT) timbers sticking out the back window resting on the tailgate. Lot's of short trips. I use it but don't abuse it too much. I have to answer to the wife if I mess it up.
squatch
Re: nah
Postby Hack » Mon Aug 20, 2007 12:12 pm
squatch wrote:I use it but don't abuse it too much. I have to answer to the wife if I mess it up.
Same with my wife's Sienna!
Mario
Hack
update
Postby squatch » Wed Oct 10, 2007 11:55 pm
Frame is almost ready to go back under the truck. It's been painted, rear OME springs + shackles installed, front sway-away torsion bars, F+R OME shocks installed, pro-comp steering stabilizer, Indy4x tie rods, powerstop rotors, EBC 6000 brake pads, Indy4x stainless brake lines, low profile droop snubbers. cv axles rebuilt and new boots, A 4:77 front diff from a planet member installed. Hubs repacked and new seals, New Superwinch manual hubs(clearcoated). Diff breather lines extended. The part no one ever tells you about with restorations is the hours spent cleaning and painting parts. I probably have 60 hrs since last update just sitting at a bench grinder with a wire wheel cleaning bolts and small parts. Still waiting on a couple of critical parts before the frame can be put back. Enjoy the pics. http://s172.photobucket.com/albums/w3/s ... %20update/
squatch
Postby onebadtrooper » Thu Oct 11, 2007 12:08 am
Wow That looks great!!!!!!!!!!
89 trooper, 6"lift, 35x13.50R15 baja claws, tera low 3.07's and 5.38's.custom bumper F&R, built 3.4L,safari snorkel.
93 trooper s SOLD..
2001 trooper 3.1L turbo diesel conversion ,yokahama geolander a/t's 265x75r16, ARB bull bar. 2wd to 4wd conversion, rock sliders, ARB roof rack with IPF lights, ARB front locker.
two troopers in a family of isuzu's
onebadtrooper
Postby Hack » Thu Oct 18, 2007 9:19 pm
Mark,
It was fun working on your project last weekend. The photos do not do it justice. When you are done you will have a better than new first generation Trooper. Stainless steel lines. Modified suspension. I can't wait to hear that exhaust. Sweet.
Thanks again for the driveshaft. I installed it tonight, after cleaning it up and lubing it. Had the Old Trooper up to 75 and felt absolutely no vibration from the drive train.
Mario
Hack
