98 trooper acceleration problems when engine warm
Postby derekthefisher » Sat Feb 19, 2011 4:28 pm
Just got this trooper. 120000 on it. Problem started randomly. Runs like a champ until operating temp is reached and then bucks and hesitates when you give it gas. It will ride fine with light gas pedal pressure but as soon as you try even a gas it bogs and bucks. So far I have done new plugs, fuel filter, egr, pcv and inspected vaccume lines. Still have the problem. There are no codes or lights. I have spent hours searching forums trying to figure this out. This seems to be the "spot". Look forward to hearing from anyone with their 2 cents.
derekthefisher
Postby tonnydoodles » Sat Feb 19, 2011 9:02 pm
how's your fuel filter? i'd change that first, tps could be the culprit as well, start on those two and give us an update
"if you make something idiot proof, someone, somewhere is raising a better idiot" 99 trooper,98 land cruiser,99 trooper
tonnydoodles
Has thanked: 19 times
Have thanks: 26 times
Postby tonnydoodles » Sat Feb 19, 2011 9:08 pm
i'd have the alternator checked as well, do you notice the problem once the fan comes on?
tonnydoodles
Postby 78fbta » Sun Feb 20, 2011 8:55 am
Do a fuel pressure test while driving,you may see a drop in press.
As stated above, fuel filter may be clogged or pump on its last leg.
Could be elec. but id start w/fuel.
2000 Rodeo LS (stock)Image
78 T/A (far from stock)
02 Diamante LS (stockish)
95 Jeep GC Limited V8(stock)
78fbta
Return to Drivetrain Problems
Users browsing this forum: DarthTrooper, Sounder and 3 guests
cron
