how strong are 5:38 gears in a dana 44
Postby recon » Sat Mar 02, 2013 4:23 pm
how strong are 5:38 gears in a dana 44 .i know the lower the gear ratio the smaller the pinion gear and less tooth count and contact.i am still debating on 5:38 gears dana 44 front and 12 bolt rear or 5:13 gears dana 44 front and a isuzu rodeo dana 44 .if i go dana 44's front and rear i will have more gear options.it will be awhile befose an sas on my truck.my 1st step is to find a wagoneer dana 44.i only plan to run 35's and 5:13 is the closest match.if i go 5:38's i will go 36's
my truck has come a long way since july 2nd 2010 and it is far from finished 8) recon
viewtopic.php?f=15&t=53703
1995 isuzu 4x4 pickup|2.6 4cyl|5spd|3 inch body lift|2.5 inch suspension lift|33 inch treadwright wardens|indy4x hd tie rods|custom winch mount|12000 lb winch|extreme high lift jack|off road lights|front and rear aussie lockers|1.5 inch diff/crossmember drop|sway a way hd torsion bars|jeep trail rated badge|moog ball joints|moog center link|precision cv axle boots|optima battery|skyjacker steering stabilizer|tinted windows|bedliner|window rain guards|Indy4x braided brake lines|indy4x sway bar bushings|exedy daikin clutch kit|revolution 3.07 transfer case gears
Build Thread: http://forum.planetisuzoo.com/viewtopic.php?f=15&t=53703&hilit=evolution+of+my+truck
recon
Has thanked: 109 times
Have thanks: 47 times
Re: how strong are 5:38 gears in a dana 44
Postby foytiX » Tue Mar 05, 2013 10:08 am
I would suggest the 44 in the front with the 12 bolt in the rear. The 12 bolt is stronger than the 44 from everything I've read :). If you win the lotto, just get matt's 12 bolt hybrid axle for the front :twisted:
'90 trooper 2.6 MUA 3" BL 33's, 5.38 gears, 12 bolt locker, and more http://forum.planetisuzoo.com/viewtopic.php?f=15&t=499
'94 Trooper MUA "theBeater"....http://forum.planetisuzoo.com/viewtopic.php?f=15&t=67019
'94 trooper ls.....parts and engine donor
'95 trooper limited.....1" hockey puck lift http://forum.planetisuzoo.com/viewtopic.php?f=15&t=66472
'98 trooper.........parts and trans donor
foytiX
Has thanked: 74 times
Have thanks: 86 times
Postby FTen » Tue Mar 05, 2013 11:33 pm
Another factor is where you source your D44 from. Not all 44's are created equal.
example ... the much vaunted Rubicon has a D44 front ... but in reality it is the smallest lightest carrier and has D30 outers. Very compromised design.
Get a waggy D44 and it is a good middle ground D44 And depending on the year (older 70's model are better) you can put the heavy carrier inside so gear choice isnt a a big problem. 5.38's should be fine just don't slap a big block in it lol
Or you can have a D44 like the one in my trooper ... came out of a mid 70's Chevy one ton. Has the big carrier, heavier outers, thinker axles etc etc, and has a beefy ring and pinion, not to mention very roomy for a big locker :) It costs a few bucks more to set it up right, but so far it has been bullit proof.
REally reading up on all the varients of the D44 and then deciding will help a whole bunch
Oh and I run 5.38 in my axle with mechanical lockers (detroit) and they work great. no problem and I've run them about 5 years now I think. I run 37 inch tires and a double reduction transfer case so i can put some torque down at low speeds and they gears always look perfect when I service it.
currently seeking my next isuzu-stein to be ... LOL
FTen
Trail Rider
Have thanks: 5 times
Return to Drivetrain Mods
