1996 Rodeo V6 4x4
1996 Rodeo V6 4x4
Postby N law » Mon Dec 21, 2015 6:00 pm
I have consistently checked craigslist for the past few years for good deals on Isuzus and have called about a few. I had the 95 trooper limited a few years back that was fun and I made some decent money flipping it, but nothing since then. There was/is a $500 first gen, but it has paperwork problems and has an issue with the starter, so I passed. Last week, I saw an ad for a 96 rodeo 4x4 for a decent price and he had a lot of the parts to fix it, so I went to look at it. The ad said it needed a rear window and front axles and tie rods (which he had, just not installed yet). When I got there, I could tell it was rough! I It was caked with mud and wouldn't start due to a dead battery. He had taken it to Aetna Mountain (northwest GA) about a year ago and then parked it. I brought a battery to see if it would start and the fuel pump seemed to be out. With starting fluid, it fired off for a second.
The guy said he was moving to Florida at the end of the month and needed to offload all of his projects/old vehicles. I gathered that the rodeo was his first vehicle and he has had it for about 10-15 years. His father was a mechanic and he is a motorcycle mechanic (went to MMI in Florida), so he said he took good care of it mechanically. I had my reservations because he also said he flipped it in his front yard after taking it over a jump :shock: I believed it!
I weighed through it and figured that I could get it running with not too much work, so I made an offer below his bottom. He said he was turning in his 2 weeks tomorrow and might be out of a job, so he didn't have time to wait for a better offer and he accepted. I loaded it up on a trailer the next night and brought it home!
99 VX
96 Rodeo Build thread
1975 FJ40
69 Beetle
84 Westfalia
70 VW bus turned camper
86 VW Diesel Golf
07 Frontier V6 6 speed
1999 4Runner Limitee- wife's
2004 Genuine Stella Scooter
N law
Has thanked: 17 times
Have thanks: 61 times
Re: 1996 Rodeo V6 4x4
Postby N law » Mon Dec 21, 2015 6:05 pm
I towed it home on my moms parade float trailer with my frontier. When I unloaded it, it ripped part of the trailer off with the rodeos trailer hitch... Oops! Sorry mom!! I welded it all back and no one will ever know...
A quick couple tests let me believe the fuel pump was the no start issue, so I checked the local parts stores. $120+!?!? Uh no. Rock auto was $15, FTMFW!!!! I ordered tie rods and the center adjuster as well as a new strainer. Parts showed up in two days and I commenced to dropping the tank.
Removing the fuel tank was a PITA. those screws were impossible to get to and most were rusty/stuck. I then googled the POs area code and got Virginia...great! I got the tank dropped and out from under the vehicle. Then I realized that some dummy decided to use screws to hold the fuel pump in... That didn't work, so I used vice grips. 3 of the 8 broke...
The fuel pump went in last night and tank is reinstalled. It fired up around 1:15 this morning and I drove it to get gas! Next is getting it through emissions and registered before doing the front end work!
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Tue Dec 22, 2015 3:52 pm
Replaced the tie rod last night and took it to the emissions testing center today at lunch... no pass because it was "not ready." Ok.... so what do I do? "drive it." But it's not registered? "You have to put it through the drive cycle so it can check all of its sensors." Ok...how long should I drive it illegally? "I can't tell you that; I'm not a mechanic" GAHHHH!!!!! ok...
Anyone know how long I have to drive this thing before its officially mine and I can dump money into it?
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby totten » Wed Dec 23, 2015 10:49 am
Run at least 3 drive cycles,see if that works. Thanks for saving another RODEO . Should be nice when done with repairs. :D
totten
Have thanks: 81 times
Postby N law » Wed Dec 23, 2015 10:56 am
Thanks for the input, but I am a bit unclear on the duration of a "drive cycle." how long is that?
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby totten » Wed Dec 23, 2015 11:02 am
Start ,run through the gears,stop,turn off. do this 3 X . May work for you.
totten
Postby N law » Wed Dec 23, 2015 11:04 am
oh ok, I've drove it last night and to work this morning. Its running great and I went through the gears just fine. I've put over 30 miles on it since I failed, so I'm hoping it passes at lunch today!
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby totten » Wed Dec 23, 2015 11:07 am
Hope that works, if not ck for cel codes. Good luck,Tony Clean the maf,egr valve,air filter,ck all sensors plugged in good.
totten
Postby TrooperChris » Wed Dec 23, 2015 10:53 pm
N law wrote:I towed it home on my moms parade float trailer with my frontier. When I unloaded it, it ripped part of the trailer off with the rodeos trailer hitch... Oops! Sorry mom!! I welded it all back and no one will ever know...
Someone will know! :D
Seriously, this thing was a steal!! Makes me want another trooper!
Past:
1988 Trooper 3"sus, 3"BL 33s Locked 2.6
2001 Trooper 2wd (Wife's)
1997 Trooper, ARB Bumper, M8000, OME Shocks, 919s, G80, Calmini SBs and TBs, Magnaflow Muffler, 33x10.50s
1989 Trooper: V6, 2.8L 4.3TBI, Indy 4x Brake Lines, Big Brake upgrade, Addco Rear Swaybar...waiting for a new 3.4
Current:
2013 Pathfinder Platinum 4x4
2011 Ford Flex Limited
TrooperChris
Have thanks: 11 times
Postby N law » Thu Dec 24, 2015 2:02 am
Passed emissions at lunch today after about 50 miles! He only had it plugged in to the OBII port for about 10 seconds, which was about the same as when it failed, so I assumed it failed but it didn't! Ran over to the courthouse and paid the fees and taxes to get it in my name. No sooner did I prop the plate in the back window, it wouldn't start... I need to replace those battery cables! Thank goodness that happened after the emissions testing or else they would have thought I disconnected it to clear codes and I would have failed again!
I'm glad that's behind me, now I can start working on it for real!
Chris, you need a project to be frustrated with again! Go to advanced search in the top right and search all posts by your name; read. Then go look at your new car and smile that you haven't had to do any transmission work to it!
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby totten » Thu Dec 24, 2015 11:32 am
Glad she running now with paperwork! ECM had to learn I guess. :)
totten
Postby N law » Mon Dec 28, 2015 12:18 am
It was awesome and warm enough today to put the parts on the truck. I got out the CV axles from the box the PO gave me but quickly noticed that they were the same! Well, I hoped that the CV styles were the same, as I have read up on my VX that some after market CVs have a different design and require you to replace the green cup. Since both CVs were the short side, I decided to see if it would work by keeping the green cup attached. All new ball joints were also included! I removed the whole hub and got the driver side removed and reinstalled. Quickly followed was the passenger side. Since I had replaced the passenger side tie rods and center piece, the rodeo drove a little wonky, so I decided to let it out a bit to correct the pulling it was doing. It's better but not quite there yet. Since I have all of the front end pieces on now, I could possibly take it to the place by work that boasts a $25 alignment.
As an added bonus to this deal, I found the receipt from the POs O'Reillys parts order that I inherited. He had a $75/ axle core charge! I'm getting $150 back!!! I stopped by the nearest store today but they said they could either put it back on the card or I could come back when they had enough cash in the drawer to issue a refund. I'll go back tomorrow instead of putting it back on his card!
I also took it to the car wash and blasted the funk and mud off of it. It went from about a 3 to a 5 just in doing that alone. This evening, I pulled the front seats and the center console and vacuumed the carpet and scrubbed at the stains. It's better but not done yet.
Still left to do:
1) replace back quarter glass
2) replace radio, ashtray and ashtray surround.
3) replace front market lights.
4) find out why the brake, airbag and rear ABS lights are on.
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Mon Dec 28, 2015 1:43 pm
Photos added
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Mon Dec 28, 2015 1:45 pm
More photos
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Mon Dec 28, 2015 1:48 pm
Even more photos
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Mon Dec 28, 2015 1:50 pm
Last photos for the time being.
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby RamAirZ » Mon Dec 28, 2015 9:51 pm
Glad to see another one saved :)
Current: 2004 GMC Sierra- slightly modded, baja style :twisted:
2002 Isuzu Rodeo Sport- 3.5 swap, 3.5" lift, 32's, LED pods, custom exhaust
Previous: 1999 Isuzu Vehicross/1997 Isuzu Rodeo/ 1995 Honda Passport
RamAirZ
Have thanks: 27 times
Postby N law » Mon Dec 28, 2015 10:37 pm
RamAirZ wrote:Glad to see another one saved :)
Just took a double take! Holy cow! Welcome back. Did you have a nice vacation?!?
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Thu Dec 31, 2015 5:22 pm
Drove the rodeo to work a couple times this week. It's been a blast but I'll be glad when a few of the parts that I ordered come in. I have new mirrors coming so I can see on the drivers side and won't be seeing double in the broken passenger mirror! The radio is sorely missed and my little handy talkie radio has an fm receiver, but it doesn't do well inside a vehicle. An exhaust is in my future as well.
I had an impromptu meeting with a contractor we work with and he said he saw me driving a "jalopy" ther other day with a duct taped window... I admitted that I had, but I don't think he understood.
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Fri Jan 01, 2016 8:12 pm
Successful day at the pull-a-part! I got all the loose interior parts that I was missing, along with stock speakers (hope they are good... The PO took the speakers and head unit out...). I got front and rear bumpers as well as both from fenders! The kicker- the two rodeos I picked were the same color as mine! It was a blast but I could not get the rear side window glass out of the donor. I'm pumped!
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Fri Jan 01, 2016 9:53 pm
The two donor trucks! I had a blast. I got the two fenders that you see, they had different pin striping and one didn't have the V6 badge. I struggled with the last bolt on the drivers side because it went in from the drivers side footwell. I had to punch through a paper cover over a body hole and then my socket fell off and down into the rocker panel under the door. I could hear it when I hit the rocker with a hammer, but my magnet wouldn't reach. A cold chisel and the hammer opened the rocker up and allowed me to grab it with the magnet! Note for installing the new fenders- don't drop the socket!!!
Last photo is of a highly customized trooper on the lot. Not sure what the bar on the back was for... But I liked that painted on quarter window. Maybe I'll employ that tactic on my broken window
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Sat Jan 02, 2016 2:03 am
That wasn't too bad putting the fenders on. The bolts that go from the inside are much harder to get started than they are to get loose. I got them back on and replaced the grill with the one I found in usable shape that was from a black rodeo. It's pretty sweet! Drivers side corner light is back in but the passenger side was missing the plug!?! Good thing I always make it a point to CUT on the car side of the plug on any electrical device I pull from a junkyard, so I'll solder it up tomorrow. I will also clean all the PO's mud out from behind the bumper too, but I couldn't resist placing it up there for a photo!
I now have three different sets of pin striping! I guess I'll get to removing all of it soon... Or not!
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby N law » Mon Jan 04, 2016 6:51 pm
Took the rodeo duck missing yesterday. Unfortunately the back left tire reached the end of it's life about 15 miles into the trip out to the blind. I heard faint popping going up a hill but couldn't identify it as anything more than my gear shifting. Then the check engine light came on and the butt dropped with a growling sound. I knew it was a flat right away. I was disappointed because I held up our hunting party on the last trip and here I was again. I told them to go on without me and proceeded to change the tire. 13 minutes from 6:05 to 6:18 to swap it out! It helped that the tire was on the back of the rodeo instead of in it like the VX. I made it in time to catch the boat after the decoys were out.
Now I'm skeptic of the tires since they let me down and I'm having to price a moderate AT. I'm looking at an off brand for about $105/tire vs the killer looking wrangler Authority for $156/tire. It adds up and I don't want to dump that much money into this one, but I can always swap tires onto the VX if this rodeo moves along.
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Postby DSUZU » Mon Jan 04, 2016 7:11 pm
So is it a lot easier to replace the fenders with it hanging from the ceiling? :lol: I know Drew (neighbor) just got a set of tires all the way around on his 1996 Rodeo. It was around 600 including alignment (required) and hazard and warrantees. Tire Kingdom. We replaced UCAs first. Dennis
"Jalopy". In my younger days, the term "Jalopy" conjured up a beat up '32 Ford roadster. Dennis
Has thanked: 215 times
Have thanks: 603 times
Postby N law » Mon Jan 04, 2016 7:35 pm
I have been reading up on how to take photos with the iPhone so as not to confuse non-apple products that don't auto-rotate the picture. I was told to have the volume buttons down, but it sounds like either way I post them, they are coming in upside down. I give up!
I have not budgeted for UCAs, let alone tires but I did see the "Alignment- $25" sign painted on the shop window down the street from work.... That's probably in the budget!
We will see what comes of the tire deal. I won't be putting 50k miles on anything anytime soon, so I'm not buying top of the line, name brands for anything but my truck and my wife's car. Those are the only ones I've had that have worn out tires in the past
99 VX
1975 FJ40
69 Beetle
84 Westfalia
86 VW Diesel Golf
N law
Users browsing this forum: No registered users and 6 guests
