2001 to 1997 rodeo
2001 to 1997 rodeo
Postby 01uniq4x4 » Tue Jul 30, 2013 1:20 pm
hello everyone, i have a 2001 isuzu rodeo that i am parting out and a 97 that i'm building at the moment. i was wondering what off of the 2001 i should keep to reuse or just have as spare parts that will bolt up or be useful maybe later on if somthing on my 97 goes out ( seats, consoles, suspension parts, anything that could be used id like to keep just need to be aware of what is swappable between these models) thank you very much for the information. (also while i'm here i'm completely parting out my 2001 isuzu rodeo( have 3 inch suspension lift OME, brand new CV axles, and everything is also on it. a bearing is going bad in the motor but still have that also, located in Madison Heights, Va 24572)
'01 Isuzu Rodeo LS- 3" suspension lift, 3" body lift, 33x12.50x15 Super Swamper TSL Radials on 15x8 Pro Comp 52's, Superwinch Hubs, Rage Stingray roof rack, and a few other dodads
01uniq4x4
Re: 2001 to 1997 rodeo
Postby Jonesy » Wed Jul 31, 2013 1:16 pm
I don't think there are a ton of parts that are completely compatible between the 2 years. Seats probably would...center console may (which would be nice for the cup holders) The suspension, front is close, so things like the CV's would be good, the diff, etc. however you won't be able to swap any of the steering (totatly different systems) Rear end is different also. The axle could be used, but you'd have to weld on spring plates since the 97 is leaf and the 01 is coil.
Obviously the body is quite different, so nothing there. Really there isn't much, trans is most likely the same (assuming both are auto or manual) Not sure what else.
'96 Rodeo V6/5spd 3-link SAS, HP D44, 4-link rear, coil-overs, ARB's, QuickAire 2, 37's...work in (slow)process
97 Rodeo, V6/5spd 3" SL 3" BL, - Retired
Jonesy
Have thanks: 16 times
Postby 01uniq4x4 » Wed Jul 31, 2013 1:30 pm
alright. that helps some. thanks for the info. any more knowledge would be appreciated by anyone else on the subject. thanks
01uniq4x4
Postby nebraskasswuppin » Wed Jul 31, 2013 2:50 pm
I think exterior door handles may switch over. I havnt tried it but they look the same.
02 rodeo sport v6 4x4 hardtop clipper blue. Trooper coils, 245/75/16 stampedes, tinted, all the extras and a few of my own
SOLD 97 rodeo v6 mua5
MY BODY IS MY OFFROAD MACHINE, MY ISUZU JUST GETS ME THERE.
nebraskasswuppin
Have thanks: 23 times
Postby 01uniq4x4 » Thu Aug 01, 2013 8:04 am
ok, thanks for the tip :)
01uniq4x4
Postby mpdetloff66 » Tue Jan 07, 2014 8:56 pm
Looking to sell any of the parts on your 2001 Rodeo via this forum? I would be interested in the front bumper cover! Looking to purchase immediately!
Matt Detloff
Minnesota
2001 Isuzu Rodeo Sport Ironman Edition
mpdetloff66
Has thanked: 41 times
Postby Dingbat » Tue Jan 07, 2014 11:13 pm
The rear bump stops will cross over without modification.
The grille clips line up with the exception of the screw. Though using the grille on the 97 would involve modifying the radiator support/deflector panel to mount the newer style headlights. I am sure other stuff will crossover to a 97, but not as much as would with a 98 or newer.
Wry Wench build thread
Dingbat
Has thanked: 15 times
Have thanks: 60 times
Users browsing this forum: Google [Bot] and 6 guests
