1996 rodeo best way to increase mileage
Postby MattParanoia » Tue Sep 24, 2013 1:44 am
Hello guys, I have a 1996 Isuzu Rodeo 4x4 3.2l v6 5-speed manual. I just got a new job that is pretty faraway and I don't have money for a new car. I average 16 or 17 mpg mixed driving, I can get up to 22 mpg on longer highway drives at around 60-65 mph, and was wondering whether there is a easy lower ratio rear swap to increase my mileage. I'm not sure what gears are currently in the truck, what's the easiest way to figure it out? Also what else would be a good way to save gas?
I currently have an intake that I pulled off of a passport, just did full tune up, and the truck has a coil on plug setup.
Thanks in advance.
MattParanoia
Re: 1996 rodeo best way to increase mileage
Postby Kable » Tue Sep 24, 2013 7:01 am
MattParanoia wrote:Hello guys, I have a 1996 Isuzu Rodeo 4x4 3.2l v6 5-speed manual. I just got a new job that is pretty faraway and I don't have money for a new car. I average 16 or 17 mpg mixed driving, I can get up to 22 mpg on longer highway drives at around 60-65 mph, and was wondering whether there is a easy lower ratio rear swap to increase my mileage. I'm not sure what gears are currently in the truck, what's the easiest way to figure it out? Also what else would be a good way to save gas?
Thanks in advance.
What do you have
Drive Flanges or Auto/Manual hubs?
Run a lighter weight synthetic oil
Stop running 50/50 coolant and switch to something Thinner
Switch to Synthetic Atf in the power steering
Convert the Manual Clutch Fan to an Electric Fan
Or buy a Prius
Kable
Have thanks: 7 times
Postby MattParanoia » Tue Sep 24, 2013 11:33 am
How would I know whether I have flanges or hubs?
I currently run 5w-30 full synthetic.
With the coolant, what would you recommend since winter is coming up?
I've been looking on the forums for a clutch to electric fan conversion, can't find any threads, but is it a straight forward process?
And I don't even have power steering currently, it is hell to drive, but my high pressure hose blew out. Is it a complex fix to replace those hoses?
MattParanoia
Postby chadzu » Mon Sep 30, 2013 10:43 pm
The '96 is sotf, so installing manual hubs will help a tiny bit. There are some 4.10 ratio rodeos out there which may help with highway mileage.
Even after everything you will probably never get better than 19 ish.
chadzu
Have thanks: 17 times
Postby rodeomonkey » Tue Oct 01, 2013 12:31 am
Fold in the wing mirrors while on the freeway. :mrgreen:
Rodeo 94 LS.
rodeomonkey
Mi Amigo
Have thanks: 15 times
Postby Kable » Tue Oct 01, 2013 5:49 am
O yeah, what temp is your thermostat? Too cold and it will burn more gas.
Kable
Return to Drivetrain Mods
Users browsing this forum: Google Adsense [Bot] and 3 guests
