no power in truck after jump start
Postby simm55845 » Thu Apr 20, 2017 9:24 am
hello isuzu nation,
after jump start truck is running but tacometer wont register,wipers run slow radio blinks and truck finally dies again. this time it wont start with a jump. battery volts register 11.64.
please help.
thanks all
simm55845
simm55845
Has thanked: 60 times
Re: no power in truck after jump start
Postby Buster28 » Thu Apr 20, 2017 11:34 am
Sounds like you hooked up the jumper cables backwards and smoked the alternator and blew some fuses.
02 Rodeo Sport 4X4 3.2L V6
simm55845
Have thanks: 863 times
Postby DSUZU » Thu Apr 20, 2017 5:41 pm
Buster28 wrote:Sounds like you hooked up the jumper cables backwards and smoked the alternator and blew some fuses.
Or some of the fusible links. Dennis
For this post the author DSUZU was thanked by:
simm55845
Has thanked: 215 times
Have thanks: 606 times
Postby simm55845 » Fri Apr 21, 2017 2:31 pm
hello dsuzu,
jump start was correct with jump box,even tried to kick start(manual trans)new battery. when key is turned on starter clicks a couple of times then horn wont bloww and lights become dim. after a while every thing goes back to normal but no start even with jump
any thoughts you have will be most appreciated.
simm55845
simm55845
Postby Buster28 » Fri Apr 21, 2017 4:20 pm
simm55845 wrote:hello dsuzu,
simm55845
You initially stated the engine would not start, now your saying it won't crank. It obviously can't start if wont crank so figure out why the starter is not working.
Postby DSUZU » Sat Apr 22, 2017 6:29 am
check BOTH ends of both cables. Dennis
Postby simm55845 » Sat Apr 22, 2017 6:27 pm
hello dsuzu,
do you mean both ends of cables to the battery?
simm55845
simm55845
Return to Drivetrain Problems
Users browsing this forum: Bing [Bot] and 3 guests
